JadeRover Posted August 15 Author Posted August 15 14 hours ago, Khenglish said: So for all 3 vbios that work, all 3 can OC memory to 8GHz OK, so you set 4004mhz on vram and that allowed the card to oc the ram? I've done more testing on the downclocking of the card and I noticed that setting lower clocks just on the core clock list results in downclock + only downclocking on the limit clocks found in the vp profiles also results in downclock (both are independent). So that means that card reads both core clock list + vp profiles to set it's clock value. On my p4000 if I left the limit clock untouched and OC core clocks in the clock list, card would not OC, I also had to raise vp profile limits clocks. My program does both but it appears that this isn't enough for p5200, there must be another hidden "max" limit clock value, in our case 1708mhz. Now I will attempt to replace the p5200 vp section with the sections of GTX cards and p4000 to see if that resolves the issue. EDIT : Well I am starting to fear that the 1708Mhz is baked in deeper into the vbios or the driver as even when using a GTX Virtual P state table or parts of VP table of the MSI P5200 vbios I still hit the 1708Mhz wall... I still have some hope as I am pretty sure the MSI vbios does make the card boost to 1911Mhz (userbenchmark scores) as well as the HP zvr backpack vbios. + Some guy in china managed to boost the P3200 & P4200 to 1900Mhz & 9Ghz vram : P3200 : Search & P4200 : Search The MSI vbios flat out refuses to boot on my system. Pasting parts from the performance section into the working "dell" vbios results in no boot as well Precision M6700 : i7-3740QM | P3000 6gb engineering vbios | 20gb DDR3 1600Mhz | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | M3000m 4gb | 16gb DDR4 2400Mhz | FHD ips Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 3011Mhz | 1440p165hz (upgrad) Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 2666Mhz | FHD IPS
Khenglish Posted August 16 Posted August 16 Yeah anything 4004 or higher sets 8GHz ram as long as a I don't touch the base or boost clocks. 6GHz if I touch those. I also tried again to mod the P4000 device ID to be a P5200. That failed again. There seems to be some security check beyond checksums to check the device ID. Also, I tried 10GHz again, but it just ran 8GHz. My guess is I just got error 43 before due to bad card seating or something, and not due to the card trying 10GHz. I also tried undervolting in hardware since we can't in software. The problem with this is the GPU core still has the same target voltage, so when I supply a lower voltage the on-die droop detectors engage and start clock stretching (This is a frequency loss not reported in software since the GPU is still requesting 1708). I dropped power draw by 10%, but dropped perf 1-4% depending on the test. So really the only way to undervolt without perf loss is bios modding if we could figure out how to mod the VF curve.
Khenglish Posted August 19 Posted August 19 One possibility to get around vbios overclocking locks might be if we could get device ID modding to work. The P5000 is the same 16GB memory config as the P5200, so that could be used as a base. I wonder if the older P4000 and P5000 vbios aren't as locked down as the later P5200 vbios.
JadeRover Posted August 19 Author Posted August 19 Yes I though of that as well, I am also thinking of looking into the voltage table that should exist? I found some info of it for Pascal on the internet, that might be a way to unlock clocks or undervolting for these cards. Precision M6700 : i7-3740QM | P3000 6gb engineering vbios | 20gb DDR3 1600Mhz | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | M3000m 4gb | 16gb DDR4 2400Mhz | FHD ips Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 3011Mhz | 1440p165hz (upgrad) Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 2666Mhz | FHD IPS
JadeRover Posted August 19 Author Posted August 19 This stock HP VR backpack bios worked to make the card post and get the core to 1911Mhz, I am trying to reverse engineer it to find where the 1911M hz limit is VS the 1708Mhz limit in the dell vbios. P5200_HP_ZVRG1.bin Precision M6700 : i7-3740QM | P3000 6gb engineering vbios | 20gb DDR3 1600Mhz | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | M3000m 4gb | 16gb DDR4 2400Mhz | FHD ips Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 3011Mhz | 1440p165hz (upgrad) Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 2666Mhz | FHD IPS
Khenglish Posted August 19 Posted August 19 Interesting. My lenovo system recognizes the card with that vbios while the Clevo does not. It does boost up to 1911, but the power limit is not behaving right. I'm hitting the power limit at around 120W, even at the stock 150W, or if I raise it to 175W. I tried 8GHz RAM on that which worked. Trying 9GHz and 8.5GHz got me locked to 6GHz though. GPUz would report the set overclock as the default clock, but it would actually run 6Ghz. Overall perf is worse on this even with 8GHz ram. Clock offsets would be fun if you could get that to work.
Khenglish Posted August 29 Posted August 29 On 8/19/2026 at 4:56 PM, JadeRover said: This stock HP VR backpack bios worked to make the card post and get the core to 1911Mhz, I am trying to reverse engineer it to find where the 1911M hz limit is VS the 1708Mhz limit in the dell vbios. P5200_HP_ZVRG1.bin 231.5 kB · 1 download Did you get higher performance out of this vbios? For me higher clocks would be reported, but it seems like it never actually ran at those clocks. The card always performs like it is running at 1695.5
JadeRover Posted August 31 Author Posted August 31 Hello, I need to test that out, I still haven't figured out what inside the vbios is responsible for the boost to 1911Mhz vs 1708Mhz Precision M6700 : i7-3740QM | P3000 6gb engineering vbios | 20gb DDR3 1600Mhz | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | M3000m 4gb | 16gb DDR4 2400Mhz | FHD ips Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 3011Mhz | 1440p165hz (upgrad) Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 2666Mhz | FHD IPS
GigaBusterEXE Posted September 14 Posted September 14 (edited) Hello, I have P100 on order for a different project, I tried changing clock limits with a vbios I got from tech power up to practice with but after I hit save as, the info box says the bios is saved but when I open it, it still has the same clocks saved in it Is this because I used the packed EXE? I'm an idiot, it works fine I will be dumping my own when it arrives Also I have heard people in here say they can use the bypass nvflash to to flash modified bios on desktop pascal, did I interpret that correctly Thank you for creating this program, I use Tesla in combination with nvidia Optimus/linux Prime to play games but they have very low frequency Edited September 19 by GigaBusterEXE I'm an idiot, program works fine
GigaBusterEXE Posted September 19 Posted September 19 So I was experimenting with vbios on tech power up and my boss has some 32gb V100's so I loaded up their bios and I noticed the core clocks as seen by CPR are half while the memory clock is correct On the 16gb P100 core clocks are correct but memclock is represented as 5005Mhz while it's supposed to be 715, 715x7=5005 I won't have my p100 until monday I hope this helps
JadeRover Posted September 19 Author Posted September 19 Hello, Sorry I am a bit busy with stuff that is not CPR lately. Can you send me your vbios ? I can have a look in the program + with HEX editor to understand what is going on. Precision M6700 : i7-3740QM | P3000 6gb engineering vbios | 20gb DDR3 1600Mhz | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | M3000m 4gb | 16gb DDR4 2400Mhz | FHD ips Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 3011Mhz | 1440p165hz (upgrad) Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 2666Mhz | FHD IPS
GigaBusterEXE Posted September 19 Posted September 19 Here's the v100 https://www.techpowerup.com/vgabios/209889/nvidia-teslav100-32768-180223 P100 https://www.techpowerup.com/vgabios/283159/283159 The 5005mhz issue was because I was looking at my Titan X bios because I named it similarly It's showing 0mhz for p100 mem I still can't edit core clocks on either p100 or v100 though
Allleeexxx Posted September 22 Posted September 22 On 7/15/2026 at 4:09 PM, JadeRover said: V1.3.4 released. GitHub updated. Anyone with a pascal mobile card, a 1.8 volt firmware flasher like CH341a and spare time is welcome to use the program and try creating some custom vbioses. If you encounter issues I will ttake a look as to improve the program ! I can also use some testers for quadro P6 and P106m so that I can look into creating completely custom vbios for these cards. Hello, I have a P6 and can test VBIOSes.
Nowan Posted September 23 Posted September 23 I was able to change the edp output but i have no way of testing it with the quadro p4200 cause i brick my m6700s mxm slot when i was adjusting the thermal pads. i copy the code section from the quadro p4000 engineerng vbios to a quadro p4200 oc imac vbios. anyone be interested of trying out this vbios for edp output? P4200_R2test3
GigaBusterEXE Posted September 27 Posted September 27 this is the P100 rom I dumped myself, still can't save changes, I think maybe it has some different clock offsets GP100.rom
Ralph Posted Thursday at 05:13 PM Posted Thursday at 05:13 PM On 8/16/2026 at 2:31 AM, Khenglish said: I also tried again to mod the P4000 device ID to be a P5200. That failed again. There seems to be some security check beyond checksums to check the device ID. This will not work because its hardware locked. There is protection made on board somewhere around chipset. Device id has to be the same in vbios. This is each time checked. If its different then you will get error 43. No crossflashing 😉
Ralph Posted Thursday at 05:16 PM Posted Thursday at 05:16 PM On 7/11/2026 at 2:57 PM, JadeRover said: Hello everyone, Good news, an actual working version of the tool, v1.3.4 is in the works. The secret? Actually do some real life rigorous testing 😉 Here is some extreme overclocking on my p4000: Didnt know that memory on Pascal cards can go that high. Your oc is insane 😅 will test 2ghz on my mx230 🙃
Khenglish Posted yesterday at 12:25 AM Posted yesterday at 12:25 AM 7 hours ago, Ralph said: This will not work because its hardware locked. There is protection made on board somewhere around chipset. Device id has to be the same in vbios. This is each time checked. If its different then you will get error 43. No crossflashing 😉 But if that is true then why can I run a P5200 vbios? Why would a P4000 moded to P5200 not work?
Ralph Posted 23 hours ago Posted 23 hours ago 7 hours ago, Khenglish said: But if that is true then why can I run a P5200 vbios? Why would a P4000 moded to P5200 not work? P4000 has 8gb and P5200 has 16gb. So my guess is that you use the same vbios for your card but someone maybe made some small changes inside your original vbios. To make it work you can ONLY flash vbios from the same gpu model as you have. It can be from different manufacturer but it has to be the same model. For example Dell P4000 vbios flashed to MSI P4000. P5200 vbios flashed to P4000 = error 43
