Blossomcrown Posted May 12 Posted May 12 8 hours ago, SuperMG said: So it's a Prema mod one but modified? Clean ME region? EDP compatible I suppose, it says 120hz on his tweet Im afraid i dont have more detailed info to provide, just uploaded the files "as is". according to BufferMod this bios support 16GB DDR3 SODIMM module.
Blossomcrown Posted May 12 Posted May 12 1 hour ago, Tetsu said: I'm confused because the term "1394 ID" is unfamiliar to me. 1394GUID shoule be something like SN or UUID for your onboard 1394 device, iirc e.g. just like mac address for ethernet card
Tetsu Posted May 12 Posted May 12 6 hours ago, Blossomcrown said: 1394GUIDは、オンボード1394デバイスのSNまたはUUIDのようなものだったはずです(私の記憶が正しければ)。 例えば、イーサネットカードのMACアドレスのようなもの Does the 1394 ID update mean that it supports 64GB of memory? Or should I just run the "update bat" like a regular BIOS update?
Blossomcrown Posted May 12 Posted May 12 1 hour ago, Tetsu said: Does the 1394 ID update mean that it supports 64GB of memory? Or should I just run the "update bat" like a regular BIOS update? no, 1394GUID not related to 64GB memory support. strongly recommended making backup of your original bios before flash this files, in case of anything goes wrong.
Tetsu Posted May 13 Posted May 13 12 hours ago, Blossomcrown said: いいえ、1394GUIDは64GBメモリのサポートとは関係ありません。 万が一問題が発生した場合に備えて、これらのファイルをフラッシュする前に、元のBIOSのバックアップを作成しておくことを強くお勧めします。 Excuse me, but could you please ask Buffermod how to update the BIOS? I've tried contacting them on X (Twitter), but I haven't received a reply.
kela-slk Posted May 14 Posted May 14 Hi. Can anyone share an unlocked BIOS for the P570WM or Prema BIOS? I have a laptop with LVDS, so is the P570WM3 BIOS compatible? With the LVDS version, is it possible to use the master graphics card for image output (like the M1000M as on the Alienware M18X R1), and install an HP RTX5000 on the slave to use Optimus switches to the powerful RTX card in games? Its works on p570wm?
SuperMG Posted May 14 Author Posted May 14 13 minutes ago, kela-slk said: Hi. Can anyone share an unlocked BIOS for the P570WM or Prema BIOS? I have a laptop with LVDS, so is the P570WM3 BIOS compatible? With the LVDS version, is it possible to use the master graphics card for image output (like the M1000M as on the Alienware M18X R1), and install an HP RTX5000 on the slave to use Optimus switches to the powerful RTX card in games? Its works on p570wm? For the GPU: Yes that works but it's better to use AMD HD 7970M/8970M + RTX 5000 with registry edits on regedit. You won't have any TDP issues (issue was: stuck at 70% max). SBIOS depends since there are 2 motherboards revisions for this laptop. LVDS + eDP.
kela-slk Posted May 15 Posted May 15 19 hours ago, SuperMG said: For the GPU: Yes that works but it's better to use AMD HD 7970M/8970M + RTX 5000 with registry edits on regedit. You won't have any TDP issues (issue was: stuck at 70% max). SBIOS depends since there are 2 motherboards revisions for this laptop. LVDS + eDP. Thanks for answering. I have lvds and 2x7970M. Do you have instructions or link , what i need edit in registry. I have tesla p6, have rtx4000, have p5000, have gtx1080 aetina. Can who's can share for me unlocked (modded) bios 1.03.07 for lvds version board?
ssj92 Posted May 15 Posted May 15 5 minutes ago, kela-slk said: Thanks for answering. I have lvds and 2x7970M. Do you have instructions or link , what i need edit in registry. I have tesla p6, have rtx4000, have p5000, have gtx1080 aetina. Can who's can share for me unlocked (modded) bios 1.03.07 for lvds version board? I sent you dual peg and tesla p6 regedit on whatsapp group chat Alienware Area-51M R2 : Intel Core i9-10900K | nVidia GeForce RTX 2080 SUPER Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 Alienware 17 : Intel Core i7 4940MX @ 4.5Ghz | nVidia GeForce RTX 4090 Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 Alienware M18x : Intel Core i7 2960XM @ 4.7Ghz | nVidia Quadro RTX 5000 Alienware M17xR3 : Intel Core i7 2920XM @ 4.7Ghz | nVidia Quadro RTX 5000 Alienware M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000)| Precision M6600 (P4000) | 7520 (T1000) | 7720 (Tesla P6) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
Tetsu Posted May 16 Posted May 16 On 2026/5/12 at 午前9時19分, Blossomcrown said: @SuperMG @Tetsu はい、どうぞ This BIOS is named "P570WM37.PM5," so it should be possible to flash it on a model that does not support 3D Vision. The 3D Vision-compatible model uses "P570WM337.PM5." As a precaution, we recommend backing up your current BIOS before flashing it. Also, because this BIOS supports 64GB, you may encounter the error "1394 GUID are invalid in both CMOS and FLASH" after flashing. If you encounter this error, please refer to the Readme file within the BIOS file for instructions on how to resolve it. As you may know, a failed BIOS rewrite can damage your laptop, so please consider this carefully before proceeding. "We cannot be held responsible for any failures."
SuperMG Posted July 10 Author Posted July 10 On 5/16/2026 at 11:49 AM, Tetsu said: This BIOS is named "P570WM37.PM5," so it should be possible to flash it on a model that does not support 3D Vision. The 3D Vision-compatible model uses "P570WM337.PM5." As a precaution, we recommend backing up your current BIOS before flashing it. Also, because this BIOS supports 64GB, you may encounter the error "1394 GUID are invalid in both CMOS and FLASH" after flashing. If you encounter this error, please refer to the Readme file within the BIOS file for instructions on how to resolve it. As you may know, a failed BIOS rewrite can damage your laptop, so please consider this carefully before proceeding. "We cannot be held responsible for any failures." Hey did you flash? I can't find the P570WM337.PM5 By the way did any of you overclocked the Xeon E5-1680 v2 on this laptop? I'm always stuck at 3.9GHz for one core and 3.8GHz all cores. The temperatures are good and I use 660W PSU.
Tetsu Posted July 12 Posted July 12 On 2026/7/11 at 午前1時5分, SuperMG said: ねえ、フラッシュした?P570WM337.PM5が見つからないんだけど。 ところで、このノートパソコンに搭載されているXeon E5-1680 v2をオーバークロックした方はいますか? 1コア動作時は常に3.9GHz、全コア動作時は常に3.8GHzで止まってしまいます。 温度は良好で、660Wの電源ユニットを使用しています。 Hello. No, I haven't flashed it yet either. If you flash "P570WM37.PM5" onto a 3D-capable model, I believe brightness adjustment stops working. It seems likely that this BIOS is a modified version of the one intended for LVDS displays. Also, if I do decide to flash it, I’d like to get hold of 16GB DDR3 modules before giving it a try.
Tetsu Posted July 12 Posted July 12 I haven't even managed to buy an RTX 4090 from ZRT yet, and now X-vision has gone and released an RTX 5000 series MXM card 😢 Do the RTX 4090 cards from ZRT and X-vision fail to work due to VBIOS issues?
SuperMG Posted July 12 Author Posted July 12 7 hours ago, Tetsu said: I haven't even managed to buy an RTX 4090 from ZRT yet, and now X-vision has gone and released an RTX 5000 series MXM card 😢 Do the RTX 4090 cards from ZRT and X-vision fail to work due to VBIOS issues? Yes, you need to do the EDID override, you'll lose the DP port on your laptop (DP_B) I don't know if you read the threads or not. But the ZRT VBIOS is like the Max-Q of X-VSION ones. They have the same DCB. So no need to get the zrt one if they don't answer. However I have a RTX 4080 MXM for sale.
