clevo p870km bios question and upgrade to rtx3080 on the way.
6 hours ago, Reciever said:
This forum will respect the wishes of Prema, do not share Prema's work without permission to do so. Any posts related to distribution of such content will be removed, and infractions issued. Consider this a warning.
Any transactions potential or otherwise must take place through the Marketplace, @ViktorV if you plan to sell components through the forums then you will be treated as a vendor to which you will need to abide by Vendor guidelines. This point isnt meant as a warning, just as notice. This would also be the case for anyone in a similar circumstance. As I am sure many would be quite interested in that heatsink, especially P870DM-G owners.
If there is no P870DM-G thread you are all always welcome to make one 🙂
🤣🤣🤣🤣Cool.But in fact, these bios are no longer shown by Prema, since they have undergone changes. I don’t sell heatsinks for p870, but I just decided to help in obtaining them without having any benefit from this. Well, although perhaps the option for 800 euros is more successful for you)) ))And there was a golden time when Prema bios were free and distributed freely, what has changed since then....?
  • Сlevo p870tm1-g 17.3 Fhd 300Hz i9-10980hk ES rtx3060. / Clevo x170smg 17.3 300Hz i9-10850k rtx2070super 32g ddr4 3200Mhz Gskill. / Clevo x170kmg 17.3 2k 165Hz i5-11600k rtx3080 32g ddr4 3200Mhz Hyper-X.
T-radiator with rtx 3080 on Clevo p870tm. Effectively cope with this video card.
today i opened notebook again because i was not happy about screw hole allignment, so i dremel hole to make them perfectly centered, cleaned some pads and adjusted thikness of some of them and i reached max temperature of 85° on gpu core and 93° on hotspot.
benchmark got higher score of 16k on 1080p high preset.
Any plans of trying to overclock the card? For me after many failed OC attempts +90 on the core seems stable and +250 on the memory.
Nice to see improvements though!
Clevo P775TM1-G:
generally im first one to overclock a vga, but here i have 2 problem; 1st is temperature not so cold and second those vga are really expensive if fail 😄  if vga would cost like 300€ i would overclock to max no problem, but if that broke and i dont get it on sale i could spend like 1600€ to get another one 😞
also i had a 1070 never oc and after 3 or more years it never get bga problem, while ive seen lots of them on sale for spare parts because bga got bad...
i think i have to fix thikness of upper card , where are all those inductor and capacitor and mosfet because there i noticed i have too much height on those pads, but i will figure it out later . now i have used 3mm+2mm height , but that is too much i think.
cant use standard guide because my heatsing is soldered together and some spot is higher then normal.
that viktor heatsink however is looking really good
well generally, as long as u only mess with clocks and not voltage (which aint possible with current gpus anyways, except unverdolting) temps shouldnt change much, thus deterioration rates would not increase at all. best thing to do, of course, is to do both UV and OC at the same time 🙂
stock clock 16092 point
+110mhz core no UV 16446 score and temp reached 86° (throttle temp start point)
uv higher oc with shown profile 87°  16372 point
uv lower oc 86°  16448 profile 2
rtx3060 in Clevo p870tm with QTJ1(i9-10980hk ES)
HOLD UP!
10th gen CPU on Z370 chipset? Care to explain please?
I understand it's mobile SKU and engineering sample but still. 10th gen?!?!?!
Very cool stuff!
Clevo P775TM1-G:
1 hour ago, srs2236 said:
HOLD UP!
Very cool stuff!
This is a mutant processor, a mobile i9-10980hk ES (QTJ1) soldered on a lga1151v2 substrate. An excellent processor, but very picky about memory bars, it does not start with all. Works confidently with SK Hynix 2133Mhz RAM, successfully overclocks to 2666Mhz after launch. Also, to run this processor, you will need a Dsanke 9900KS 128g bios.
Why not QTJ0? From what I heard some users even pushed 3200Mhz on memory with one of those.
QTJ1 is more stable with memory selection than QTJ0. I have both processors. They are essentially the same, they differ only in stock frequencies, but it doesn't matter because you won't use them at stock frequencies anyway.
Nice. Thank you for the info. I was planning to buy one of those but I was afraid that it will not work with 2666Mhz RAM.
Aslo do you think that P870DM VRM will handle this 8 core cpu?
It'll do just fine.Pin mod is not needed on the mutant. It is for information only .From memory, take SK Hynix 2133Mhz, it works well with this processor. Then you can overclock it to 2666Mhz. I managed to overclock it to 2933Mhz, it also took 3000Mhz, but it did not work stably.
11 minutes ago, Scruffy said:
i wonder how much that 10th gen cpu 45 watt perform compared to mine 9700k  90watt both 8 core but mine doesnt have ht.
Do not look at the stock values of this processor))) mine runs at a frequency of 5 gigahertz in single thread and 4.3 gigahertz in multi-thread, pl1 125w and pl2 175w, undervolt -125 millivolts for the core and cache.
I also installed a B173HAN03.1 FHD 300Hz display. You can also install 2k 165HZ ne173qhn ny2 and 4k 120Hz b173zan03.3.
4 minutes ago, Scruffy said:
B173HAN03.1 show me 144hrz on ebay is it oc ?
I think he meant B173HAN05.1
Do you think N173HCE-G33 will work in P870DM with 6-43-P8701-020-L cable?
Very interesting! If I sell what I have now I may pursue this route over time.
Wrong) b173han05.1. But b173han03.3 also works, checked.
Now I'll see what kind of connector is on it, 0.5mm or 0.4mm
Forgive me I didn't see the edit. Prema stopped distributing his bios as a result of people and companies stealing his work and reselling for profit. There were also instances where individuals would make small changes in order to claim as their work that resulted in some fried laptops.
what thickness shoud we use here ? (red circle zone)
 i put k9 pro on inductor and was using 3mm+2mm  for mosfet and 3+3mm for capacitor , but i noticed they are too tick. maybe ill go with 3mm+1mm for mosfet and 3mm+1,5mm for capacitors ?
Looked. 0.5mm 40pin EDP connector, standard connector for Clevo p870/775/750 laptops, there is a nuance, the connector on these displays is located on the opposite side of the standard matrices and therefore you will need a long 40pin EDP display cable, for p870 you can use the cable from p775 , it is initially long.
