10 hours ago, SuperMG said:
Quadro RTX 5000、RTX 2080 Max-Qと同等の性能です。
また、ZRT RTX 4090を入手した人もいますが、これはX-Vsionのものと同じvbiosですが、Max-Qです。そのため、データシートに記載されている150W、ディスプレイテーブルの順序、eDP(無効になっています。通常のドライバーでテストしました)に関する記述は嘘でした。
P570WMの余剰在庫はありますか?3D対応でも非3D対応でも構いません。
That's right.
Was the VBIOS for the ZRT RTX4090 the same as X-vision?
Does this mean that ZRT cards cannot be used with the P570WM?
Unfortunately, we do not have any surplus stock of the P570WM.
7 hours ago, Tetsu said:
So, does that mean the only RTX card that could potentially be used is the ENBIK?
They all can be used but you need to do some EDID override. I'm still waiting for @DynamiteZerganswer on that with the proper ZRT drivers. To see if he's getting the same issue or not
Hmm, I'm not entirely sure, but I suspect ENBIK's MXM cards use the same VBIOS as X-vision.
The price isn't listed on ENBIK's website, so I'm not sure if I can buy it, but I'll try to purchase it using an import agent.
Hello, do you have any spare LVDS P570WM for sale? That works?
On 2026/5/7 at 午後6時8分, SuperMG said:
こんにちは、LVDS P570WMの予備品は販売されていますか?動作するものでしょうか?
I have a damaged LVDS motherboard. It won't boot.
I'm currently on Hachijojima Island, so I can't go to the warehouse on the mainland to pick it up.
You can still find eDP-type motherboards for sale on eBay, but they're quite expensive.
I have a question regarding the P570WM: Does the PremaMod 1.03.07 V5 BIOS not support 64GB of RAM?
I already have them, I just need to assemble my eDP motherboard+ eDP cable + eDP screen. I don't have the whole chassis with the power button and heatsinks.
No it doesn't accept 64GB sadly... The BIOS needs to be edited for that
It seems someone on X (Twitter) has created a ModBIOS that supports 64GB RAM. They were trying to submit it to PremaMod.
I tried contacting that person, but received no reply.
It's like on the X7200. The X7200 boots with 16GB modules but doesn't use them all... It's set at 0GB but HWINFO recognize them. It's a BIOS memory mapping issue of course.
can you show me the post. I was under the impression sandy/ivy can't do 64gb on mobile so-dimm but if I can see what they did I can port it possibly
7 hours ago, ssj92 said:
投稿を見せていただけますか?Sandy/IvyではモバイルSO-DIMMで64GBは使えないと思っていたのですが、彼らが何をしたのかが分かれば、移植できるかもしれません。
Hello.
That person's account name is BufferMod. You should be able to find it easily by searching on X.
2026年5月9日午前2時25分、ssj92さんはこう言いました。
Sandy Bridge/Ivy BridgeではモバイルSO-DIMMで64GBは使えないと思っていましたが、どれが何をしたのかが分かれば、移植できるかも知れません。
This is the content of the post.
3 minutes ago, Tetsu said:
Hello.
This is the content of your post. Please review it.
Tell him this for the P570WM:
The only mods I did, was to get the Prema BIOS, make a backlight mod cable FPC for RTX, add the RTX 4090 MXM and make a modded custom heatsink.
Can he come to this forum please? I need his BIOS for the 64GB RAM!! Clean ME bios of course.
Normally the X79 and X58 chipset support 16GB DIMM per slot. But the BIOS limited them to 8GB DIMMs.
13 minutes ago, SuperMG said:
P570WMについては、彼にこう伝えてください。
私が行った改造は、Prema BIOSの入手、RTX用のバックライト改造ケーブルFPCの作成、RTX 4090 MXMの追加、そして改造カスタムヒートシンクの作成だけです。
彼にこのフォーラムに来てもらえませんか?64GB RAM用のBIOSが必要なんです!もちろんクリーンなME BIOSでお願いします。
I've conveyed the content of the comment. I don't expect a reply, though...
26 minutes ago, SuperMG said:
Hello. Where did you find this?
What module was updated/edited in UEFI tool?
Thank you
files come from that BufferMod guy.
not sure what is modded exactly since I dont have a P570WM and never researched about it myself.  maybe something related to this, I guess.
So it's a Prema mod one but modified? Clean ME region? EDP compatible I suppose, it says 120hz on his tweet
3 hours ago, SuperMG said:
つまり、Prema mod 1 を改造したものってこと?クリーンな ME 領域?EDP 互換だと思う。彼のツイートには 120Hz と書いてある。
Hello.
Has the BIOS on your P570WM been updated? It should work without problems using Rufus.
Since the Readme is a .doc file, I don't have the corresponding application, so I'll try running it once I find a compatible application and check its contents.
Hello.
No I don't run, I wait for others to test it.
いいえ、私は走りません。他の人がテストするのを待っています。
The update procedure should be in the Readme file. It's best to check it before proceeding. I also plan to check the Readme file before flashing.
Do you have 16GB DIMMs? If the BIOS works and the RAM too then I'll flash
1 hour ago, SuperMG said:
16GBのDIMMはお持ちですか?BIOSとRAMが動作すれば、フラッシュします。
No, I don't have it. I'm currently checking the sales website.
I haven't flashed the BIOS yet.
