cylix Posted October 8, 2022 Author Posted October 8, 2022 2 hours ago, razor0601 said: I know you’re from Germany. Yes I have a fully functional P775TM for sale. I can als sell it as Barebone without CPU, GPU… Yes let me see tomorrow with the i3 8100 if the Mainboard works or not and try and test the i9900k on another pc. 1 hour ago, ViktorV said: In this area, the legs are still covered with thermal paste, there may be poor contact with the processor nickels. Also check the contact pad of the processor, it may also be contaminated with thermal paste. Yes i saw that as well but i think its from the last application there last year so it worked until now like this. But i will take a contact spray and clean that when i mount the test cpu 7950X3D| Zotac 4090 AMP Extreme Airo| MSI MPG B650 Edge Wifi| Lian Li Galahad 360 V2| 48GB GSkillTrident Z RGB 7600|Kingston KC3000 2TB| Fury Renegade 2TB| Lian Li O11 Dynamic Evo| Corsair HX1500i| Samsung Odyssey G9 Neo Threadripper 7995WX Pro | AsRock WRX90 WS Evo | Kingston 128Gb DDR5 5600 ECC | Samsung 9100 Pro 2TB
razor0601 Posted October 8, 2022 Posted October 8, 2022 I hope it will work Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
cylix Posted October 9, 2022 Author Posted October 9, 2022 Looks like my board is dead😓 I just put inside the i3 8100 and its still doing the same thing.. Screen is black and after a while fans go to 100% and shutdown.. Shoul i try one thing more and try and rewrite the fc and bios? What programmer do i need?? @razor0601 Can u pm with a price foe barebone? Thx 😁 7950X3D| Zotac 4090 AMP Extreme Airo| MSI MPG B650 Edge Wifi| Lian Li Galahad 360 V2| 48GB GSkillTrident Z RGB 7600|Kingston KC3000 2TB| Fury Renegade 2TB| Lian Li O11 Dynamic Evo| Corsair HX1500i| Samsung Odyssey G9 Neo Threadripper 7995WX Pro | AsRock WRX90 WS Evo | Kingston 128Gb DDR5 5600 ECC | Samsung 9100 Pro 2TB
razor0601 Posted October 9, 2022 Posted October 9, 2022 Reprogramming doesn’t help you. I did it many times like I posted in my thread. A technician where I sent it to, couldn’t fix it without spending many hours to locate the bricked component. It could be many things. Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
ViktorV Posted October 9, 2022 Posted October 9, 2022 On 10/9/2022 at 6:44 AM, cylix said: Looks like my board is dead😓 I just put inside the i3 8100 and its still doing the same thing.. Screen is black and after a while fans go to 100% and shutdown.. Shoul i try one thing more and try and rewrite the fc and bios? What programmer do i need?? @razor0601 Can u pm with a price foe barebone? Thx 😁 Do you have another video card to check? And one stick of RAM that is not from your kit will not hurt. Have you tried to put different sticks of RAM one at a time? It's just that if your motherboard died completely, then the behavior would be completely different, and you have a reaction to the power button and an attempt to initialize the system, but at some point there is a transition to emergency mode, and it is very likely that some of the components do not receive an answer about condition or temperature. This may well be a faulty RAM or video card. 1 Сlevo p870tm1-g 17.3 Fhd 300Hz i9-10980hk ES rtx3060. / Clevo x170smg 17.3 300Hz i9-10850k rtx2070super 32g ddr4 3200Mhz Gskill. / Clevo x170kmg 17.3 2k 165Hz i5-11600k rtx3080 32g ddr4 3200Mhz Hyper-X.
cylix Posted October 9, 2022 Author Posted October 9, 2022 1 hour ago, ViktorV said: It's just that if your motherboard died completely, then the behavior would be completely different, and you have a reaction to the power button and an attempt to initialize the system, but at some point there is a transition to emergency mode, and it is very likely that some of the components do not receive an answer about condition or temperature. This may well be a faulty RAM or video card. Yeah i tried all the Ram sticks one by one, so i think they are good. The rtx i cannot try it in another system sadly but i think its ok aswell. Why i think the Motherboard is faulty is because of the first thing that happend was that one of the SSD Sata ports was not working anymore. That was the first symptome it showed.. 7950X3D| Zotac 4090 AMP Extreme Airo| MSI MPG B650 Edge Wifi| Lian Li Galahad 360 V2| 48GB GSkillTrident Z RGB 7600|Kingston KC3000 2TB| Fury Renegade 2TB| Lian Li O11 Dynamic Evo| Corsair HX1500i| Samsung Odyssey G9 Neo Threadripper 7995WX Pro | AsRock WRX90 WS Evo | Kingston 128Gb DDR5 5600 ECC | Samsung 9100 Pro 2TB
srs2236 Posted October 9, 2022 Posted October 9, 2022 Maybe the chipset died/malfunctioned? That's the first thing that comes to my mind, because of the SSD failure. It's controlled by the chipset. I assume on normal Z370 motherboards the chipset is cooled with proper heatsink, but on the P775 it's cooled using a 4mm thermal pad against the metal chassis which is kind of a joke and not actual cooling. Both of you with your failed machines have me getting very anxious about my P775TM1-G 😬😬😬 2 Clevo P775TM1-G: Spoiler GPU: NVIDIA GeForce RTX 3080 Laptop 16GB (150W, +110MHz Core, +350MHz Mem) CPU: Intel(R) Core(TM) i9-9900KS (5GHz, 4GHz Cache, -130mV, 255A, 200W PL1/2) RAM: DDR4 32 GB (3333MHz, 14-17-17-32, 2x16, Micron rev.E, 1.45v) Storage 1: Kingston KC3000 2TB RAID0 (2x1TB, NVME, PCI-E 3.0) Storage 2: Seagate LM015 2TB (2.5, HDD, SATA3) Storage 3: Integral UltimaPro 512GB (SDXC, 100r/50w, PCI-E) Display: AU Optronics B173ZAN0.10 (4K, 60Hz) Wi-Fi/BT: Killer(R) Wireless-AC 1550 (9260NGW, PCI-E) Operating system: Windows 11 Pro x64 (23H2)
cylix Posted October 9, 2022 Author Posted October 9, 2022 55 minutes ago, srs2236 said: Maybe the chipset died/malfunctioned? That's the first thing that comes to my mind, because of the SSD failure. It's controlled by the chipset. I assume on normal Z370 motherboards the chipset is cooled with proper heatsink, but on the P775 it's cooled using a 4mm thermal pad against the metal chassis which is kind of a joke and not actual cooling. Both of you with your failed machines have me getting very anxious about my P775TM1-G 😬😬😬 Yeah i think is possible that happend.. 7950X3D| Zotac 4090 AMP Extreme Airo| MSI MPG B650 Edge Wifi| Lian Li Galahad 360 V2| 48GB GSkillTrident Z RGB 7600|Kingston KC3000 2TB| Fury Renegade 2TB| Lian Li O11 Dynamic Evo| Corsair HX1500i| Samsung Odyssey G9 Neo Threadripper 7995WX Pro | AsRock WRX90 WS Evo | Kingston 128Gb DDR5 5600 ECC | Samsung 9100 Pro 2TB
cylix Posted October 11, 2022 Author Posted October 11, 2022 Found a firm that's doing clevo repairs among other laptops. They say they will look into it and try to repaie the motherboard. So one more chance to repair it. If it fails ill sell the rest of the components and go desktop route early as planned. 7950X3D| Zotac 4090 AMP Extreme Airo| MSI MPG B650 Edge Wifi| Lian Li Galahad 360 V2| 48GB GSkillTrident Z RGB 7600|Kingston KC3000 2TB| Fury Renegade 2TB| Lian Li O11 Dynamic Evo| Corsair HX1500i| Samsung Odyssey G9 Neo Threadripper 7995WX Pro | AsRock WRX90 WS Evo | Kingston 128Gb DDR5 5600 ECC | Samsung 9100 Pro 2TB
razor0601 Posted October 11, 2022 Posted October 11, 2022 How many does it cost? Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
cylix Posted October 12, 2022 Author Posted October 12, 2022 17 hours ago, razor0601 said: How many does it cost? Around 220 with transport, if the repair is successful. If not then only around 30-and 40 euros. Well see, ill keep you posted on the progress. Will take around 3 weeks though.. Until then working and playing cloud games with gamepass😅 on the i3 8100 office pc or the tab s7+ 7950X3D| Zotac 4090 AMP Extreme Airo| MSI MPG B650 Edge Wifi| Lian Li Galahad 360 V2| 48GB GSkillTrident Z RGB 7600|Kingston KC3000 2TB| Fury Renegade 2TB| Lian Li O11 Dynamic Evo| Corsair HX1500i| Samsung Odyssey G9 Neo Threadripper 7995WX Pro | AsRock WRX90 WS Evo | Kingston 128Gb DDR5 5600 ECC | Samsung 9100 Pro 2TB
razor0601 Posted October 12, 2022 Posted October 12, 2022 Ok, and when it works please give a feedback what was the problem. Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
ViktorV Posted October 12, 2022 Posted October 12, 2022 The problem will be banal, you'll see😜 1 Сlevo p870tm1-g 17.3 Fhd 300Hz i9-10980hk ES rtx3060. / Clevo x170smg 17.3 300Hz i9-10850k rtx2070super 32g ddr4 3200Mhz Gskill. / Clevo x170kmg 17.3 2k 165Hz i5-11600k rtx3080 32g ddr4 3200Mhz Hyper-X.
Reciever Posted October 12, 2022 Posted October 12, 2022 40 minutes ago, ViktorV said: The problem will be banal, you'll see😜 Usually is AM4-DD | 5800X3D @ 4.45Ghz | Wet Devil 7900 XTX | 32GB DDR4 3200Mhz | 2TB NVME | EVGA 1300w | Win11 IoT UNRAID | Xeon Gold 6248 40c/80t | 64GB + 512GB PMEM | RTX 3090Ti | 9300i-16P | 68TB HDD's | BeQuiet DP 13 1000w HomeLab | E5-2697A 32c/64t | 128GB DDR4 2133Mhz | 2x2x1x1TB NVME Bifurcated | GTX 1060 3GB | X550 10Gbps Telegram / TS3 / Twitter 2700X to 5800X3D upgrade! With a 10850K cameo!
cylix Posted October 13, 2022 Author Posted October 13, 2022 Hahah lets see, i hope it can be repaired, ill be a little sad to sell it in pieces. 7950X3D| Zotac 4090 AMP Extreme Airo| MSI MPG B650 Edge Wifi| Lian Li Galahad 360 V2| 48GB GSkillTrident Z RGB 7600|Kingston KC3000 2TB| Fury Renegade 2TB| Lian Li O11 Dynamic Evo| Corsair HX1500i| Samsung Odyssey G9 Neo Threadripper 7995WX Pro | AsRock WRX90 WS Evo | Kingston 128Gb DDR5 5600 ECC | Samsung 9100 Pro 2TB
cylix Posted November 14, 2022 Author Posted November 14, 2022 So the laptop is back from repair shop, sadly unrepaired...they did repair the cpu socket pins but the problem is still there. I just want to try and reflash the bios with a programmer to check this aswell, but i didnt do it until now so i am a total noob there. Right now on it it the latest bios from clevo and latest ec. 1.07.29. So can one explain in baby steps and with pictures what do i need to do :D. And of course what programmer should i buy. Or can i try directly from a usb stick? LE: Will this work? https://www.ebay.de/itm/394222093154?hash=item5bc977c362:g:TmwAAOSwNaRjDx0C&amdata=enc%3AAQAHAAAA4C2JRoKnZPjJwYgJgRXNwl7yQBGOH5VuuCvjyoMPhCLP2K1bJs4RJGOJjqwnhkPbdRuqS9PVLBuelWIA2epOmjzUACHPHGDebBH2WGun5YlHtXMZXKtE%2F%2FBhEdH07edITZVw6optrs%2Fn6FC3mN9%2B3TzspTTGSLk2qIgP2OUwsq9g2UvpzICje1BmMlqCG8FMuZX5ibJCsJzpQwx4IcTVNZ%2FVGNEzjxR8GwL9nLbYSpdCwGS0qI9VG%2BHQZtpI9Z3CTz8XaWjxB6qhRg8NRAHjmoAHN6VXOxn1PwE9Hwc5s8gw|tkp%3ABFBM8pDg7I5h 7950X3D| Zotac 4090 AMP Extreme Airo| MSI MPG B650 Edge Wifi| Lian Li Galahad 360 V2| 48GB GSkillTrident Z RGB 7600|Kingston KC3000 2TB| Fury Renegade 2TB| Lian Li O11 Dynamic Evo| Corsair HX1500i| Samsung Odyssey G9 Neo Threadripper 7995WX Pro | AsRock WRX90 WS Evo | Kingston 128Gb DDR5 5600 ECC | Samsung 9100 Pro 2TB
ViktorV Posted November 14, 2022 Posted November 14, 2022 1 hour ago, cylix said: So the laptop is back from repair shop, sadly unrepaired...they did repair the cpu socket pins but the problem is still there. I just want to try and reflash the bios with a programmer to check this aswell, but i didnt do it until now so i am a total noob there. Right now on it it the latest bios from clevo and latest ec. 1.07.29. So can one explain in baby steps and with pictures what do i need to do :D. And of course what programmer should i buy. Or can i try directly from a usb stick? LE: Will this work? https://www.ebay.de/itm/394222093154?hash=item5bc977c362:g:TmwAAOSwNaRjDx0C&amdata=enc%3AAQAHAAAA4C2JRoKnZPjJwYgJgRXNwl7yQBGOH5VuuCvjyoMPhCLP2K1bJs4RJGOJjqwnhkPbdRuqS9PVLBuelWIA2epOmjzUACHPHGDebBH2WGun5YlHtXMZXKtE%2F%2FBhEdH07edITZVw6optrs%2Fn6FC3mN9%2B3TzspTTGSLk2qIgP2OUwsq9g2UvpzICje1BmMlqCG8FMuZX5ibJCsJzpQwx4IcTVNZ%2FVGNEzjxR8GwL9nLbYSpdCwGS0qI9VG%2BHQZtpI9Z3CTz8XaWjxB6qhRg8NRAHjmoAHN6VXOxn1PwE9Hwc5s8gw|tkp%3ABFBM8pDg7I5h BIOS: Format the flash drive via Rufus in FreeDOS, and upload the contents of the archive to the root of the flash drive # 1) Boot into the BIOS, in the Security section, disable Secure Boot (disabled by default) 2) Boot from a flash drive in UEFI mode, enter the meset command (the fans will work at 100% and the laptop will reboot) 3) Boot from the flash drive again, enter the fpt -d backup.bin command to save the current BIOS to backup.bin 4) Enter the command fpt -f the name of your BIOS.bin -rewrite -y wait for the end of the process (erasing, flashing, verification) and enter the fpt -greset command (the laptop will reboot with clearing CMOS) 5) To roll back to the previous BIOS, repeat steps 2 and 4, changing the command to fpt -f backup.bin -rewrite -y You will most likely need a programmer, since in order to flash the BIOS from a USB flash drive, you need a workable laptop. This CH341A programmer from your link will work just fine. If you need help with the details of the BIOS firmware, then ask, I will help as far as possible. 1 hour ago, cylix said: So the laptop is back from repair shop, sadly unrepaired...they did repair the cpu socket pins but the problem is still there. How is the laptop behaving now? If there is such a programmer EZP2019 + USB SPI Programmierer for sale near you, then it’s better to take this one, it’s better 1 Сlevo p870tm1-g 17.3 Fhd 300Hz i9-10980hk ES rtx3060. / Clevo x170smg 17.3 300Hz i9-10850k rtx2070super 32g ddr4 3200Mhz Gskill. / Clevo x170kmg 17.3 2k 165Hz i5-11600k rtx3080 32g ddr4 3200Mhz Hyper-X.
Reciever Posted November 14, 2022 Posted November 14, 2022 @ViktorV Please do not post 5 times consecutively. It removes visibility to other threads. Thanks! AM4-DD | 5800X3D @ 4.45Ghz | Wet Devil 7900 XTX | 32GB DDR4 3200Mhz | 2TB NVME | EVGA 1300w | Win11 IoT UNRAID | Xeon Gold 6248 40c/80t | 64GB + 512GB PMEM | RTX 3090Ti | 9300i-16P | 68TB HDD's | BeQuiet DP 13 1000w HomeLab | E5-2697A 32c/64t | 128GB DDR4 2133Mhz | 2x2x1x1TB NVME Bifurcated | GTX 1060 3GB | X550 10Gbps Telegram / TS3 / Twitter 2700X to 5800X3D upgrade! With a 10850K cameo!
cylix Posted November 14, 2022 Author Posted November 14, 2022 @ViktorV you mean this one? https://www.ebay.de/itm/125246438235?hash=item1d2944fb5b:g:-QMAAOSwtD5iTYdI&amdata=enc%3AAQAHAAAA8BNZGYEfBz8XjEfRfN8Q3bs3CKxBuUpblOzTLcy7kUsmadI097XhNDpYEtbQToCKk3Y4mtq7e4GKrPah13lR6JNpplkyPodFmZ1ICcBsHerIx5O3kXWpFJXdEe1EdEQgppXFO1VMJ9%2BHZD35CqkPYxBSUvb76tnTe2c9fucH6uNujhuxkqDvplSvV9tpz7ZILnqla3fd1X%2BKMq0vYDBf7DxNK%2FDdVMzr%2BhxElUfvZRjMeW2heYBt12zd%2F8%2BByemmmJioIhVS8mloqhrHjs8Pm4wUvCB6A6Wmpvx%2FcHRWscR%2F1K06Xcu257Lp5T0qmrx4Dw%3D%3D|tkp%3ABFBMqtKr9Y5h yes i can buy it. will be here around the 22 of november Laptop is still behaving like before, black screen and afterwards fans go 100% keboard is blue color, so no way i can get into bios and update it with usbstick. So only option is with a programmer. 7950X3D| Zotac 4090 AMP Extreme Airo| MSI MPG B650 Edge Wifi| Lian Li Galahad 360 V2| 48GB GSkillTrident Z RGB 7600|Kingston KC3000 2TB| Fury Renegade 2TB| Lian Li O11 Dynamic Evo| Corsair HX1500i| Samsung Odyssey G9 Neo Threadripper 7995WX Pro | AsRock WRX90 WS Evo | Kingston 128Gb DDR5 5600 ECC | Samsung 9100 Pro 2TB
ViktorV Posted November 15, 2022 Posted November 15, 2022 9 hours ago, cylix said: you mean this one? Yes 1 Сlevo p870tm1-g 17.3 Fhd 300Hz i9-10980hk ES rtx3060. / Clevo x170smg 17.3 300Hz i9-10850k rtx2070super 32g ddr4 3200Mhz Gskill. / Clevo x170kmg 17.3 2k 165Hz i5-11600k rtx3080 32g ddr4 3200Mhz Hyper-X.
cylix Posted November 15, 2022 Author Posted November 15, 2022 Thanks, but i just talked with the repair shop and they also did a bios flash with the programmer with no luck so it looks like the mainboard is fried.. 😑. So i think this is it for the laptop, cannot find a cheap replacement so probably ill sell the working components.. 7950X3D| Zotac 4090 AMP Extreme Airo| MSI MPG B650 Edge Wifi| Lian Li Galahad 360 V2| 48GB GSkillTrident Z RGB 7600|Kingston KC3000 2TB| Fury Renegade 2TB| Lian Li O11 Dynamic Evo| Corsair HX1500i| Samsung Odyssey G9 Neo Threadripper 7995WX Pro | AsRock WRX90 WS Evo | Kingston 128Gb DDR5 5600 ECC | Samsung 9100 Pro 2TB
ViktorV Posted November 15, 2022 Posted November 15, 2022 4 hours ago, cylix said: So i think this is it for the laptop, cannot find a cheap replacement so probably ill sell the working components.. Do you need a motherboard or do you want another laptop? Сlevo p870tm1-g 17.3 Fhd 300Hz i9-10980hk ES rtx3060. / Clevo x170smg 17.3 300Hz i9-10850k rtx2070super 32g ddr4 3200Mhz Gskill. / Clevo x170kmg 17.3 2k 165Hz i5-11600k rtx3080 32g ddr4 3200Mhz Hyper-X.
cylix Posted November 15, 2022 Author Posted November 15, 2022 New motherboard if the price is ok, also second hand is good. If not then ill sell the components 😅 7950X3D| Zotac 4090 AMP Extreme Airo| MSI MPG B650 Edge Wifi| Lian Li Galahad 360 V2| 48GB GSkillTrident Z RGB 7600|Kingston KC3000 2TB| Fury Renegade 2TB| Lian Li O11 Dynamic Evo| Corsair HX1500i| Samsung Odyssey G9 Neo Threadripper 7995WX Pro | AsRock WRX90 WS Evo | Kingston 128Gb DDR5 5600 ECC | Samsung 9100 Pro 2TB
ViktorV Posted November 16, 2022 Posted November 16, 2022 10 hours ago, cylix said: New motherboard if the price is ok, also second hand is good. If not then ill sell the components 😅 Unfortunately, the motherboard for p775tm has already been sold, there are Clevo p870tm and x170smg laptops, if interested, we can discuss. Сlevo p870tm1-g 17.3 Fhd 300Hz i9-10980hk ES rtx3060. / Clevo x170smg 17.3 300Hz i9-10850k rtx2070super 32g ddr4 3200Mhz Gskill. / Clevo x170kmg 17.3 2k 165Hz i5-11600k rtx3080 32g ddr4 3200Mhz Hyper-X.
razor0601 Posted November 17, 2022 Posted November 17, 2022 Oh my god. That’s what they did? Bios reflashing and pin rapiring? Stupid guys. I told you before that it’s not a Bios issue. It could be many but not a Bios or a pin issue. Did they check that all voltages are correct? Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
