ViktorV Posted October 6, 2022 Posted October 6, 2022 Look Сlevo p870tm1-g 17.3 Fhd 300Hz i9-10980hk ES rtx3060. / Clevo x170smg 17.3 300Hz i9-10850k rtx2070super 32g ddr4 3200Mhz Gskill. / Clevo x170kmg 17.3 2k 165Hz i5-11600k rtx3080 32g ddr4 3200Mhz Hyper-X.
ViktorV Posted October 6, 2022 Posted October 6, 2022 15 minutes ago, Scruffy said: what thickness shoud we use here ? (red circle zone) i put k9 pro on inductor and was using 3mm+2mm for mosfet and 3+3mm for capacitor , but i noticed they are too tick. maybe ill go with 3mm+1mm for mosfet and 3mm+1,5mm for capacitors ? K5pro and K9pro are not a very good choice, they do not remove heat well. The best liquid thermal pads are laird. Сlevo p870tm1-g 17.3 Fhd 300Hz i9-10980hk ES rtx3060. / Clevo x170smg 17.3 300Hz i9-10850k rtx2070super 32g ddr4 3200Mhz Gskill. / Clevo x170kmg 17.3 2k 165Hz i5-11600k rtx3080 32g ddr4 3200Mhz Hyper-X.
srs2236 Posted October 6, 2022 Posted October 6, 2022 47 minutes ago, ViktorV said: I also installed a B173HAN03.1 FHD 300Hz display. You can also install 2k 165HZ ne173qhn ny2 and 4k 120Hz b173zan03.3. Hi! Thanks for all the very cool info you have been spreading around lately. I have a question for you if you don't mind. Do you think I can install this B173ZAN03.3 4K 120Hz display in my P775TM1-G Clevo? I had a look, but I think the mounting of the panel is different than the one I currently have in my P775. (It's a 4K 60Hz panel for reference, hopefully you know it) Thanks! Clevo P775TM1-G: Spoiler GPU: NVIDIA GeForce RTX 3080 Laptop 16GB (150W, +110MHz Core, +350MHz Mem) CPU: Intel(R) Core(TM) i9-9900KS (5GHz, 4GHz Cache, -130mV, 255A, 200W PL1/2) RAM: DDR4 32 GB (3333MHz, 14-17-17-32, 2x16, Micron rev.E, 1.45v) Storage 1: Kingston KC3000 2TB RAID0 (2x1TB, NVME, PCI-E 3.0) Storage 2: Seagate LM015 2TB (2.5, HDD, SATA3) Storage 3: Integral UltimaPro 512GB (SDXC, 100r/50w, PCI-E) Display: AU Optronics B173ZAN0.10 (4K, 60Hz) Wi-Fi/BT: Killer(R) Wireless-AC 1550 (9260NGW, PCI-E) Operating system: Windows 11 Pro x64 (23H2)
ViktorV Posted October 6, 2022 Posted October 6, 2022 12 minutes ago, srs2236 said: Hi! Thanks for all the very cool info you have been spreading around lately. I have a question for you if you don't mind. Do you think I can install this B173ZAN03.3 4K 120Hz display in my P775TM1-G Clevo? I had a look, but I think the mounting of the panel is different than the one I currently have in my P775. (It's a 4K 60Hz panel for reference, hopefully you know it) Thanks! Yes, you can install this panel on your 775, but as I wrote earlier, the connector is on the other side, and if my memory serves me right, then there is a 0.4mm 40pin edp connector.You can fix the panel using double-sided tape, before centering it on the frame. 1 Сlevo p870tm1-g 17.3 Fhd 300Hz i9-10980hk ES rtx3060. / Clevo x170smg 17.3 300Hz i9-10850k rtx2070super 32g ddr4 3200Mhz Gskill. / Clevo x170kmg 17.3 2k 165Hz i5-11600k rtx3080 32g ddr4 3200Mhz Hyper-X.
ViktorV Posted October 6, 2022 Posted October 6, 2022 Смотри, что есть на AliExpress! Проводной радиатор Clevo P750/1DM P775TM P770 P870 B156ZAN05.1 B173ZAN03.3 4K/120Hz B173HAN05.0/1/2 FHD/240/360Hz EDP 0,4/5m LCD за 1 821,05 руб. https://sl.aliexpress.ru/p?key=2C89mH 1 Сlevo p870tm1-g 17.3 Fhd 300Hz i9-10980hk ES rtx3060. / Clevo x170smg 17.3 300Hz i9-10850k rtx2070super 32g ddr4 3200Mhz Gskill. / Clevo x170kmg 17.3 2k 165Hz i5-11600k rtx3080 32g ddr4 3200Mhz Hyper-X.
jaybee83 Posted October 6, 2022 Posted October 6, 2022 3 hours ago, ViktorV said: This is a mutant processor, a mobile i9-10980hk ES (QTJ1) soldered on a lga1151v2 substrate. An excellent processor, but very picky about memory bars, it does not start with all. Works confidently with SK Hynix 2133Mhz RAM, successfully overclocks to 2666Mhz after launch. Also, to run this processor, you will need a Dsanke 9900KS 128g bios. that. is. hilarious! i love that selfmade "IHS" on top of the bare die mobile cpu which in turn is socketed on an LGA1151 adapter, genius! i love this kinda stuff 😄 and just goes to show what kind of added value a socketed cpu brings in a laptop Mine: Hyperion "Titan God of Heat, Heavenly Light, Power" (2022-26) AMD Ryzen 9 9950X3D (TG High Perf. IHS) / Asus ROG Crosshair X670E Extreme (Qualcomm QCNCM865 Wifi 7 Upgrade) / MSI Geforce RTX 5090 Suprim SOC / G.Skill Trident Z5 RGB DDR5-8000 2x24 GB / 4x Western Digital Black SN850P/X 8TB in 2x16TB RAID 0 / Arctic Liquid Freezer III Pro 420 (Push/Pull 6x Noctua NF-A14 IndustrialPPC-3000 exhaust) / Seasonic TX-1600 W Titanium / Phanteks NV9 MKII Black incl. Premium D-RGB Light Strips Kit (6x Arctic P14 Pro A-RGB black intake / 2x Arctic P14 Pro A-RGB black exhaust / 1x Arctic P14 Pro A-RGB black RAM cooling) / Samsung Odyssey Neo G8 32" 4K 240 Hz / Ducky One 3 Daybreak Fullsize Cherry MX Brown / Corsair M65 Ultra RGB / PDP Afterglow Wave Black / Beyerdynamic DT 770 Pro X Limited Edition My Lady's: Clevo NH55JNNQ "Alfred" (2022-26) Sharp LQ156M1JW03 FHD matte 15.6" IGZO 8 bit @248 Hz / Intel Core i5 12600 / Nvidia Geforce RTX 3070 Ti / Mushkin Redline DDR4-3200 2x32 GB / Samsung 970 Pro 1 TB / Samsung 870 QVO 8 TB / Intel AX201 WIFI 6+BT 5.2 / Win 11 Pro Phoenix Lite OS / 230 W PSU powered by Prema Mod!
srs2236 Posted October 6, 2022 Posted October 6, 2022 17 minutes ago, ViktorV said: Смотри, что есть на AliExpress! Проводной радиатор Clevo P750/1DM P775TM P770 P870 B156ZAN05.1 B173ZAN03.3 4K/120Hz B173HAN05.0/1/2 FHD/240/360Hz EDP 0,4/5m LCD за 1 821,05 руб. https://sl.aliexpress.ru/p?key=2C89mH Nice find, thanks! But can't I just use one of these? (https://www.aliexpress.com/item/1005002211991684.html?spm=a2g0o.productlist.0.0.2a95984dAb8lz5&algo_pvid=9656c590-9309-4eef-bfc1-683bc277f070&algo_exp_id=9656c590-9309-4eef-bfc1-683bc277f070-0&pdp_ext_f={"sku_id"%3A"12000019285628106"}&pdp_npi=2%40dis!GBP!7.34!7.34!!!!!%402100bdec16650656325058775e1bfc!12000019285628106!sea&curPageLogUid=NshHfbYta5pO) Or is it still going to be too short and I have to buy a new special cable? Clevo P775TM1-G: Spoiler GPU: NVIDIA GeForce RTX 3080 Laptop 16GB (150W, +110MHz Core, +350MHz Mem) CPU: Intel(R) Core(TM) i9-9900KS (5GHz, 4GHz Cache, -130mV, 255A, 200W PL1/2) RAM: DDR4 32 GB (3333MHz, 14-17-17-32, 2x16, Micron rev.E, 1.45v) Storage 1: Kingston KC3000 2TB RAID0 (2x1TB, NVME, PCI-E 3.0) Storage 2: Seagate LM015 2TB (2.5, HDD, SATA3) Storage 3: Integral UltimaPro 512GB (SDXC, 100r/50w, PCI-E) Display: AU Optronics B173ZAN0.10 (4K, 60Hz) Wi-Fi/BT: Killer(R) Wireless-AC 1550 (9260NGW, PCI-E) Operating system: Windows 11 Pro x64 (23H2)
ViktorV Posted October 6, 2022 Posted October 6, 2022 3 minutes ago, srs2236 said: Nice find, thanks! But can't I just use one of these? (https://www.aliexpress.com/item/1005002211991684.html?spm=a2g0o.productlist.0.0.2a95984dAb8lz5&algo_pvid=9656c590-9309-4eef-bfc1-683bc277f070&algo_exp_id=9656c590-9309-4eef-bfc1-683bc277f070-0&pdp_ext_f={"sku_id"%3A"12000019285628106"}&pdp_npi=2%40dis!GBP!7.34!7.34!!!!!%402100bdec16650656325058775e1bfc!12000019285628106!sea&curPageLogUid=NshHfbYta5pO) Or is it still going to be too short and I have to buy a new special cable? You can) but the question remains the length of the cable. 1 Сlevo p870tm1-g 17.3 Fhd 300Hz i9-10980hk ES rtx3060. / Clevo x170smg 17.3 300Hz i9-10850k rtx2070super 32g ddr4 3200Mhz Gskill. / Clevo x170kmg 17.3 2k 165Hz i5-11600k rtx3080 32g ddr4 3200Mhz Hyper-X.
runix18 Posted October 7, 2022 Posted October 7, 2022 15 hours ago, ViktorV said: Look Thank for the info. I actually have a P775 cable as well. Desktop - MSI X670E Tomahawk Wifi (cheap Ebay mobo that I fixed) | AMD 9800X3D | 64GB Corsair Vengeance RGB DDR5 6000MHz CL30 Dual Channel Kit | MSI RTX 4070TI Suprim X | Alienware 27 AW2724DM 2K 165 Hz Gsync | Samsung 990 Pro Nvme - Boot | Other various storage | Windows 11 Enterprise x64 SOLD - Clevo P870DM-G | i9-9700K 4.5 Ghz on all cores (-50 mv undervolted) | 32GB Hyper X Black 2666MHz | Clevo RTX 2080 3.1b undervolted for better temp 1905Mhz @881 mv | AUO B173HAN03.1 144hz Gsync | Samsung 980 NVME | Dsanke TM BIOS - Chujoi13 adapted based on needs | Network Card: Intel AX210-AX | Windows 10 Pro x64
ViktorV Posted October 7, 2022 Posted October 7, 2022 ne173qhm-nz1/2/3 2k 240Hz and ne173qum-ny1 4k 144Hz EDP 40pin 0.5mm Сlevo p870tm1-g 17.3 Fhd 300Hz i9-10980hk ES rtx3060. / Clevo x170smg 17.3 300Hz i9-10850k rtx2070super 32g ddr4 3200Mhz Gskill. / Clevo x170kmg 17.3 2k 165Hz i5-11600k rtx3080 32g ddr4 3200Mhz Hyper-X.
Developer79 Posted October 8, 2022 Posted October 8, 2022 On 10/4/2022 at 5:48 AM, ViktorV said: On the p870tm1-g, I use this heatsink for the 10-20-30 series of video cards, the temperature of rtx3060 is 35 ° in idle / web surfing, 60-65 ° in load. On rtx3070 38-40 ° in idle, 68-72 in load. On rtx3080 42° idle, 70-78 under load. Quite satisfied with the results of this radiator. The temperatures seem very high to me under full load. At idle, the temperatures are like mine! I have under full load 50 - 52 degrees over hours with the RTX 3070... 2
Scruffy Posted October 8, 2022 Author Posted October 8, 2022 5 hours ago, Developer79 said: The temperatures seem very high to me under full load. At idle, the temperatures are like mine! I have under full load 50 - 52 degrees over hours with the RTX 3070... 1 message memeber... i guess u use a heatsink modified by a german dude that ask 800€for it ? 😄 in addition 50- 52° in full load.. or u use ur pc inside a refrigerator , or it's liquid, or u use double gpu vapor chamber.... 1 1
ViktorV Posted October 9, 2022 Posted October 9, 2022 14 hours ago, Developer79 said: The temperatures seem very high to me under full load. At idle, the temperatures are like mine! I have under full load 50 - 52 degrees over hours with the RTX 3070... Tell me in more detail on what device do you have such indicators? If this is a laptop, then the noise of the fans there is probably going through the roof, since it’s hard for me to imagine such temperatures at full load on the GPU without the cooling system running at maximum. I observed such temperatures only for laptops on the TongFang platform ( XMG Neo/Mechrevo/Machenike, etc.) with a liquid cooling system, as well as on Clevo p870/p775 with a custom liquid cooling system. Сlevo p870tm1-g 17.3 Fhd 300Hz i9-10980hk ES rtx3060. / Clevo x170smg 17.3 300Hz i9-10850k rtx2070super 32g ddr4 3200Mhz Gskill. / Clevo x170kmg 17.3 2k 165Hz i5-11600k rtx3080 32g ddr4 3200Mhz Hyper-X.
Developer79 Posted October 10, 2022 Posted October 10, 2022 On 10/8/2022 at 7:31 PM, Scruffy said: 1 message memeber... i guess u use a heatsink modified by a german dude that ask 800€for it ? 😄 in addition 50- 52° in full load.. or u use ur pc inside a refrigerator , or it's liquid, or u use double gpu vapor chamber.... No, I do not use a refrigerator, nor water cooling. I use the large vapour chamber! I can gladly make a photo if that is desired!
Developer79 Posted October 10, 2022 Posted October 10, 2022 On 10/9/2022 at 5:14 AM, ViktorV said: Tell me in more detail on what device do you have such indicators? If this is a laptop, then the noise of the fans there is probably going through the roof, since it’s hard for me to imagine such temperatures at full load on the GPU without the cooling system running at maximum. I observed such temperatures only for laptops on the TongFang platform ( XMG Neo/Mechrevo/Machenike, etc.) with a liquid cooling system, as well as on Clevo p870/p775 with a custom liquid cooling system. I don't use water cooling, just the big vapour chamber! Of course, the power dissipation must be transported away quickly. Only with the Vapour one reaches the highest power dissipation! I can gladly make photos later if that is desired....
runix18 Posted October 10, 2022 Posted October 10, 2022 1 hour ago, Developer79 said: I don't use water cooling, just the big vapour chamber! Of course, the power dissipation must be transported away quickly. Only with the Vapour one reaches the highest power dissipation! I can gladly make photos later if that is desired.... Picture please... Desktop - MSI X670E Tomahawk Wifi (cheap Ebay mobo that I fixed) | AMD 9800X3D | 64GB Corsair Vengeance RGB DDR5 6000MHz CL30 Dual Channel Kit | MSI RTX 4070TI Suprim X | Alienware 27 AW2724DM 2K 165 Hz Gsync | Samsung 990 Pro Nvme - Boot | Other various storage | Windows 11 Enterprise x64 SOLD - Clevo P870DM-G | i9-9700K 4.5 Ghz on all cores (-50 mv undervolted) | 32GB Hyper X Black 2666MHz | Clevo RTX 2080 3.1b undervolted for better temp 1905Mhz @881 mv | AUO B173HAN03.1 144hz Gsync | Samsung 980 NVME | Dsanke TM BIOS - Chujoi13 adapted based on needs | Network Card: Intel AX210-AX | Windows 10 Pro x64
Developer79 Posted October 10, 2022 Posted October 10, 2022 1 hour ago, runix18 said: Picture please... I'll get back to you later....
Developer79 Posted October 10, 2022 Posted October 10, 2022 12 hours ago, runix18 said: Picture please... Here is a picture of the internals!
Scruffy Posted October 10, 2022 Author Posted October 10, 2022 yes u and the german dude asking 800€posting always the picture that show almost nothing..... make picture of internal heatshink and on how u screw on 3070 or 3080
Developer79 Posted October 12, 2022 Posted October 12, 2022 On 10/9/2022 at 5:14 AM, ViktorV said: Tell me in more detail on what device do you have such indicators? I use the P870tm like you! Of course the fans must run, otherwise the heat will be too much! There is no other way in an air cooling system...
Developer79 Posted October 12, 2022 Posted October 12, 2022 On 10/10/2022 at 10:53 AM, runix18 said: Picture please... Here...
runix18 Posted October 12, 2022 Posted October 12, 2022 3 minutes ago, Developer79 said: Here... Nice !!! Desktop - MSI X670E Tomahawk Wifi (cheap Ebay mobo that I fixed) | AMD 9800X3D | 64GB Corsair Vengeance RGB DDR5 6000MHz CL30 Dual Channel Kit | MSI RTX 4070TI Suprim X | Alienware 27 AW2724DM 2K 165 Hz Gsync | Samsung 990 Pro Nvme - Boot | Other various storage | Windows 11 Enterprise x64 SOLD - Clevo P870DM-G | i9-9700K 4.5 Ghz on all cores (-50 mv undervolted) | 32GB Hyper X Black 2666MHz | Clevo RTX 2080 3.1b undervolted for better temp 1905Mhz @881 mv | AUO B173HAN03.1 144hz Gsync | Samsung 980 NVME | Dsanke TM BIOS - Chujoi13 adapted based on needs | Network Card: Intel AX210-AX | Windows 10 Pro x64
Scruffy Posted October 12, 2022 Author Posted October 12, 2022 2 hours ago, Developer79 said: Here... if this is not for sale, can u show how vga is screwed to it ?
Scruffy Posted January 13, 2023 Author Posted January 13, 2023 hi again to the forum. im still waiting for some info about heatsink for my 3080, and would like to get my bios to support 3080 natively. i can save my actual bios if needed. cheers to all
srs2236 Posted January 13, 2023 Posted January 13, 2023 2 hours ago, Scruffy said: hi again to the forum. im still waiting for some info about heatsink for my 3080, and would like to get my bios to support 3080 natively. i can save my actual bios if needed. cheers to all Hi! Do you have a hardware flasher and easy access to BIOS chip? If so I can help you with the actual BIOS. I can make your current BIOS support it. There was one already out in the wild though. I believe it was dsankes BIOS with 3080 support. It was in one of the threads here. Up to you which suits you better. Clevo P775TM1-G: Spoiler GPU: NVIDIA GeForce RTX 3080 Laptop 16GB (150W, +110MHz Core, +350MHz Mem) CPU: Intel(R) Core(TM) i9-9900KS (5GHz, 4GHz Cache, -130mV, 255A, 200W PL1/2) RAM: DDR4 32 GB (3333MHz, 14-17-17-32, 2x16, Micron rev.E, 1.45v) Storage 1: Kingston KC3000 2TB RAID0 (2x1TB, NVME, PCI-E 3.0) Storage 2: Seagate LM015 2TB (2.5, HDD, SATA3) Storage 3: Integral UltimaPro 512GB (SDXC, 100r/50w, PCI-E) Display: AU Optronics B173ZAN0.10 (4K, 60Hz) Wi-Fi/BT: Killer(R) Wireless-AC 1550 (9260NGW, PCI-E) Operating system: Windows 11 Pro x64 (23H2)
