GuitarG Posted June 7 Author Posted June 7 Little upgrade, after dissasembly of panel I put some thermal pad for big IC of DC board - I cut out plastic foil between lid and IC. Now panels seems to be cold, previously it was very hot to touch (especially on lower bezel). Will test more with higher brightness, but seems to help somewhat - I though previously that RGB backlight of DC screen was scorching. 1
MODDER1 Posted July 8 Posted July 8 Hello All, crazy stuff on this thread and tremendous work by everybody, insane amount of informations, so a big thank you first! Second, i'm very new (n00b) to modding, and i got a 8570w also (gift) since 2-3 years, and from what i read, we can do a lot of upgrade with this elitebook, and since day one, i really wanted to push this beast to a build with a lot of potential. For now, i just updated the stockage to a SSD kingston, replace the heatsink (the laptop was overheating everytime with slightiest use) by the a spare one, and still dealing with the original cpu and gpu (quadro k2000m). I will definitly upgrade the CPU with the Core i7-3940XM (pretty simple task) but then come the gpu part, and all the mods il will have to do. I saw that @Daedalus had the same desire regarding his 8570w, did you manage to finally install a 980m on it ?
Daedalus Posted July 17 Posted July 17 On 7/8/2026 at 7:04 PM, MODDER1 said: Hello All, crazy stuff on this thread and tremendous work by everybody, insane amount of informations, so a big thank you first! Second, i'm very new (n00b) to modding, and i got a 8570w also (gift) since 2-3 years, and from what i read, we can do a lot of upgrade with this elitebook, and since day one, i really wanted to push this beast to a build with a lot of potential. For now, i just updated the stockage to a SSD kingston, replace the heatsink (the laptop was overheating everytime with slightiest use) by the a spare one, and still dealing with the original cpu and gpu (quadro k2000m). I will definitly upgrade the CPU with the Core i7-3940XM (pretty simple task) but then come the gpu part, and all the mods il will have to do. I saw that @Daedalus had the same desire regarding his 8570w, did you manage to finally install a 980m on it ? Welcome MODDER1, good to see your on the similar journey. SSD's definitely help the machine catchup to newer generations. Currently running 1TB samsung Sata SSD in mine with a 500gb Msata secondary drive. i do run the i7-3940XM CPU with my current k1000M GPU. I have the 980M SLI (same as KBX on here) card ready to go in, but am currently working on Chassis mods to allow dual fans (980M is a hot beast) to get the heat away so not yet running the card (KBX has his running and working on 1070M). The 980M mod requires the 8770W sink mod as its a "B" card and 8570W only ever shipped with "A" cards from HP, so to go 980M or any more powerful card you'll be collecting alot of parts 🙂 The 980M is the best you'll get without dreamcolour screens, others on this post have DC screens and have done more awesome mods and more powerful cards. HP Elitebook 8570w - i7-3940XM / 32GB HyperX 1866 (fake) / 1TB Samsung Evo / 512gb Kingston Msata / K1000m (to be 980M)
MODDER1 Posted July 19 Posted July 19 Happy to hear from you @Daedalus! On 7/17/2026 at 3:00 PM, Daedalus said: Currently running 1TB samsung Sata SSD in mine with a 500gb Msata secondary drive Truuue, mine is also going faster (booting, lauching app, etc). On 7/17/2026 at 3:00 PM, Daedalus said: The 980M mod requires the 8770W sink mod as its a "B" card and 8570W only ever shipped with "A" cards from HP, so to go 980M or any more powerful card you'll be collecting alot of parts 🙂 Yep! I was thinking about doing a modded heatsink with a copper plate (5mm), and then soldering the stock copper heatpipes on it , for better cooling on these type B cards. On 7/17/2026 at 3:00 PM, Daedalus said: The 980M is the best you'll get without dreamcolour screens, others on this post have DC screens and have done more awesome mods and more powerful cards. exactly, with the DC being a rare pokemon, i was also thinking about installing a new standard eDP screen on my 8570w, but i know its still not fully resolved on the forum (modded cable vs nvidia drivers vs screen whitelist vs etc, ahah), and then go for and test the newest RTX cards.
Daedalus Posted July 21 Posted July 21 Full copper GPU sink would be the way to go. Ive seen some machined ones, but never any OEM. They seem to like the Alu / berylium things we see in our machines, which are a pig to use LMP solder too. A couple of my heatsinks dissasembled at points i didnt want to undo before the point i needed came apart. KBX is working on a 1070m but hes hitting DC issues too, card works but only via DP. That said his H/sink is different to the 980M as chip heights so i dont know if there is another plate available, unless you scour Ali/Google for a 1070 sink from another manafacturer and decouple the GPU. 9xx is best for 8570W / 8770W ( well was in OEM spec) our crazy minds have gone a little bit further than that here HP Elitebook 8570w - i7-3940XM / 32GB HyperX 1866 (fake) / 1TB Samsung Evo / 512gb Kingston Msata / K1000m (to be 980M)
JadeRover Posted July 21 Posted July 21 20 minutes ago, Daedalus said: KBX is working on a 1070m but hes hitting DC issues too, card works but only via DP That is due to a vbios mismatch with the mxm slot regarding eDP placement on the 8570w. What he needs is a custom vbios that has eDP on DP_C position of the card as that's where it is located on the mxm slot of the laptop. Most laptops have eDP on position DP_D of the mxm slot so most vbios have it set to that. He can use this Macrumors vbios for 1070m that has eDP on DP_C (that luckily exists) : https://forums.macrumors.com/threads/imac-2011-maxwell-and-pascal-gpu-upgrade.2300989/page-10?post=30799977#post-30799977 I discovered this when my p3000 worked with the internal display of my zbook 17 g3 (eDP on position DP_C) once I used another "Mac compatible" vbios Precision M6700 : i7-3740QM | P3000 6gb engineering vbios | 20gb DDR3 1600Mhz | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | M3000m 4gb | 16gb DDR4 2400Mhz | FHD ips Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 3011Mhz | 1440p165hz (upgrad) Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 2666Mhz | FHD IPS
Daedalus Posted July 22 Posted July 22 @JadeRover so if i understand/read that correctly, that Vbios build makes 1070M work on a Non-DC enabled 8570W? cool news if it does. hadnt stumbled on that post before i got my 980M (d'oh) time to search for a 1070M then 😉 for the next upgrade stage. Until the cable saga is resolved the RTX cards will have to wait. HP Elitebook 8570w - i7-3940XM / 32GB HyperX 1866 (fake) / 1TB Samsung Evo / 512gb Kingston Msata / K1000m (to be 980M)
JadeRover Posted July 22 Posted July 22 2 hours ago, Daedalus said: so if i understand/read that correctly, that Vbios build makes 1070M work on a Non-DC enabled 8570W? Unfortunately no, since non DC screen go through the LVDS port of the gpu and all pascal cards and above (including 1070m) don't have LVDS pins, no vbios can fix that. What it should do is make the 1070m work on DC screen since it wasn't possible before due to eDP placement mismatch in vbios. The 8570w doesn't use integrated graphics and the internal lcd goes directly to the dGPU if I am not mistaken. Precision M6700 : i7-3740QM | P3000 6gb engineering vbios | 20gb DDR3 1600Mhz | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | M3000m 4gb | 16gb DDR4 2400Mhz | FHD ips Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 3011Mhz | 1440p165hz (upgrad) Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 2666Mhz | FHD IPS
KbX Posted July 22 Posted July 22 Hi! Unfortunately, my hardware ID for the 1070 is DEV_1BE1, and I noticed in the Nvidia settings that I could choose some options for G-Sync. I don't have enough experience with BIOS to freely change and modify it, but I believe it works with other laptops and older versions that have LVDS communication. My GTX 1070 works via DP but not via VGA connector, which leads me to think that the problem is the screen which is from the time when VGA was used. When i connect the external VGA display, it detects but remains black... I have to ask a friend of mine who has a computer store if he has experience with GPU BIOS and also if he has a recent 40-pin laptop screen to try before buying one, risking it not working. The heatsink for the GTX 1070 will be easier because it has all the memories on the top side, different from the 980 which has on both sides. I'm Portuguese and for now i have to enjoy summer, we don't know when Russia will use a bomb under the sea to flood and drown us all. I don't believe Nvidia made a driver for this hardware combination. Note that Nvidia released the last official driver for GTX which greatly increases performance in newer games and dx12. Note that this CPU does not have AVX2. More and more recent games require this. It won't be worth having an RTX in this laptop because some games won't open because of the 3940xm.
MODDER1 Posted July 22 Posted July 22 Hi! 5 hours ago, KbX said: Note that this CPU does not have AVX2. More and more recent games require this. It won't be worth having an RTX in this laptop because some games won't open because of the 3940xm. That's interesting, it makes sense. We definitely have some limits with these machine. 6 hours ago, KbX said: I have to ask a friend of mine who has a computer store if he has experience with GPU BIOS and also if he has a recent 40-pin laptop screen to try before buying one, risking it not working. That would be great. 6 hours ago, KbX said: The heatsink for the GTX 1070 will be easier because it has all the memories on the top side, different from the 980 which has on both sides. I forgot about this. What are the solutions on the 980? using PTM7950 with another copper plate...or maybe not install it at all ahah.
JadeRover Posted July 22 Posted July 22 I checked again on the 8570w boardview and the LCD connector is wirred to DP_D of the MXM slot : Meaning no need for vbios mod I was wrong. If you have DC screen evey GPU with eDP support should work. What is the problem with 1070m @KbX ? no image ? Precision M6700 : i7-3740QM | P3000 6gb engineering vbios | 20gb DDR3 1600Mhz | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | M3000m 4gb | 16gb DDR4 2400Mhz | FHD ips Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 3011Mhz | 1440p165hz (upgrad) Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 2666Mhz | FHD IPS
Daedalus Posted July 27 Posted July 27 On 7/22/2026 at 10:40 PM, JadeRover said: I checked again on the 8570w boardview and the LCD connector is wirred to DP_D of the MXM slot : Meaning no need for vbios mod I was wrong. If you have DC screen evey GPU with eDP support should work. What is the problem with 1070m @KbX ? no image ? Maybe I'm thinking about this wrong (wouldnt be the first) but if one was good enough at micro soldering and cut the right traces couldnt we make the cables were trying to build work at the board level? i mean its alot of work, but a question is free...... HP Elitebook 8570w - i7-3940XM / 32GB HyperX 1866 (fake) / 1TB Samsung Evo / 512gb Kingston Msata / K1000m (to be 980M)
JadeRover Posted July 28 Posted July 28 On 7/27/2026 at 11:56 AM, Daedalus said: Maybe I'm thinking about this wrong (wouldnt be the first) but if one was good enough at micro soldering and cut the right traces couldnt we make the cables were trying to build work at the board level? i mean its alot of work, but a question is free...... Honestly no, we would need a board level rewiring to make the eDP from motherboard use DP_D position on mxm slot. Not viable in my opinion. What is viable however is to do a backlight mod, meaning you have to use an MXM gpu with regular DP (display port) on DP_C position. Then use a backlight v2 mod cable to get an image on the internal lcd. There's still a problem with windows drivers but that can be fixed as well. This is by far the best method and the mod cable is easy to install with no soldering. Precision M6700 : i7-3740QM | P3000 6gb engineering vbios | 20gb DDR3 1600Mhz | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | M3000m 4gb | 16gb DDR4 2400Mhz | FHD ips Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 3011Mhz | 1440p165hz (upgrad) Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 2666Mhz | FHD IPS
Daedalus Posted July 29 Posted July 29 20 hours ago, JadeRover said: Honestly no, we would need a board level rewiring to make the eDP from motherboard use DP_D position on mxm slot. Not viable in my opinion. What is viable however is to do a backlight mod, meaning you have to use an MXM gpu with regular DP (display port) on DP_C position. Then use a backlight v2 mod cable to get an image on the internal lcd. There's still a problem with windows drivers but that can be fixed as well. This is by far the best method and the mod cable is easy to install with no soldering. That backlight mod would still limit card options no? current non-DC screens have a 980M limit. if the backlight mod allows greater / newer options then that could give a pathway. HP Elitebook 8570w - i7-3940XM / 32GB HyperX 1866 (fake) / 1TB Samsung Evo / 512gb Kingston Msata / K1000m (to be 980M)
SuperMG Posted July 29 Posted July 29 15 minutes ago, Daedalus said: That backlight mod would still limit card options no? current non-DC screens have a 980M limit. if the backlight mod allows greater / newer options then that could give a pathway. What?? That'll never limit. Only iGPU SG limits your performance
JadeRover Posted July 29 Posted July 29 52 minutes ago, Daedalus said: current non-DC screens have a 980M limit. Correct, that's because there is no mux switch and non DC screen = LVDS lcd and the newest and fastest card that supports LVDS video signal is 980m. After maxwell generation Nvidia dropped support for LVDS. Therefore you would need a DC screen to upgrade to newer cards + backlight mods. Parts : - DC screen and cable - newer gpu - backlight cable mod Alternatively you can get someone to build a custom lcd cable to connect the lcd connector of the motherboard to any modern 30/40 pin edp display. Parts would be : - custom edp cable - standard laptop eDP display - new GPU - backlight mod cable Getting a custom edp cable has been done before, on taobao it is possible to order some custom ones based on the laptop lcd connector. Precision M6700 : i7-3740QM | P3000 6gb engineering vbios | 20gb DDR3 1600Mhz | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | M3000m 4gb | 16gb DDR4 2400Mhz | FHD ips Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 3011Mhz | 1440p165hz (upgrad) Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 2666Mhz | FHD IPS
MODDER1 Posted Sunday at 04:20 PM Posted Sunday at 04:20 PM On 4/21/2026 at 11:28 AM, Daedalus said: once i have that it will be multiple to take either heat from CPU/GPU sources. intake will be via hole in DVD Bay chassis and a custom access panel vent then exhaust out a DVD drive cover with vent holes. Also looking at custom GPU spiders as 980M has VRAM underneath which doesnt connect to spider to remove heat, just the copper pads on the Mobo. Will share designs / parts used etc so anyone on here can duplicate as required. Hi @Daedalus, did you make any progress regarding the design/part used? I started to really think on the second fan and cooling system mod, by dedicating a copper plate to GPU with it's own fan & pipes.
Daedalus Posted Monday at 08:17 AM Posted Monday at 08:17 AM 19 hours ago, MODDER1 said: Hi @Daedalus, did you make any progress regarding the design/part used? I started to really think on the second fan and cooling system mod, by dedicating a copper plate to GPU with it's own fan & pipes. Hey, Still working on the Access panel vent so the 2nd fan can pull air, but at present its a Type H (fits 470 thru to 590) copper plate (0.5mm thick) from Ali i'm modifying to sit under the card with Upsiren putty to try and clamp via spider (you'll need longer spider too for this) so heat is shared back into the main heatsink. It aint perfect as bolt holes need widening, but its better than hoping the PCB will dissipate heat. will need to Kapton tape the underside to minimise short risk too. But thats the idea im running with at the moment unless anyone has managed a better fix. will find the link and re-edit post shortly https://a.aliexpress.com/_Ewz3iIS is the part I’m modifying as an off the shelf solution (ish) its an evolution of the copper plate that KBX did on his 980M install but trying to keep as an sandwich assembly (hopefully it wont foul the DVD port too, although i suspect it will, so DVD port will require a trim ) HP Elitebook 8570w - i7-3940XM / 32GB HyperX 1866 (fake) / 1TB Samsung Evo / 512gb Kingston Msata / K1000m (to be 980M)
MODDER1 Posted Wednesday at 09:02 PM Posted Wednesday at 09:02 PM On 8/3/2026 at 10:17 AM, Daedalus said: is the part I’m modifying as an off the shelf solution (ish) its an evolution of the copper plate that KBX did on his 980M install but trying to keep as an sandwich assembly (hopefully it wont foul the DVD port too, although i suspect it will, so DVD port will require a trim ) yep the sandwich thing, that's the way with a 980M. But in any case, i think the DVD port need a trim right? If not, the card will sit on it. From my side, i have two spare heatsink, will try to get it separate for the two cards, CPU cooling with 2 pipes and his fan & same for GPU, looking for high performance heat pipes. Waiting for all the material. And for the memory under the card, another copper plate in fact, or some little thin sheets should help, connected to the main heatsink, and its perfect.
Daedalus Posted Wednesday at 10:08 PM Posted Wednesday at 10:08 PM 1 hour ago, MODDER1 said: yep the sandwich thing, that's the way with a 980M. But in any case, i think the DVD port need a trim right? If not, the card will sit on it. From my side, i have two spare heatsink, will try to get it separate for the two cards, CPU cooling with 2 pipes and his fan & same for GPU, looking for high performance heat pipes. Waiting for all the material. And for the memory under the card, another copper plate in fact, or some little thin sheets should help, connected to the main heatsink, and its perfect. Yeah I think the sandwich creation is sensible. Although had a (stupid idea) top of 980m cooled by main 8770w sink, and under side cooled by second fan and heat pipe, but they are held together by spider, so allows cooling assembly as two part. there are copper heatsinks for memory on Ali too I noticed so I may try them. Also plan to cool north bridge whilst I’m creating a monster i now have three 8570w sinks in various states of removed parts to work out what fits and can be used in different locations HP Elitebook 8570w - i7-3940XM / 32GB HyperX 1866 (fake) / 1TB Samsung Evo / 512gb Kingston Msata / K1000m (to be 980M)
MODDER1 Posted yesterday at 12:38 PM Posted yesterday at 12:38 PM 14 hours ago, Daedalus said: i now have three 8570w sinks in various states of removed parts to work out what fits and can be used in different locations This is good! 14 hours ago, Daedalus said: there are copper heatsinks for memory on Ali too I noticed so I may try them. Also plan to cool north bridge whilst I’m creating a monster Yep i saw it. I don't know about underneath, but for the memory on top, it could be very good, much better heat transfert in theory
Daedalus Posted 23 hours ago Posted 23 hours ago 16 minutes ago, MODDER1 said: This is good! Yep i saw it. I don't know about underneath, but for the memory on top, it could be very good, much better heat transfert in theory as they are two slots it will be the thin copper sinks, removal of the stickers to maximise contact, underneath set will fair better as they are side by side and have a vent on access door. under keyboard may suffer higher temps. HP Elitebook 8570w - i7-3940XM / 32GB HyperX 1866 (fake) / 1TB Samsung Evo / 512gb Kingston Msata / K1000m (to be 980M)
