segfault-bilibili2 Posted October 10 Posted October 10 On 10/8/2026 at 7:28 PM, Tetsu said: Thank you for your reply. I have received the BIOS that supports 64GB of RAM. Could you please confirm if the update procedure for this BIOS is the same as that for Prema Mod? Also, could you please explain how to modify the 1394 ID? Will using this BIOS enable support for 64GB of RAM? Additionally, which memory modules should I use? The previous post made by yourself mentioned that P570WM and P570WM3 have different BIOS file names. If you got the file specifically for P570WM3, you must replace IvtQpiandMrcInit module with MMTool. UEFITool might seem to work but according to my experience it failed to boot.
segfault-bilibili2 Posted October 10 Posted October 10 On 7/11/2026 at 12:05 AM, SuperMG said: Hey did you flash? I can't find the P570WM337.PM5 By the way did any of you overclocked the Xeon E5-1680 v2 on this laptop? I'm always stuck at 3.9GHz for one core and 3.8GHz all cores. The temperatures are good and I use 660W PSU. P570WM337.PM5 should be the prema mod for P570WM3, the 3D vision model I think? @Tetsu I can find official BIOS (not prema mod) for both the non-3D-Vision and 3D-Vision model here: https://repo.palkeo.com/clevo-mirror/P570WM/
SuperMG Posted October 10 Author Posted October 10 1 hour ago, segfault-bilibili2 said: P570WM337.PM5 should be the prema mod for P570WM3, the 3D vision model I think? @Tetsu I can find official BIOS (not prema mod) for both the non-3D-Vision and 3D-Vision model here: https://repo.palkeo.com/clevo-mirror/P570WM/ It looks complicated. If you can get the original modder to make an easy english tutorial like my backlight mod cables instructions. Also, why does the Xeon E5-1680 v2 can't be overclocked? I am stuck at 3.8GHz all core and 3.9GHz in single core. It's an unlocked 8 cores CPU. I want to do 4.2GHz one core and 4.1GHz all core. I don't have any thermal throttle. The CPU does max 130W while I set the limits way higher.
Tetsu Posted October 11 Posted October 11 19 hours ago, segfault-bilibili2 said: 以前の投稿で、P570WMとP570WM3ではBIOSファイル名が異なると書かれていましたね。 P570WM3専用のファイルを入手した場合は、IvtQpiandMrcInitモジュールをMMToolに置き換える必要があります。UEFIToolは動作するように見えるかもしれませんが、私の経験では起動に失敗しました。 Thank you for your reply. I checked the files using MMTool and compared the 64GB-compatible BIOS with Prema Mod v5; I found no differences in the source code or GUIDs for the "IvtQpiandMrcInit" project. Could it be that I am checking the wrong area? In the screenshot, the 64GB-compatible BIOS is on the left, and Prema Mod v5 is on the right.
segfault-bilibili2 Posted October 11 Posted October 11 4 hours ago, Tetsu said: Thank you for your reply. I checked the files using MMTool and compared the 64GB-compatible BIOS with Prema Mod v5; I found no differences in the source code or GUIDs for the "IvtQpiandMrcInit" project. Could it be that I am checking the wrong area? In the screenshot, the 64GB-compatible BIOS is on the left, and Prema Mod v5 is on the right. you are comaring the unique IDs (GUID) and sizes (in hexadecimal) of the module between two BIOS files. It's totally normal that these two share exactly the same value, same ID, same size - totally normal and expected. That does NOT mean the content/code is the same. Also, I asked BufferMod and he said 3D-vision model and non-3D-vision model can share one singe prema mod BIOS file.
segfault-bilibili2 Posted October 11 Posted October 11 @Tetsu By the way as we all know 1394 is obsolete tech. If you encountered "1394 GUID missing" error message, I think you may simply disable it in the BIOS settings to get rid of it.
SuperMG Posted October 11 Author Posted October 11 How do we install the BIOS mod then on the P570WM3?
segfault-bilibili2 Posted October 12 Posted October 12 21 hours ago, SuperMG said: How do we install the BIOS mod then on the P570WM3? There should be a in-BIOS update picker if I recalled correctly. Official method to update the BIOS requires MS-DOS environment. You may include the BIOS binary file together with AFUDOS.exe utility into the memdisk image.
SuperMG Posted October 12 Author Posted October 12 5 hours ago, segfault-bilibili2 said: There should be a in-BIOS update picker if I recalled correctly. Official method to update the BIOS requires MS-DOS environment. You may include the BIOS binary file together with AFUDOS.exe utility into the memdisk image. Did you successfully install the BIOS on your P570WM3? I know you have one because before I tried to send you a friend request on Discord about purchasing a P570WM. Can buffermod allow Xeon E5-1680 v2 overclock past 4GHz? I am stuck at 3.8GHz all cores, no matter what I do. The BIOS overclocking doesn't like the 8 cores. Only 6 cores overclocking works like 4.2, 4.5Ghz..
Tetsu Posted October 12 Posted October 12 On 2026/10/11 at 午後6時5分, SuperMG said: それでは、P570WM3にBIOS改造をインストールするにはどうすればいいですか? When I installed the Prema Mod, I used Rufus to create a bootable USB drive (formatted as MS-DOS) and simply copied the BIOS data onto it. Then, I plugged the USB drive into a USB 2.0 port, set the boot order to prioritize that drive, and—after booting up—typed "update" to run the batch file. After that, I simply followed the on-screen instructions. If you have the Prema mod, a readme file is included, so it is a good idea to check it. It contains the update instructions.
Tetsu Posted October 12 Posted October 12 1 minute ago, Tetsu said: Prema Modをインストールする際、Rufusを使って起動可能なUSBドライブ(MS-DOS形式でフォーマット済み)を作成し、そこにBIOSデータをコピーしました。 その後、USBドライブをUSB 2.0ポートに接続し、起動順序をそのドライブを優先するように設定し、起動後に「update」と入力してバッチファイルを実行しました。 その後は、画面の指示に従っただけです。 Prema modをインストールしている場合は、readmeファイルが同梱されているので、確認することをお勧めします。 そこにはアップデート手順が記載されています。 Additionally, the update procedure for the modified BIOS is likely almost the same. After the update, a "1394 GUID error" will likely occur, so a fix will be required.
SuperMG Posted October 12 Author Posted October 12 7 minutes ago, Tetsu said: When I installed the Prema Mod, I used Rufus to create a bootable USB drive (formatted as MS-DOS) and simply copied the BIOS data onto it. Then, I plugged the USB drive into a USB 2.0 port, set the boot order to prioritize that drive, and—after booting up—typed "update" to run the batch file. After that, I simply followed the on-screen instructions. If you have the Prema mod, a readme file is included, so it is a good idea to check it. It contains the update instructions. I already have the Prema mod installed. Did you install the 64GB RAM, PCIE 3.0 patch? Successful?
Tetsu Posted October 12 Posted October 12 1 hour ago, SuperMG said: Prema modは既にインストール済みです。64GB RAM、PCIE 3.0パッチはインストールしましたか?うまくいきましたか? No, I haven't done it yet.
SuperMG Posted October 13 Author Posted October 13 Hello if someone wanna help me about the Xeon E5-1680 v2 overclocking issues: https://notebooktalk.net/topic/3205-clevo-p570wm-cant-overclock-xeon-e5-1680-v2-to-4ghz-and-beyond/#comment-69327
segfault-bilibili2 Posted October 14 Posted October 14 On 10/12/2026 at 8:10 PM, SuperMG said: I already have the Prema mod installed. Did you install the 64GB RAM, PCIE 3.0 patch? Successful? BufferMod said he never released the PCIe 3.0 patched BIOS. Only 64GB memory one is shared. I co-authored the PCIe 3.0 part as well however. If someday I could get a P570WM mainboard to experiment maybe I could try it out myself.
