MELOCODI Posted April 16 Author Posted April 16 I use PTM 7950 + Upsiren UTP-8 putty on CPU+GPU dies and VRM+VRAM DELL Precision M4800 "Slave Design" Spoiler GPU: XVSION RTX 4060 8 GB (110W) CPU: i7 4930MX (Ol' Reliable) RAM: 32 GB G.Skill RipJaws 1866 mHz (4 x 8 GB) Storage (SATA1): Samsung SSD 870 EVO 512 GB Storage (SATA2): Samsung SSD 870 EVO 1024 GB
SuperMG Posted April 16 Posted April 16 12 minutes ago, MELOCODI said: Didn't have any results yet, but from what I see - this GPU needs a VBIOS with less max TDP, this goes into a scary territory + some scary coil whine. This is under FurMark 2 VK stress test ≈ 1 minute. Coil whine = high FPS. Happens on every cards I own. What FPS did you get for average? Isn't the maximum throttle 87C for the core? That's good! Hotspot throttle is 105C I believe. Maybe -10C with a two heatpipes design. Standard heatpipes, not the "big flat" one.
MELOCODI Posted April 17 Author Posted April 17 Here is the best picture of the internals I took a while back, maybe that will help, I tried to play around with some heatsink parts to kinda check the fitment, but couldn't figure out how to jam in another heatpipe on the GPU, tolerances are pretty tight... maybe cutting the palmrest plastic is the way? Don't wanna ruin the rigidity DELL Precision M4800 "Slave Design" Spoiler GPU: XVSION RTX 4060 8 GB (110W) CPU: i7 4930MX (Ol' Reliable) RAM: 32 GB G.Skill RipJaws 1866 mHz (4 x 8 GB) Storage (SATA1): Samsung SSD 870 EVO 512 GB Storage (SATA2): Samsung SSD 870 EVO 1024 GB
SuperMG Posted April 17 Posted April 17 1 hour ago, MELOCODI said: Here is the best picture of the internals I took a while back, maybe that will help, I tried to play around with some heatsink parts to kinda check the fitment, but couldn't figure out how to jam in another heatpipe on the GPU, tolerances are pretty tight... maybe cutting the palmrest plastic is the way? Don't wanna ruin the rigidity Thank you. Is the Ethernet port in the same height as the GPU heatpipe? Can you overclock to 4GHz all cores using NVRAM edits + sleep bug to unlock the TDP?
MELOCODI Posted April 17 Author Posted April 17 47 minutes ago, SuperMG said: Thank you. Is the Ethernet port in the same height as the GPU heatpipe? Can you overclock to 4GHz all cores using NVRAM edits + sleep bug to unlock the TDP? I'll check the height. About an overclock - not sure, I am running (1 core - 4 core ratios) : 43, 42, 40, 39 DELL Precision M4800 "Slave Design" Spoiler GPU: XVSION RTX 4060 8 GB (110W) CPU: i7 4930MX (Ol' Reliable) RAM: 32 GB G.Skill RipJaws 1866 mHz (4 x 8 GB) Storage (SATA1): Samsung SSD 870 EVO 512 GB Storage (SATA2): Samsung SSD 870 EVO 1024 GB
SuperMG Posted April 17 Posted April 17 13 minutes ago, MELOCODI said: I'll check the height. About an overclock - not sure, I am running (1 core - 4 core ratios) : 43, 42, 40, 39 That sounds like an overclock to me. Chip can handle 43, 41, 41, 40? Single-thread in CPU-Z, it's 420?
MELOCODI Posted April 17 Author Posted April 17 1 hour ago, SuperMG said: Thank you. Is the Ethernet port in the same height as the GPU heatpipe? Looks like it DELL Precision M4800 "Slave Design" Spoiler GPU: XVSION RTX 4060 8 GB (110W) CPU: i7 4930MX (Ol' Reliable) RAM: 32 GB G.Skill RipJaws 1866 mHz (4 x 8 GB) Storage (SATA1): Samsung SSD 870 EVO 512 GB Storage (SATA2): Samsung SSD 870 EVO 1024 GB
SuperMG Posted April 17 Posted April 17 49 minutes ago, MELOCODI said: Looks like it We can run a heatpipe on the ethernet without trimming it, okay.
panda_zzz Posted April 18 Posted April 18 8 hours ago, SuperMG said: We can run a heatpipe on the ethernet without trimming it, okay. There's no place on the copper grid to solder another copper tube - where are you planning to vent the heat, then? 1
MELOCODI Posted April 20 Author Posted April 20 UPDATE 11 - 13#: now for sure Got a much smaller 240W LA240PM180 charger, it is very sleek and light, love it! An old XM3C3 was too big, it loved to crush things in my backpack. Swapped a severely degraded i7 4980HQ --> i7 4930MX (Slightly overclocked, but most importantly undervolted, don't wanna mess with the old man) NVIDIA RTX 4060 works.. a whole year after I bought it. Countless hours spent on studying DSDT/SSDTs, sketchy Ghidra/IDA Pro patches... just for the main culprit to be... a mutant abomination of a CPU I had... Spoiler IT IS PINK!! You see? You can eat it! Hello Kitty donated her marshmallow for this! Instant +9999 FPS boost!!!! Spoiler DLSS RAYTRACING HUANG JACKET OVEN (nah, screw him, M4800 doesn't wanna see DLSS 5) Custom boot logo (I LOVE Sybreed, I think it really fits this laptop) Spoiler Plans: Get a lower TDP VBIOS (or MAYBE one with adjustable power limits, if it exists... and not kept locked behind countless "BUY OUR GPU, NO BUY GPU = NO VBIOS FOR YOU" emails. Come on, TechPowerUp VBIOS database doesn't bite.) Fix ReBar (i7 4930MX doesn't want to work with my modified BIOS) Do something about the SUBSYS ID on the GPU, I want to get rid of the modded drivers once for all, 1028 15CC ain't gonna cut it. I have to investigate this more... if only DSanke was here.... Do the eDP mod to finally disable iGPU, probably when I get my hands on a better panel, can't afford the panel right now.. Life Is Peachy DELL Precision M4800 "Slave Design" Spoiler GPU: XVSION RTX 4060 8 GB (110W) CPU: i7 4930MX (Ol' Reliable) RAM: 32 GB G.Skill RipJaws 1866 mHz (4 x 8 GB) Storage (SATA1): Samsung SSD 870 EVO 512 GB Storage (SATA2): Samsung SSD 870 EVO 1024 GB
SuperMG Posted April 20 Posted April 20 8 minutes ago, MELOCODI said: UPDATE 11&12#: now for sure Swapped a severely degraded i7 4980HQ --> i7 4930MX (Slightly overclocked, but most importantly undervolted, don't wanna mess with the old man) NVIDIA RTX 4060 works.. a whole year after I bought it. Countless hours spent on studying DSDT/SSDTs, sketchy Ghidra/IDA Pro patches... just for the main culprit to be... a mutant abomination of a CPU I had... Reveal hidden contents IT IS PINK!! You see? You can eat it! Hello Kitty donated her marshmallow for this! Instant +9999 FPS boost!!!! Hide contents DLSS RAYTRACING HUANG JACKET OVEN (nah, screw him, M4800 doesn't wanna see DLSS 5) Custom boot logo Reveal hidden contents Plans: Get a lower TDP VBIOS (or MAYBE one with adjustable power limits, if it exists... and not kept locked behind countless "BUY OUR GPU, NO BUY GPU = NO VBIOS FOR YOU" emails. Come on, TechPowerUp VBIOS database doesn't bite.) Fix ReBar (i7 4930MX doesn't want to work with my modified BIOS) Do the eDP mod to finally disable iGPU, probably when I get my hands on a better panel, can't afford the panel right now.. Life Is Peachy You do need a better heatsink, cicichen made the two heatpipes version. He needs to add some "spiky surface area" on the full copper heatsink and it'll be good to go! Could handle 100W. Wait ReBar and 4G decode exist for the M4800? Any BIOS online? The same for M6800? Since they use the same BIOS type.
MELOCODI Posted April 20 Author Posted April 20 6 minutes ago, SuperMG said: You do need a better heatsink, cicichen made the two heatpipes version. He needs to add some "spiky surface area" on the full copper heatsink and it'll be good to go! Could handle 100W. As I said already - I'll try my best to replicate the design once I get some pictures and information, I've tried to drop in some heatpipes just to see the fitment, but space is kinda restricted there, balls to the wall situation. 8 minutes ago, SuperMG said: Wait ReBar and 4G decode exist for the M4800? Any BIOS online? The same for M6800? Since they use the same BIOS type. I've used xCuri0's Dxe module and guide from here: https://github.com/xCuri0/ReBarUEFI It is pretty hit or miss, I have done this mod at least five times until I got it somewhat right... just to see i7 4930MX walk in and reject everything, laptop didn't even try to boot. Black screen (no backlight too) -> no indicators except for the power button -> pressing the power button results in a fan ramp up and then it shuts down. This is a pretty standard behavior I noticed when BIOS breaks on this laptop. DELL Precision M4800 "Slave Design" Spoiler GPU: XVSION RTX 4060 8 GB (110W) CPU: i7 4930MX (Ol' Reliable) RAM: 32 GB G.Skill RipJaws 1866 mHz (4 x 8 GB) Storage (SATA1): Samsung SSD 870 EVO 512 GB Storage (SATA2): Samsung SSD 870 EVO 1024 GB
SuperMG Posted April 20 Posted April 20 Here's a preview. The surface just need some dissipations points, adapt the height of the right side inductors and that's it! Compatible heatsink for the 4060, 4070.
MELOCODI Posted April 20 Author Posted April 20 7 minutes ago, SuperMG said: Here's a preview. The surface just need some dissipations points, adapt the height of the right side inductors and that's it! Compatible heatsink for the 4060, 4070. That's exactly what I wanted when asking cicichen to make me a heatsink.. dang it.. why it didn't come out like this... DELL Precision M4800 "Slave Design" Spoiler GPU: XVSION RTX 4060 8 GB (110W) CPU: i7 4930MX (Ol' Reliable) RAM: 32 GB G.Skill RipJaws 1866 mHz (4 x 8 GB) Storage (SATA1): Samsung SSD 870 EVO 512 GB Storage (SATA2): Samsung SSD 870 EVO 1024 GB
MELOCODI Posted April 20 Author Posted April 20 This is the one he made for me Spoiler DELL Precision M4800 "Slave Design" Spoiler GPU: XVSION RTX 4060 8 GB (110W) CPU: i7 4930MX (Ol' Reliable) RAM: 32 GB G.Skill RipJaws 1866 mHz (4 x 8 GB) Storage (SATA1): Samsung SSD 870 EVO 512 GB Storage (SATA2): Samsung SSD 870 EVO 1024 GB
SuperMG Posted April 20 Posted April 20 13 minutes ago, MELOCODI said: This is the one he made for me Hide contents He just took the OEM heatsink and added a full copper plate, that's it. The newer version, it's a new base, new heatpipes. I just hope he can really add these spiky dissipations points for the surface because that could help a lot! Like this for example: https://ae01.alicdn.com/kf/S810491978e404e748c165314a164c71f7.jpg
Bublik Posted April 22 Posted April 22 (edited) On 15.4.2026 at 22:32, MELOCODI said: I use an EDP LA-9772p motherboard and tried both restoring the original BIOS (because mine is modded, I have unlocked the SPD write + ReBAR) and also tried CoreBoot, it just doesn't show up for some reason... Hello MELOCODI, How did you enable ReBar in the sBIOS? Do you have instructions for this, or would you perhaps be willing to create some? Maybe next time I should read to the end... Sorry, never mind 😄 I’ve been looking for a solution for quite some time now; the only thing I’ve found were the instructions for unlocking the hidden 4G decode option on GitHub. However, I haven’t found this option in the sBIOS (A26) of my M4800. I need this for an Adlink RTX A1000 Embedded, which absolutely requires this option. Thanks Edited April 22 by Bublik
SuperMG Posted April 22 Posted April 22 4 minutes ago, Bublik said: Hello MELOCODI, How did you enable ReBar in the sBIOS? Do you have instructions for this, or would you perhaps be willing to create some? I’ve been looking for a solution for quite some time now; the only thing I’ve found were the instructions for unlocking the hidden 4G decode option on GitHub. However, I haven’t found this option in the sBIOS (A26) of my M4800. I need this for an Adlink RTX A1000 Embedded, which absolutely requires this option. Thanks So every Ampere cards that are Quadro and from Aetina, ADLINK, Getec don't work because of 4G decode? The only card that seems to work (M18X R2 and R3 SG) is the Quadro RTX A3000 from XVSION Is your laptop eDP or LVDS version? Also these cards lack the backlight pins so that's why the screen stays black for eDP.
Bublik Posted April 22 Posted April 22 I tried both versions with FHD displays. The result was the same: the boot process freezes right before the Dell logo appears, without any error messages displayed via the LEDs above the keyboard. However, the GPU gets warm and the fans start spinning. The Adlink user manual specifies that Above 4G is necessary. I then tested the GPU with a Miner PCIe x1 adapter, and it works. But even on the desktop, it only works with the 4G option enabled. Otherwise, it isn’t recognized.
SuperMG Posted April 22 Posted April 22 45 minutes ago, Bublik said: I tried both versions with FHD displays. The result was the same: the boot process freezes right before the Dell logo appears, without any error messages displayed via the LEDs above the keyboard. However, the GPU gets warm and the fans start spinning. The Adlink user manual specifies that Above 4G is necessary. I then tested the GPU with a Miner PCIe x1 adapter, and it works. But even on the desktop, it only works with the 4G option enabled. Otherwise, it isn’t recognized. Unlucky. ssj92 tried an A4500 from Aetina and it didn't work too, in his Alienware M18X R2. Same issue. I wish these manufacturers could make 3 vbios types like: - default one - no 4G decode + Max-Q - no 4G decode The RTX 4060/4070 (60W or 110W) are the best options for M4800 in eDP with the new dual heatpipes heatsink for the RTX + 240W PSU. They have 4G decode but it's not a necessity for the mxm to work. Maybe for you, the limit comes from the iGPU when it's in Optimus? Did you try in dGPU? In DP out?
Bublik Posted April 22 Posted April 22 Yeah, I tried that too. I systematically tested everything I could think of—UEFI, CSM, with and without Optimus, plus an external monitor, different VBIOSes—but nothing works. It’s always the same result or error 43 after installing the driver. I think there’s also some kind of hardware coding on the GPU that detects that it’s not the original VBIOS.
ssj92 Posted April 22 Posted April 22 On 4/15/2026 at 1:32 PM, MELOCODI said: I use an EDP LA-9772p motherboard and tried both restoring the original BIOS (because mine is modded, I have unlocked the SPD write + ReBAR) and also tried CoreBoot, it just doesn't show up for some reason... Quadro T1000 works perfectly fine though.. I know about the backlight cable mod too, but shouldn't it at least show up with Optimus on? Correct me if I am wrong. If disabling Optimus + having a backlight mod lets these old M6x00 & M4x00 work with newer GPUs then I am shocked... With T1000 disabling optimus results in a black screen (ofc, because I didn't use the edp mod), but laptop actually works. Doing so with 4060 results in a reboot after I apply the settings and in around 5 seconds laptop just shuts down, turns Optimus back on (by itself) and 4060 is not even visible in the system.... Did you also implement above 4g decoding or you only added rebar dxe? My goal is to enable above 4g decode on every laptop I have... 23 minutes ago, Bublik said: Yeah, I tried that too. I systematically tested everything I could think of—UEFI, CSM, with and without Optimus, plus an external monitor, different VBIOSes—but nothing works. It’s always the same result or error 43 after installing the driver. I think there’s also some kind of hardware coding on the GPU that detects that it’s not the original VBIOS. You are literally going through what I did with A4500. At that time I tried everything possible and only solution is above 4g decoding. We need to find a way to implement it into the bios (it IS possible on ivy/haswell at least). 1 Alienware Area-51M R2 : Intel Core i9-10900K | nVidia GeForce RTX 2080 SUPER Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 Alienware 17 : Intel Core i7 4940MX @ 4.5Ghz | nVidia GeForce RTX 4090 Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 Alienware M18x : Intel Core i7 2960XM @ 4.7Ghz | nVidia Quadro RTX 5000 Alienware M17xR3 : Intel Core i7 2920XM @ 4.7Ghz | nVidia Quadro RTX 5000 Alienware M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000)| Precision M6600 (P4000) | 7520 (T1000) | 7720 (Tesla P6) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
SuperMG Posted April 22 Posted April 22 Does AETINA or Adlink sell GeForce RTX cards? If yes, did anyone try? I know that the Turing Quadro ones are working on the Ivy and Haswell laptops. That's also why the Nvidia GeForce Ampère and Ada cards are good. ZRT and XVSION they work without any issues in eDP. I bought another RTX 4070 because it has a good vbios and it's for the M4800.
ssj92 Posted April 22 Posted April 22 13 minutes ago, SuperMG said: Does AETINA or Adlink sell GeForce RTX cards? If yes, did anyone try? I know that the Turing Quadro ones are working on the Ivy and Haswell laptops. That's also why the Nvidia GeForce Ampère and Ada cards are good. ZRT and XVSION they work without any issues in eDP. I bought another RTX 4070 because it has a good vbios and it's for the M4800. No, they only sell official quadro cards. There is no "official" geforce cards. All the geforce mxm cards after 2000 series are frankenmod cards with a leaked vbios that let's them work in mxm form factor. Alienware Area-51M R2 : Intel Core i9-10900K | nVidia GeForce RTX 2080 SUPER Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 Alienware 17 : Intel Core i7 4940MX @ 4.5Ghz | nVidia GeForce RTX 4090 Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 Alienware M18x : Intel Core i7 2960XM @ 4.7Ghz | nVidia Quadro RTX 5000 Alienware M17xR3 : Intel Core i7 2920XM @ 4.7Ghz | nVidia Quadro RTX 5000 Alienware M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000)| Precision M6600 (P4000) | 7520 (T1000) | 7720 (Tesla P6) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
MELOCODI Posted April 22 Author Posted April 22 Hi, everyone, I've tried to implement ReBar using the mod guide from GitHub (made by xCuri0), but it is extremely unstable and is very hit or miss, i7 4980HQ + Quadro T1000 combo made it look like something was going on inside, even had "Above 4G Decoding" and "Resizable Bar" showing up as active in GPU-Z, but the success was short lived (increased bar size to 1 GB from what I remember, after that point - laptop can't boot). I installed i7 4930MX + Quadro T1000 and the mod stopped working compltelely, even when rebar is disabled (github mod allows to set the bar using an .exe app) it doesn't boot, same with RTX 4060. What I think is that the uefipatch step from RebarDxe page should be done differently, after a careful research using GHIDRA & IDA Pro to see EXACTLY what should be patched, because even though there are some provided Haswell 1150 patches on the page - barely any actually apply. DELL Precision M4800 "Slave Design" Spoiler GPU: XVSION RTX 4060 8 GB (110W) CPU: i7 4930MX (Ol' Reliable) RAM: 32 GB G.Skill RipJaws 1866 mHz (4 x 8 GB) Storage (SATA1): Samsung SSD 870 EVO 512 GB Storage (SATA2): Samsung SSD 870 EVO 1024 GB
