Nizmeïster Posted May 23 Author Posted May 23 9 hours ago, SuperMG said: Il y a toujours une solution à tout (sauf si l'on parle de modification du BIOS virtuel Nvidia, c'est impossible :/). Vous pouvez réaliser : des dissipateurs thermiques personnalisés, des supports MXM personnalisés, etc. Hi, do you know what the difference is in terms of mounting holes and GPU position between the A4000 and an RTX 4070, for example?
SuperMG Posted May 23 Posted May 23 3 hours ago, Nizmeïster said: Hi, do you know what the difference is in terms of mounting holes and GPU position between the A4000 and an RTX 4070, for example? The RTX 4070 uses the standard MXM layout and X-bracket layout. The A4000 is different, it's not standard MXM layout because of the core offset, which is in the middle. However a standard X-bracket will work on the A4000 like on the RTX 4070. For both layouts, 4070 and A4000, you need some new heatsinks because of their higher TDP and the different MXM layout.
FrancoTecno Posted May 25 Posted May 25 On 5/22/2026 at 10:31 PM, SuperMG said: There's always a solution for everything (unless we're talking about Nvidia vbios modding, it's impossible:/). You can do: Custom heatsinks, custom mxm holding, etc. yeah obviously i can modify it, but the thing here is. idk if it is going to work with my machine anyway... nobody tested that cards on the GT60/70. the only i saw its a quadro rtx 4000 working on the gt70 from a yt video. and the author dont described what variant of the card he used. MSI GT60 2OC Intel i7 4930MX, GTX 1060, 15.6" FHD (90Hz OC), 32GB RAM, 1TB mSATA RAID 0 (2x512), 1TB HDD, Intel WiFi 7 BE200 Card
FrancoTecno Posted May 25 Posted May 25 theres no data about the module he used. i dont ear the fan spinning at the maximum for example MSI GT60 2OC Intel i7 4930MX, GTX 1060, 15.6" FHD (90Hz OC), 32GB RAM, 1TB mSATA RAID 0 (2x512), 1TB HDD, Intel WiFi 7 BE200 Card
FrancoTecno Posted May 25 Posted May 25 if it works on the GT70, works inthe GT60 since both are basicly the same MSI GT60 2OC Intel i7 4930MX, GTX 1060, 15.6" FHD (90Hz OC), 32GB RAM, 1TB mSATA RAID 0 (2x512), 1TB HDD, Intel WiFi 7 BE200 Card
FrancoTecno Posted May 25 Posted May 25 1 minute ago, FrancoTecno said: theres no data about the module he used. i dont ear the fan spinning at the maximum for example and, i cant confirm if the video outputs are working MSI GT60 2OC Intel i7 4930MX, GTX 1060, 15.6" FHD (90Hz OC), 32GB RAM, 1TB mSATA RAID 0 (2x512), 1TB HDD, Intel WiFi 7 BE200 Card
FrancoTecno Posted May 25 Posted May 25 On 5/23/2026 at 11:20 AM, SuperMG said: The RTX 4070 uses the standard MXM layout and X-bracket layout. The A4000 is different, it's not standard MXM layout because of the core offset, which is in the middle. However a standard X-bracket will work on the A4000 like on the RTX 4070. For both layouts, 4070 and A4000, you need some new heatsinks because of their higher TDP and the different MXM layout. for x-vsion 4070, you can use the stock gt60/70 heatsink and modify it to make fit the card MSI GT60 2OC Intel i7 4930MX, GTX 1060, 15.6" FHD (90Hz OC), 32GB RAM, 1TB mSATA RAID 0 (2x512), 1TB HDD, Intel WiFi 7 BE200 Card
Nizmeïster Posted May 26 Author Posted May 26 Anyway, if the Quadro RTX 3000 works on the GT60, then logically the Quadro RTX 4000 should work as well. And I think the whole Turing family should work fine too, since in the end it’s a generation that’s fairly close to Pascal. But the problem is actually finding these Turing Quadro RTX cards — it’s almost impossible. The 3000 is already very hard to find, but a 4000 or 5000 feels like an impossible mission, I think. As for the 4060/4070, yes, the stock heatsink is enough with a few modifications so the VRMs fit properly. I did it on the GT60 Haswell I used to have. No issues either getting the card recognized with the drivers. The only remaining issues were the EC Panic Mode and the video outputs that needed fixing. But I couldn’t test any further because I quickly switched over to the Precision 7720 that I found brand new for 300 euros...
SuperMG Posted May 26 Posted May 26 1 hour ago, Nizmeïster said: Anyway, if the Quadro RTX 3000 works on the GT60, then logically the Quadro RTX 4000 should work as well. And I think the whole Turing family should work fine too, since in the end it’s a generation that’s fairly close to Pascal. But the problem is actually finding these Turing Quadro RTX cards — it’s almost impossible. The 3000 is already very hard to find, but a 4000 or 5000 feels like an impossible mission, I think. As for the 4060/4070, yes, the stock heatsink is enough with a few modifications so the VRMs fit properly. I did it on the GT60 Haswell I used to have. No issues either getting the card recognized with the drivers. The only remaining issues were the EC Panic Mode and the video outputs that needed fixing. But I couldn’t test any further because I quickly switched over to the Precision 7720 that I found brand new for 300 euros... I have one RTX 3000 HP available if you want. I have like 2 laptops with this GPU, on the M17X R4 eDP 120Hz red nebula and the Dell Precision M6700 Red Covet eDP 120Hz.
Nizmeïster Posted May 26 Author Posted May 26 42 minutes ago, SuperMG said: J'ai une RTX 3000 HP disponible si vous le souhaitez. J'ai deux ordinateurs portables équipés de cette carte graphique : le M17X R4 eDP 120 Hz Red Nebula et le Dell Precision M6700 Red Covet eDP 120 Hz. It seems that HP cards can cause issues on the GT60. They’re slightly wider and apparently don’t fit properly in the chassis. That’s what I’ve been told, but I’ve never checked it myself.
SuperMG Posted May 26 Posted May 26 12 minutes ago, Nizmeïster said: It seems that HP cards can cause issues on the GT60. They’re slightly wider and apparently don’t fit properly in the chassis. That’s what I’ve been told, but I’ve never checked it myself. I was able to fit them on 3 laptops. It's like the RTX 4070, needs small modifications since the core is like 0.4mm to the right.
Nizmeïster Posted May 26 Author Posted May 26 1 hour ago, SuperMG said: J'ai pu les installer sur trois ordinateurs portables. C'est comme la RTX 4070 : il faut faire quelques petites modifications car le cœur est décalé de 0,4 mm vers la droite. Sliderfra told me that HP cards don’t fit in the GT60. Apparently, HP Quadro RTX 3000 cards simply cannot fit inside.
SuperMG Posted May 26 Posted May 26 3 minutes ago, Nizmeïster said: Sliderfra told me that HP cards don’t fit in the GT60. Apparently, HP Quadro RTX 3000 cards simply cannot fit inside. Then how did I make them fit? By the way HP cards are eDP friendly, you don't need to get the backlight mod v2 cable because the AETINA, ADLINK and PNY ones need that cable in order to display in the eDP screen.
Nizmeïster Posted May 26 Author Posted May 26 11 minutes ago, SuperMG said: Comment ai-je fait pour les adapter ? Au fait, les cartes HP sont compatibles eDP ; vous n’avez pas besoin du câble de rétroéclairage modifié v2, car les cartes AETINA, ADLINK et PNY nécessitent ce câble pour s’afficher sur l’écran eDP. On the GT60, the MXM slot is located at the edge of the chassis, preventing larger cards from fitting. The depth is also a tight fit, down to the millimeter, because of the entire mSATA card assembly. It's not a matter of the GPU's orientation; it's simply a matter of the MXM connector's placement, with a reserved space that's precisely sized for the MXM B 3.0 standard. If the card is too wide, it will be blocked by the chassis; if it's too deep, it won't fit because of the mSATA RAID card.
SuperMG Posted May 26 Posted May 26 54 minutes ago, Nizmeïster said: On the GT60, the MXM slot is located at the edge of the chassis, preventing larger cards from fitting. The depth is also a tight fit, down to the millimeter, because of the entire mSATA card assembly. It's not a matter of the GPU's orientation; it's simply a matter of the MXM connector's placement, with a reserved space that's precisely sized for the MXM B 3.0 standard. If the card is too wide, it will be blocked by the chassis; if it's too deep, it won't fit because of the mSATA RAID card. Unlucky for you. Didn't know about this. Might need to modify chassis
Nizmeïster Posted May 28 Author Posted May 28 Well, I’ve started diving into a small project to completely refurbish a GT60 that I repaired some time ago and that was honestly in terrible condition. It’s an Ivy Bridge 16F3 model, currently equipped with an i7-3920XM / 32 GB Kingston HyperX DDR3 at 1866 MHz / GTX 1060 6 GB / 2x500 GB mSATA SSDs plus an additional 500 GB SATA SSD. I’m planning to try either a Quadro A4000 or A3000 in it depending on my budget. The first issue will obviously be the use of a custom heatsink. I asked Chichen to join the project and he’s really into it, so he’s currently studying a possible solution. While we’re at it, we’re also going to improve the cooling system for the i7-3920XM to try and achieve a decent overclock on it. I also ordered a higher-quality TN panel to replace the stock LG display, which had a few dark spots. I chose a B156HW01 V7, which is one of the best 40-pin LVDS panels available. I don’t know if better options exist, or even whether LVDS/eDP converters would properly work to get an IPS panel, so I’d rather stick with a plug-and-play solution. The laptop will use a 240W power supply and is also running a custom unlocked BIOS and custom EC firmware by Svet from MSI. So now we’ll see whether a Quadro A4000 can perform better than RTX 4060 or 4070 mods. I just need to find the money to fund one by selling a few things first!
FrancoTecno Posted May 30 Posted May 30 On 5/26/2026 at 5:51 PM, Nizmeïster said: On the GT60, the MXM slot is located at the edge of the chassis, preventing larger cards from fitting. The depth is also a tight fit, down to the millimeter, because of the entire mSATA card assembly. It's not a matter of the GPU's orientation; it's simply a matter of the MXM connector's placement, with a reserved space that's precisely sized for the MXM B 3.0 standard. If the card is too wide, it will be blocked by the chassis; if it's too deep, it won't fit because of the mSATA RAID card. yeah, the GT60 its weird to make heatsink modifications. actually the most safely upgrade its the Getac/PNY QUADRO RTX 3000 based on @sliderfra review. RTX 4000 its a possible successful upgrade since a guy made it working but we dont know too much details about it. RTX cards from X-Vsion arent a safe upgrade because we dont know the behaviour of the external outputs, on 4060 and 4070 probably not works since both are almost identical. MSI GT60 2OC Intel i7 4930MX, GTX 1060, 15.6" FHD (90Hz OC), 32GB RAM, 1TB mSATA RAID 0 (2x512), 1TB HDD, Intel WiFi 7 BE200 Card
FrancoTecno Posted May 30 Posted May 30 On 5/28/2026 at 6:23 AM, Nizmeïster said: Well, I’ve started diving into a small project to completely refurbish a GT60 that I repaired some time ago and that was honestly in terrible condition. It’s an Ivy Bridge 16F3 model, currently equipped with an i7-3920XM / 32 GB Kingston HyperX DDR3 at 1866 MHz / GTX 1060 6 GB / 2x500 GB mSATA SSDs plus an additional 500 GB SATA SSD. I’m planning to try either a Quadro A4000 or A3000 in it depending on my budget. The first issue will obviously be the use of a custom heatsink. I asked Chichen to join the project and he’s really into it, so he’s currently studying a possible solution. While we’re at it, we’re also going to improve the cooling system for the i7-3920XM to try and achieve a decent overclock on it. I also ordered a higher-quality TN panel to replace the stock LG display, which had a few dark spots. I chose a B156HW01 V7, which is one of the best 40-pin LVDS panels available. I don’t know if better options exist, or even whether LVDS/eDP converters would properly work to get an IPS panel, so I’d rather stick with a plug-and-play solution. The laptop will use a 240W power supply and is also running a custom unlocked BIOS and custom EC firmware by Svet from MSI. So now we’ll see whether a Quadro A4000 can perform better than RTX 4060 or 4070 mods. I just need to find the money to fund one by selling a few things first! what GTX 1060 manufacturer you have? MSI GT60 2OC Intel i7 4930MX, GTX 1060, 15.6" FHD (90Hz OC), 32GB RAM, 1TB mSATA RAID 0 (2x512), 1TB HDD, Intel WiFi 7 BE200 Card
Nizmeïster Posted June 2 Author Posted June 2 On 30/05/2026 at 07:29, FrancoTecno said: De quel fabricant est votre GTX 1060 ? MSI
FrancoTecno Posted June 3 Posted June 3 4 hours ago, Nizmeïster said: MSI video outputs works fine? and you need to modify .inf to get it working or the system detects it as an msi card and allow you to get installed drivers without modify them? one time i tried to make a VBIOS modification of my Aetina GTX 1060 to modify its subsystem ID and stop modifiying the drivers. but since "Pascal TDP Tweaker" had a bug with checksum offset by flashing it the gpu got error 43. i noticed about the bug a few months later but i dont like to disasemble my system only for that. MSI GT60 2OC Intel i7 4930MX, GTX 1060, 15.6" FHD (90Hz OC), 32GB RAM, 1TB mSATA RAID 0 (2x512), 1TB HDD, Intel WiFi 7 BE200 Card
FrancoTecno Posted June 3 Posted June 3 i left this here if anyone have the same Aetina card and want to try this own modified vbios by me, it spoof the subsystem ID of the card with the MSI one and have a +10w of TDP overclock. their checksum is the same as the original unmodified VBIOS. if you flash it with a SPI programmer may be go working. i dont flashed it on mine because i am trying to upgrade the entire GPU and i dont like to dissasemble all the system only for this moddedaetina.rom MSI GT60 2OC Intel i7 4930MX, GTX 1060, 15.6" FHD (90Hz OC), 32GB RAM, 1TB mSATA RAID 0 (2x512), 1TB HDD, Intel WiFi 7 BE200 Card
FrancoTecno Posted June 3 Posted June 3 MSI GT60 2OC Intel i7 4930MX, GTX 1060, 15.6" FHD (90Hz OC), 32GB RAM, 1TB mSATA RAID 0 (2x512), 1TB HDD, Intel WiFi 7 BE200 Card
FrancoTecno Posted July 28 Posted July 28 ok! i finally go for the HP QUADRO RTX 4000. I listened as you said @SuperMG and i will do a heatsink/chassis mod as needed. i will post all the whole process in 2-3 months when the card arrives MSI GT60 2OC Intel i7 4930MX, GTX 1060, 15.6" FHD (90Hz OC), 32GB RAM, 1TB mSATA RAID 0 (2x512), 1TB HDD, Intel WiFi 7 BE200 Card
FrancoTecno Posted July 28 Posted July 28 that card has HDMI in dp_C and eDP on DP_D, so if the bios/ec dont gives issues with video output. it should show image through external ports MSI GT60 2OC Intel i7 4930MX, GTX 1060, 15.6" FHD (90Hz OC), 32GB RAM, 1TB mSATA RAID 0 (2x512), 1TB HDD, Intel WiFi 7 BE200 Card
FrancoTecno Posted July 28 Posted July 28 i have a question @SuperMG, exist a QUADRO RTX 4000 from another OEM in MXM format? because if you see here in this topic, i uploaded a youtube video link when a user uses a QUADRO RTX 4000 on a GT70 system. its probably the HP variant? or maybe from another OEM? MSI GT60 2OC Intel i7 4930MX, GTX 1060, 15.6" FHD (90Hz OC), 32GB RAM, 1TB mSATA RAID 0 (2x512), 1TB HDD, Intel WiFi 7 BE200 Card
