Daedalus Posted September 18 Posted September 18 Noooo, thats not good news. was yours a 980M?? Were all "hot" chips cooled ok? the copper plate is flat (obviously) whereas the aluminium 8770W one has recesses to cater for different heights. (i'm looking at full copper but got to wait until my slide table turns up so i can convert my drillpress into a milling machine arrives, so its the 8770W sink until then) i assume the GPU core wasnt contacting the sink as if i recall VRAM is a tiny bit higher off the PCB (i could be wrong, i used the thicker blue heat pads which squish a bit more, although i may change to upsiren paste next) this is the issue i found when creating an "undercooler plate" for the 980M VRAM on the other (under)side of the PCB that sit next to Mobo and dont get cooled enough. was your card a "low mileage" one? might have been slowly dying and the mod pushed it over the edge. However we learn and upgrade. Will share the underplate on here shortly once i get a chance to take a pic this weekend (if it works i'll convert into a printable template). HP Elitebook 8570w - i7-3940XM / 32GB HyperX 1866 (fake) / 1TB Samsung Evo / 512gb Kingston Msata / K1000m (to be 980M)
MODDER1 Posted September 18 Posted September 18 On 9/14/2026 at 10:50 PM, Vladka76 said: It would probably be best to realign the heatpipe(s) using a non-functional, "dummy" graphics card?.. true! but how tho? i would need the mobo at the same time i think HP Elitebook 8570w / i7 intel 3740QM / GTX 980M 8GB / 16 GB RAM 1600Mhz stock / Double FAN Cooling
Vladka76 Posted September 18 Posted September 18 2 hours ago, MODDER1 said: i would need the mobo at the same time i think Of course. hp EliteBook 8770w: i7-3840QM | M3000m 4Gb | 16Gb DDR3L 1866Mhz (2 pcs original Kingston HX318LS11IB/8)
MODDER1 Posted September 18 Posted September 18 13 hours ago, Daedalus said: Noooo, thats not good news. was yours a 980M?? Yes unfortunately🥹 13 hours ago, Daedalus said: Were all "hot" chips cooled ok? I would say yes, as i'm using thermal pads with different thickness so everybody can access the plate. 13 hours ago, Daedalus said: was your card a "low mileage" one? might have been slowly dying and the mod pushed it over the edge. However we learn and upgrade. Could be if being honest, but the general state of the card was and is good actually, but yeah GPU are not like RAM for examples that lives forever ahah Still on test to understand the issue, will try tomorow HP Elitebook 8570w / i7 intel 3740QM / GTX 980M 8GB / 16 GB RAM 1600Mhz stock / Double FAN Cooling
Daedalus Posted September 21 Posted September 21 On 9/18/2026 at 8:38 PM, MODDER1 said: true! but how tho? i would need the mobo at the same time i think this is why i now have a junker dual core 8570W (only difference is no RAM slot 1&3 under keyboard from what i can see) in a half chassis for my heatsink work, all i need are CPU and GPU bolt points to align. i can prep all i need without killing anything (fingers crossed) plus i can mod the chassis for cooling and swap items across as proven. no spare 980m though (eek) HP Elitebook 8570w - i7-3940XM / 32GB HyperX 1866 (fake) / 1TB Samsung Evo / 512gb Kingston Msata / K1000m (to be 980M)
MODDER1 Posted September 22 Posted September 22 Update: i ran the mods MATS test, and seems like memories still good, it was a flawless PASS; still need to put the card under charge to see if it works normally; and ow i did flash a new VBIOS on it (MSI techpowerup) via NVFLASHK, was a success and the card is working fine, but i think i will need to do some additional tests to be sure of everything Little Update on PSU side: for the little story, i did buy a 230W PSU for the workstation, but it was not recognize by the Laptop, because it did not have the special Pin that allow the PSU to charge the laptop. So had to mod it, with the use of 100K ohm resitor to close the circuit, cut the charging cable from the original HP PSU, solder it on the new generic one (V+ & GND), and solder the Pin (central tiny cable) with a resistor to the V+ cable of the generic PSU, and just like that, i have a working 230W PSU working fine. Maybe it can help someone here, we never know. HP Elitebook 8570w / i7 intel 3740QM / GTX 980M 8GB / 16 GB RAM 1600Mhz stock / Double FAN Cooling
Vladka76 Posted September 22 Posted September 22 8 hours ago, MODDER1 said: i ran the mods MATS test, and seems like memories still good, it was a flawless PASS Congratulations, but how long did the test take? 🙂 A couple of minutes?.. If so, that’s not quite right - these tests are often configured to check only 10–20% of the total video memory (or a specific fixed small amount). That might be enough in case of a death of single memory chip, but for more complex issues, I strongly recommend to let the GPU warm up well during the long full test. To enable a full test, you need to open the MATS configuration file named 'runmats' for editing - and locate the line at the very end that calls the MATS program; it look something like this: "$LOCATION/$PKGNAME/mats" -e 20 (check only 20 Mb of VRAM) or "$LOCATION/$PKGNAME/mats" -c 10 (check only 10 percent of VRAM) ...and delete any symbols after 'mats"'. 🙂 Or you may comment non-modified line with symbols '#' and a following ' ', both placed in the beginning, and a add new one with a call of MATS without arguments. And you may wish to add as the last line of this file the command: poweroff Then your PC will be auto powered off shortly after end of check (it's very useful in case of long test caused huge size of VRAM). The results will be written into text .log file placed in the same directory. Enjoy. 😉 hp EliteBook 8770w: i7-3840QM | M3000m 4Gb | 16Gb DDR3L 1866Mhz (2 pcs original Kingston HX318LS11IB/8)
MODDER1 Posted September 25 Posted September 25 Hi @Vladka76, thanks for the guidance, i will definitly run back this Test with parameter you said. In fact the test was not so long, then i think it's as you say, it did not test everything like it should have for this type of problem. Thanks a lot and good luck to me! HP Elitebook 8570w / i7 intel 3740QM / GTX 980M 8GB / 16 GB RAM 1600Mhz stock / Double FAN Cooling
Daedalus Posted September 26 Posted September 26 On 9/25/2026 at 7:53 PM, MODDER1 said: Hi @Vladka76, thanks for the guidance, i will definitly run back this Test with parameter you said. In fact the test was not so long, then i think it's as you say, it did not test everything like it should have for this type of problem. Thanks a lot and good luck to me! If it’s a dry joint/heat related short the longer test will show it up. maybe a heat gun operation if chips are good. HP Elitebook 8570w - i7-3940XM / 32GB HyperX 1866 (fake) / 1TB Samsung Evo / 512gb Kingston Msata / K1000m (to be 980M)
MODDER1 Posted September 27 Posted September 27 20 hours ago, Daedalus said: If it’s a dry joint/heat related short the longer test will show it up. Yup! Update: did another test today (8192mb) for the entire memory, about 2+ hours of running, and the result is PASS, with no anomaly nowhere, so it means the memory are good i would say. Like i said, i also changed the Vbios, and did run two unigine heaven today, for some long minutes (until the throttle), and no artefact. I will continue to test, but i will say there is maybe an Hope that the card still good.🥹 1 HP Elitebook 8570w / i7 intel 3740QM / GTX 980M 8GB / 16 GB RAM 1600Mhz stock / Double FAN Cooling
Daedalus Posted September 29 Posted September 29 Thats good to hear your test proved a pass, so it seems to align the card is good. Definitely review your cooling solution as this may have been a bit tooo close a call to failure. Happy to measure my 8770W "half plate" GPU sink if you need heights verified. That will work for a 980M but not anything newer, if i recall @KbX has a 1070M in his (but suffers display output options) not sure if hes evolved his heatsink since. Can anyone advise if the 1080M has been tried, not sure why we stopped at 1070m as i saw one which didnt have the PSU plug so it must be downclocked to run via MXM slot. HP Elitebook 8570w - i7-3940XM / 32GB HyperX 1866 (fake) / 1TB Samsung Evo / 512gb Kingston Msata / K1000m (to be 980M)
K4sum1 Posted September 29 Posted September 29 On 9/7/2023 at 2:34 AM, GuitarG said: You can use almost any 1,8v bios chips like W25Q20E or W25Q40EW or MX25U8033E. Just program vbios from my thread on this forum with zip file, solder it on with soldering iron, voila! All those Dell vbios works pretty much same, I didn't saw any difference. If I were to try to do this myself, what are the differences between the revisions? Currently the only local one is Rev A for me, and also kinda pricy so I'm wanting to keep a lookout. Maybe only buy after AI bubble pop idk. On 3/7/2023 at 8:34 AM, GuitarG said: I had also though about RTX Quadro, model 5000, but there is not even one on auction site in my location. Also full height cards have different mounting points. I'm wanting to do something maybe stupid. I'd like to get the HP ZBook 17 G6 for the 8c16t CPU over the 6c12t 17 G5, but get a P5200 for it because the RTX 5000 is near unobtainium, and the difference in performance is not that great in the types of games I want to play. I've also heard Pascal cards play better with older games than the later gens, and idk if it was because my 2080 Ti was dying, but after it died and I had to put a 1080 in my desktop, it's been a better experience overall aside from worse perf. So I would prefer a Pascal card over the Turing card. (I lean a bit more towards yolo and just getting one because I could just put it in my 8770W worst case, and just use the DP out and whatever as a desktop replacement, but I'd rather have it in the new laptop.) Both are MXM, so how different are they? Could I fit a P5200 in a 17 G6? Precision M4800 - i7 4810MQ, 32GB RAM, Nvidia Quadro M2200 Thinkpad T430 - i7 3630QM, 16GB RAM, Intel HD 4000, 1080p display mod Main PC - AMD Ryzen 9 5950X, 64GB RAM, RTX 2080 Ti
JadeRover Posted September 30 Posted September 30 The RTX 5000 MXM from HP has different mounting holes for the heatstink + screw standoffs to attach the card to the motherboard, this is compared to the standard MXM cards. If you want to fit a P5200 in the 17 G6 you will need the heatsink from the 17 G5, and vice versa if you want the RTX 5000 in the 17 G5. You will also have to grind down the screw standoffs on the 17 G6 motherboard and either : - stick some thick rubber pad and screw the card down on that. - stick some thick thermal pad so that the card "sticks" to the motherboard via the pad + cools down a little bit (especially the extra VRAM chips on the bottom of the card) Hope this helps ! Precision M6700 : i7-3740QM | P3000 6gb engineering vbios | 20gb DDR3 1600Mhz | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | M3000m 4gb | 16gb DDR4 2400Mhz | FHD ips Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 3011Mhz | 1440p165hz (upgrad) Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 2666Mhz | FHD IPS
Daedalus Posted September 30 Posted September 30 if i recall (i think it was GuitarG) put the P5200 in his 8570/8770 unit, i think theres a YT vid on it, But is amazing the p5200 runs in an older unit as it does alot of the heavy lifting for games usage. Again not sure if the newer G5/G6 need a DC screen for them to work. HP Elitebook 8570w - i7-3940XM / 32GB HyperX 1866 (fake) / 1TB Samsung Evo / 512gb Kingston Msata / K1000m (to be 980M)
JadeRover Posted September 30 Posted September 30 1 hour ago, Daedalus said: Again not sure if the newer G5/G6 need a DC screen for them to work They do not, that was the case on 8570 and 8770 G5 and G6 (probably G4 too) have eDP on DP_D position of MXM slot, G1, G2 and G3 have eDP on DP_C so either a custom vbios is required to get picture on screen or a backlight cable mod. All zbooks have only eDP display connections. 17 g1 and 17 g2 have an eDP to LVDS converter on the display cable because they used LVDS displays, the GPU will read the display as eDP however. 1 Precision M6700 : i7-3740QM | P3000 6gb engineering vbios | 20gb DDR3 1600Mhz | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | M3000m 4gb | 16gb DDR4 2400Mhz | FHD ips Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 3011Mhz | 1440p165hz (upgrad) Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 2666Mhz | FHD IPS
K4sum1 Posted October 4 Posted October 4 After doing some research, it appears the cheapest way for me to get a P5200 will be to wait for a good deal on a ZBook 17 G5 with a P5200 to come. These models also appear to exclusively come with the highest end CPU that the 17 G5 came with, the Xeon E-2186M. This CPU outperforms the G6's 9850H all around, and is better than the 9980H in single thread. The only all around better CPU for the G6 would be the E-2286M. So I would need to get the highest end 17 G5, and then probably the highest end or close to it 17 G6. It would be cool to have both, but that is a bit steep for what I want and I would have a mid-high end RTX card of some sort and nothing to do with it. So I may just get a 17 G5 with the 2186M and P5200 when one pops up. Precision M4800 - i7 4810MQ, 32GB RAM, Nvidia Quadro M2200 Thinkpad T430 - i7 3630QM, 16GB RAM, Intel HD 4000, 1080p display mod Main PC - AMD Ryzen 9 5950X, 64GB RAM, RTX 2080 Ti
SuperMG Posted October 4 Posted October 4 46 minutes ago, K4sum1 said: After doing some research, it appears the cheapest way for me to get a P5200 will be to wait for a good deal on a ZBook 17 G5 with a P5200 to come. These models also appear to exclusively come with the highest end CPU that the 17 G5 came with, the Xeon E-2186M. This CPU outperforms the G6's 9850H all around, and is better than the 9980H in single thread. The only all around better CPU for the G6 would be the E-2286M. So I would need to get the highest end 17 G5, and then probably the highest end or close to it 17 G6. It would be cool to have both, but that is a bit steep for what I want and I would have a mid-high end RTX card of some sort and nothing to do with it. So I may just get a 17 G5 with the 2186M and P5200 when one pops up. The 8850 and 9850H have +400MHz turbo bins on all cores unlike the 9750H and 9980H so you do end up with a faster single thread at the end.
K4sum1 Posted October 4 Posted October 4 1 hour ago, SuperMG said: The 8850 and 9850H have +400MHz turbo bins on all cores unlike the 9750H and 9980H so you do end up with a faster single thread at the end. Well when I looked it up, I used passmark cpubench to easily compare them all side by side, and the top single thread performers were the 2186M and the 2286M. I may also see about ECC or other features idk, but I think going for the Xeon is a no brainer. Precision M4800 - i7 4810MQ, 32GB RAM, Nvidia Quadro M2200 Thinkpad T430 - i7 3630QM, 16GB RAM, Intel HD 4000, 1080p display mod Main PC - AMD Ryzen 9 5950X, 64GB RAM, RTX 2080 Ti
SuperMG Posted October 4 Posted October 4 1 hour ago, K4sum1 said: Well when I looked it up, I used passmark cpubench to easily compare them all side by side, and the top single thread performers were the 2186M and the 2286M. I may also see about ECC or other features idk, but I think going for the Xeon is a no brainer. Xeon is a locked multiplier, you can undervolt like the 9850H. A 4070 MXM would be a perfect match for the Xeon variants. I have one if interested.
K4sum1 Posted October 4 Posted October 4 4 minutes ago, SuperMG said: Xeon is a locked multiplier Aren't they all locked though? Therefore Xeon at 4.8 or 5.0 would be highest? 5 minutes ago, SuperMG said: I have one if interested. As in the 17 G5/G6 with Xeon? Precision M4800 - i7 4810MQ, 32GB RAM, Nvidia Quadro M2200 Thinkpad T430 - i7 3630QM, 16GB RAM, Intel HD 4000, 1080p display mod Main PC - AMD Ryzen 9 5950X, 64GB RAM, RTX 2080 Ti
SuperMG Posted October 4 Posted October 4 8 minutes ago, K4sum1 said: Aren't they all locked though? Therefore Xeon at 4.8 or 5.0 would be highest? As in the 17 G5/G6 with Xeon? Yes all the Xeon, 8750H, 9750H, 9980H have all locked multipliers. No turbo bins. Yes the RTX 4070 MXM is available from me and it works in my I7 9750H G6 17 system.
K4sum1 Posted October 4 Posted October 4 I listed reasons for wanting P5200, I won't be taking a 4070 lol. Precision M4800 - i7 4810MQ, 32GB RAM, Nvidia Quadro M2200 Thinkpad T430 - i7 3630QM, 16GB RAM, Intel HD 4000, 1080p display mod Main PC - AMD Ryzen 9 5950X, 64GB RAM, RTX 2080 Ti
SuperMG Posted October 4 Posted October 4 Just now, K4sum1 said: I listed reasons for wanting P5200, I won't be taking a 4070 lol. Damn no one wants my 4070 bruh
gingerswordsmith Posted October 7 Posted October 7 Hello everyone, I am planning a GPU upgrade on my HP EliteBook 8570w and am looking for assistance with a custom VBIOS patch to bypass the HP whitelist and ensure proper display initialization. I am upgrading from a working Nvidia Quadro K2000M to a Dell-sourced AMD FirePro M5100. Using a CH341B hardware programmer and NeoProgrammer, I have successfully extracted and verified a clean dump of the card's factory VBIOS (it is confirmed to have SK Hynix VRAM, and the internal string shows BR46584.001.FGL VENUS). I have attached this raw .bin file to this post, as I understand it is usually safer to custom patch the card's original firmware rather than flashing a generic file. Here are my exact host system specifications: Host System: HP EliteBook 8570w System Board ID: 176B HP System BIOS Version: 68IAV Ver. F.43 Boot Mode: Pure UEFI (Native) Internal Display Panel: Standard FHD 8-bit LVDS Panel (LG Philips LP156WF1 - Non-DreamColor) Target OS Setup: Dual-booting Windows 10 and Debian 12 Could someone please help modify my attached original VBIOS with the proper subsystem IDs and ACPI adjustments to work cleanly with my 176B motherboard and standard LVDS display? Thank you so much for your time and expertise! PS. Though I know my way around basic command lines, I am not a computer expert; that's why I'm here asking for help. [Attached: Original_Dell_M5100_Hynix_BR46584.bin] Original_Dell_M5100_Hynix_BR46584.bin
Daedalus Posted October 8 Posted October 8 12 hours ago, gingerswordsmith said: Hello everyone, I am planning a GPU upgrade on my HP EliteBook 8570w and am looking for assistance with a custom VBIOS patch to bypass the HP whitelist and ensure proper display initialization. I am upgrading from a working Nvidia Quadro K2000M to a Dell-sourced AMD FirePro M5100. Using a CH341B hardware programmer and NeoProgrammer, I have successfully extracted and verified a clean dump of the card's factory VBIOS (it is confirmed to have SK Hynix VRAM, and the internal string shows BR46584.001.FGL VENUS). I have attached this raw .bin file to this post, as I understand it is usually safer to custom patch the card's original firmware rather than flashing a generic file. Here are my exact host system specifications: Host System: HP EliteBook 8570w System Board ID: 176B HP System BIOS Version: 68IAV Ver. F.43 Boot Mode: Pure UEFI (Native) Internal Display Panel: Standard FHD 8-bit LVDS Panel (LG Philips LP156WF1 - Non-DreamColor) Target OS Setup: Dual-booting Windows 10 and Debian 12 Could someone please help modify my attached original VBIOS with the proper subsystem IDs and ACPI adjustments to work cleanly with my 176B motherboard and standard LVDS display? Thank you so much for your time and expertise! PS. Though I know my way around basic command lines, I am not a computer expert; that's why I'm here asking for help. [Attached: Original_Dell_M5100_Hynix_BR46584.bin] Original_Dell_M5100_Hynix_BR46584.bin 128 kB · 0 downloads Welcome to the Forum and Thread, you will find a number of us have arrived at same desire to modify these machines. Are you set in getting the M5100? i ask as there are a fair few MXM "A" cards you could use above the M5100, otherwise you can go further down the rabbit hole and look at MXM "B" upgrades. Take a look at TechPowerUp, there maybe a Vbios image already there for the m5100 that works. Unfortunately its difficult to load a VBios "in machine" as our CPU socket traces dont exist even though the CPU might have IntelHD on the core. You refer to the whitelist, if i recall this is located on the Mobo and not the GPU card, so your looking at whiletlist editing (a completely seperate to a working VBios image). You may have a perfect Vbios solution but if the mobo says no, you'll only get a black screen. The whitelist appears to have not just GPU restrictions, also Network cards too. sorted a 6250 wifi to a 7260 upgrade and had similar fun, Internet says "it shouldnt work" Pah..... This 8570W now runs a 7260HMW card (so stuff can be done within the apparent restrictions) wether it be HP scare tactics or an actual whitelist they deny exists...... That said its not all doom, if you read through the thread a number of GPU's have been proven to work which arent on HP's "list" HP Elitebook 8570w - i7-3940XM / 32GB HyperX 1866 (fake) / 1TB Samsung Evo / 512gb Kingston Msata / K1000m (to be 980M)
