Developer79 Posted August 29, 2025 Posted August 29, 2025 Hi, here an Test with P870TM and RTX4070MXM: 1
SuperMG Posted August 29, 2025 Author Posted August 29, 2025 1 hour ago, Developer79 said: Hi, here an Test with P870TM and RTX4070MXM: Hello! What's the max TDP you got? You were thermal throttling? Didn't you use a 1mm shim on the die?
SuperMG Posted August 29, 2025 Author Posted August 29, 2025 Thanks to @Developer79for confirming my hypothesis on the backlight pins. Yes the pin 23, 25, 27 were indeed needed! Sadly Developer79 didn't find a way to do some hardware mods on the PCB of the RTX 4070 MXM. He did it on his MXM connector, which doesn't make the MXM card plug and play on almost any mxm laptops. Although... I'll try my best to solder these 3 pins. The red line is 2 wires. (280 to 23, 25) The green line is 1 wire (278 to 27) If I can't solder these... I need to contact someone else to solder these pins! Wish me luck once I get the 4070 MXM back home! 2
SuperMG Posted September 1, 2025 Author Posted September 1, 2025 Hello. Here's a new clear picture. It shows how to do the mod. It's the right one. I checked the datasheet for the RTX 3060/3070/3080 (from X-VSION, probably the same for ZRT). They also lack the backlight pins 23,25,27 and the vbios don't have eDP. Although, they have DP on DP_D. Theorically, if the backlight pins are modded like on the picture I've sent, the DP could be displayed in the eDP screen! I know you 4 guys have the RTX 3060 or 3080 from X-Vsion. If you have an eDP laptop that has signals for DP_D between pins 206 and 236 of the MXM slot, you can try this mod and let us know please! @sliderfra @therhor70 @aldarxt @ssj92
Developer79 Posted September 2, 2025 Posted September 2, 2025 On 8/29/2025 at 2:20 PM, SuperMG said: Thanks to @Developer79for confirming my hypothesis on the backlight pins. Yes the pin 23, 25, 27 were indeed needed! Sadly Developer79 didn't find a way to do some hardware mods on the PCB of the RTX 4070 MXM. He did it on his MXM connector, which doesn't make the MXM card plug and play on almost any mxm laptops. Although... I'll try my best to solder these 3 pins. The red line is 2 wires. (280 to 23, 25) The green line is 1 wire (278 to 27) If I can't solder these... I need to contact someone else to solder these pins! Wish me luck once I get the 4070 MXM back home! 17 hours ago, SuperMG said: Hello. Here's a new clear picture. It shows how to do the mod. It's the right one. I checked the datasheet for the RTX 3060/3070/3080 (from X-VSION, probably the same for ZRT). They also lack the backlight pins 23,25,27 and the vbios don't have eDP. Although, they have DP on DP_D. Theorically, if the backlight pins are modded like on the picture I've sent, the DP could be displayed in the eDP screen! I know you 4 guys have the RTX 3060 or 3080 from X-Vsion. If you have an eDP laptop that has signals for DP_D between pins 206 and 236 of the MXM slot, you can try this mod and let us know please! @sliderfra @therhor70 @aldarxt @ssj92 Each motherboard must be examined individually and then modified accordingly. Not all displays function in the same way. However, those from Clevo usually do!
SuperMG Posted September 2, 2025 Author Posted September 2, 2025 17 minutes ago, Developer79 said: Each motherboard must be examined individually and then modified accordingly. Not all displays function in the same way. However, those from Clevo usually do! I compared some Clevo P7XX and P870 they do indeed have the same pinouts! Same for the Alienware M17X R4 (it has a mux switch for the eDP connector unlike Clevo) The backlight pins are universal. I can't confirm if other laptops are compatible with that. Some may have different signals for eDP like not being set for port D... Better find the MXM pinouts diagram for your laptop!
SuperMG Posted September 2, 2025 Author Posted September 2, 2025 @Developer79 Solder-less idea, using thin flex cables and one wire. (Sorry for the bad example)
sliderfra Posted September 3, 2025 Posted September 3, 2025 12 hours ago, SuperMG said: @Developer79 Solder-less idea, using thin flex cables and one wire. (Sorry for the bad example) As both 278/280 pins are 3.3v & the 3 others are BL pins (that need 3.3V), you may solder blob the 278+280 & 23/25/27 then solder a single wire between them. I think that the easiest solution. One might even put a switch if mod is not needed to revert to standard specs. EDIT: you need to check schematics as MXM pinout on laptop might not be exactly the same. If you solder 3.3V on GND pin you end up with a dead short
Developer79 Posted September 3, 2025 Posted September 3, 2025 6 hours ago, sliderfra said: As both 278/280 pins are 3.3v & the 3 others are BL pins (that need 3.3V), you may solder blob the 278+280 & 23/25/27 then solder a single wire between them. I think that the easiest solution. One might even put a switch if mod is not needed to revert to standard specs. EDIT: you need to check schematics as MXM pinout on laptop might not be exactly the same. If you solder 3.3V on GND pin you end up with a dead short Yes, be careful when soldering because of short circuits!
SuperMG Posted September 3, 2025 Author Posted September 3, 2025 19 hours ago, Developer79 said: Yes, be careful when soldering because of short circuits! Hello. Do you know the width of one MXM pin? Is it 0.3mm? 0.35mm? Literally no information online other than one thing... 0.5mm pitch, that's it. Here's how it should be.
SuperMG Posted September 5, 2025 Author Posted September 5, 2025 (edited) On 9/3/2025 at 2:01 PM, SuperMG said: Hello. Do you know the width of one MXM pin? Is it 0.3mm? 0.35mm? Literally no information online other than one thing... 0.5mm pitch, that's it. Here's how it should be. Hello guys. I managed to finish the design and I'll find a manufacturer. Edit: I found a manufacturer for making the flex cable mod! It'll get produced on monday Edited September 6, 2025 by SuperMG
SuperMG Posted September 8, 2025 Author Posted September 8, 2025 Hello some news! The manufacturing has started! I'll get the samples maybe this week, but I'm not sure. Here are some pictures on how the backlight mod should work: Here is how it should sit on the top side of the MXM card This mod will work on any Turing to Ada MXM cards that are lacking the 3 backlight panel pins and also the ones who have eDP or DP on port D! You'll finally have a display on your internal screen! 1
ssj92 Posted September 8, 2025 Posted September 8, 2025 45 minutes ago, SuperMG said: Hello some news! The manufacturing has started! I'll get the samples maybe this week, but I'm not sure. Here are some pictures on how the backlight mod should work: Here is how it should sit on the top side of the MXM card This mod will work on any Turing to Ada MXM cards that are lacking the 3 backlight panel pins and also the ones who have eDP or DP on port D! You'll finally have a display on your internal screen! now this is interesting. Wonder if it'll help me run some cards on M17xR3 lol Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
SuperMG Posted September 8, 2025 Author Posted September 8, 2025 15 minutes ago, ssj92 said: now this is interesting. Wonder if it'll help me run some cards on M17xR3 lol M17X R4 is the same M17X R3 eDP in terms of MXM pinouts and connector. Did the Quadro Pascal or GTX 1070M ever work on the R3? Because they do on the R4.
SuperMG Posted September 12, 2025 Author Posted September 12, 2025 New custom heatsink for the P570WM! Will arrive soon to me. I have 3 of them available, if someone wants to buy one, let me know. Compatible for the MXM cards with centered die! Such as RTX A3000,3060,3070,3070 Ti,3080, 3080 Ti,A4500,4080,4090 from X-VSION and ZRT! Up to 175W of heat compatibility! 4 heatpipes for the GPU cores and aluminium cooling for the VRAM/VRM! 1
JadeRover Posted September 15, 2025 Posted September 15, 2025 On 9/1/2025 at 3:30 PM, SuperMG said: I checked the datasheet for the RTX 3060/3070/3080 (from X-VSION, probably the same for ZRT). They also lack the backlight pins 23,25,27 and the vbios don't have eDP. Although, they have DP on DP_D. Theorically, if the backlight pins are modded like on the picture I've sent, the DP could be displayed in the eDP screen! @SuperMG Hi, this is a great mod and could be essential for MXM upgrades !! Where you able to see if a laptop with only DP (display port) output on DP_D would run the eDP screen ? Wouldn't there be issues like screen brigthness adjustments and such ? (heck as long as it outputs a clear picture I wouldn't mind tbh) I would be intrested to try this on my 1060M because it outputs DP on DP_C (that is where my eDP screen is connected on the schematic of my zbook 17 g3) Thanks 1 Precision M6700 : i7-3740QM, M3000M, 20gb DDR3, FHD ips dreamcolor, delta fans Zbook 17 g3 : i7-6820HQ, GTX 1060 (Zotac zbox card), 8gb DDR4 (for now), FHD ips
SuperMG Posted September 15, 2025 Author Posted September 15, 2025 23 minutes ago, JadeRover said: @SuperMG Hi, this is a great mod and could be essential for MXM upgrades !! Where you able to see if a laptop with only DP (display port) output on DP_D would run the eDP screen ? Wouldn't there be issues like screen brigthness adjustments and such ? (heck as long as it outputs a clear picture I wouldn't mind tbh) I would be intrested to try this on my 1060M because it outputs DP on DP_C (that is where my eDP screen is connected on the schematic of my zbook 17 g3) Thanks No idea about your GPU. I know that every Pascal GPUs have the BACKLIGHT pins working. The brightness depends, it can be controlled thru the laptop's motherboard. For my laptop, it's outside the MXM card. It's called BRIGHTNESS_R with one resistor. Your issue is maybe due to a vbios configuration. You need eDP on DP_D since most or "every" Pascal VBIOS has the eDP port declared in the vbios.
SuperMG Posted September 16, 2025 Author Posted September 16, 2025 7 hours ago, JadeRover said: zbook 17 g3 Hello again. I think G2 and G3 are different than G4, G5 and G6. G2 and G3 doesn't have eDP on D but on C for the MXM slot. G4 to G6 they have eDP on D for the MXM slot.
JadeRover Posted September 16, 2025 Posted September 16, 2025 Yes, That's what I found as well, my g3 has edp on port DP_C of MXM slot. Problem is no vbios for 1060 has edp on C and I can't find a way to mod the bios to change DP outputs. Do you think running standard DP to DP_C with hardware mod could work to drive eDP? What should I look for to do this you think? Thanks Precision M6700 : i7-3740QM, M3000M, 20gb DDR3, FHD ips dreamcolor, delta fans Zbook 17 g3 : i7-6820HQ, GTX 1060 (Zotac zbox card), 8gb DDR4 (for now), FHD ips
SuperMG Posted September 16, 2025 Author Posted September 16, 2025 8 minutes ago, JadeRover said: Yes, That's what I found as well, my g3 has edp on port DP_C of MXM slot. Problem is no vbios for 1060 has edp on C and I can't find a way to mod the bios to change DP outputs. Do you think running standard DP to DP_C with hardware mod could work to drive eDP? What should I look for to do this you think? Thanks Change laptop, get the G4. The mux switches are making everything complicated too, it's very hard to do physical mods.
ssj92 Posted September 17, 2025 Posted September 17, 2025 On 9/16/2025 at 3:01 AM, SuperMG said: Change laptop, get the G4. The mux switches are making everything complicated too, it's very hard to do physical mods. If this was our attitude toward all these older laptops, we would have not gotten anywhere in the first place. back in 2012-2013 era, everyone gave up on M17xR3 and M18xR1 saying they will never reach beyond 800M series. Here I am in 2025 with W7100 in M17xR3 (eDP) and RTX 5000 in M18xR1 (Dual PEG). Never give up 😁 Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
SuperMG Posted September 17, 2025 Author Posted September 17, 2025 3 minutes ago, ssj92 said: If this was our attitude toward all these older laptops, we would have not gotten anywhere in the first place. back in 2012-2013 era, everyone gave up on M17xR3 and M18xR1 saying they will never reach beyond 800M series. Here I am in 2025 with W7100 in M17xR3 (eDP) and RTX 5000 in M18xR1 (Dual PEG). Never give up 😁 I would rather change. Look at the Clevo X7200, there's probably a whitelist for the GPU on the master slot, because the GTX 700 and above won't work. The Zbook G2 and G3 have the eDP on DP_C. I don't even know if there are any Pascal Vbios who use eDP on DP_C... But he can try the Quadro RTX Turing from HP because they all have DP on every ports and even DP_C Although, If he really want to use his GTX 1060M... I know one only way to convert "eDP/DP" DP_D to DP_C...
SuperMG Posted September 17, 2025 Author Posted September 17, 2025 22 minutes ago, ssj92 said: If this was our attitude toward all these older laptops, we would have not gotten anywhere in the first place. back in 2012-2013 era, everyone gave up on M17xR3 and M18xR1 saying they will never reach beyond 800M series. Here I am in 2025 with W7100 in M17xR3 (eDP) and RTX 5000 in M18xR1 (Dual PEG). Never give up 😁 Wait, you have a M17X R3 eDP correct? I saw your laptop's MXM slot diagram, you can do the soldered version of the backlight mod! It means you can make your RTX 3080 MXM work with your R3 screen! I need to see if it'll work on this laptop because of the mux switch...
gluon Posted September 18, 2025 Posted September 18, 2025 I've a similar ZBook with the same issue as @JadeRover. My solution is Linux. Out with Optimus, in with Prime. Prime allows for render offload, with the MXM GPU used as the source for iGPU display memory (eDP output). This lessens screen tearing and improves multi-monitoring. Would be interesting to test a HP Turing card with hybrid/discreet modes, though.
ssj92 Posted September 18, 2025 Posted September 18, 2025 20 hours ago, SuperMG said: Wait, you have a M17X R3 eDP correct? I saw your laptop's MXM slot diagram, you can do the soldered version of the backlight mod! It means you can make your RTX 3080 MXM work with your R3 screen! I need to see if it'll work on this laptop because of the mux switch... It won't work. Need a BIOS mod to make UEFI either completely gone or fix the issue. M17xR3 doesn't have UEFI, it has some sort of UEFI wrapper which causes issues with any GPU newer than 800M to not post. WX7100 works because AMD's UEFI vBIOS is different. Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
