GuitarG Posted August 17 Author Posted August 17 18 minutes ago, Daedalus said: not to be difficult, UK users cant see IMGUR pictures, so all i see is a blue block. Awesome progress though. Shame the 8570W journey ends. Did anyone uncover the HP LVDS cable pinout diagram? i seem to recall its in an older post (i'll go hunt for it. Happy to try recreate the cable, just need to get a bundle of LDVS to sacrifice 😄
Daedalus Posted August 18 Posted August 18 On 8/17/2026 at 6:15 PM, GuitarG said: am i assuming from the diagram above no interposer board is needed? just looking at sources for the cables at present. LVDS elitebook ones seem viable on ebay. is there any IPS displays preferred that fit the 8570W lid best (just to focus searches) Also has anyone got the interposer dreamcolor board cable assembly part number too? @GuitarG i salute your devotion to the cause and effort so far, a shame the 8570W is retired from your flock. Enjoy the next challenge 😉 HP Elitebook 8570w - i7-3940XM / 32GB HyperX 1866 (fake) / 1TB Samsung Evo / 512gb Kingston Msata / K1000m (to be 980M)
FrancoTecno Posted August 28 Posted August 28 On 11/17/2025 at 3:30 PM, Vladka76 said: Interesting. The FBGA code "D9RVX" on your chips means the model name MT41K512M8RG-107:N, officially also 1866 (from the datasheet: the "-107" marking = option "1.07ns@CL=13 (DDR3-1866)"). This chip's frequency is the same as one I've encountered, but the FBGA code on those I've seen was slightly different from this one. What's preventing good memory chips from running at full speed? Perhaps poor-quality resistor arrays on the data buses (all my original modules have ceramic, white resistor arrays)? Or the firmware on the SPD flash IC? It's sad. This is often the case with the Chinese – they copy almost everything well, but somewhere there's always a flaw that ruins everything... Another my photo. 🙂 Compare the quality of the sticker on the other side of the two modules (original on top, counterfeit on the bottom). The original has an aluminum base and a black ink printing, while the counterfeit has a paper base and white ink with a low-resolution print. And a resistor arrays are different in color and material... i leave the official PDF of those DRAM family chips, the -107 revision (D9RVX) are rated for 1866MHz at 13-13-13, a jedec profile that matches with the DRAM oficial specificacion isnt specified in the SPD of these fake DIMMs, so probably you need to adjust primary timings and secondary ones manually to make them working at 1866, right now i managed to make them working at 2133MHz, but i need more research into the official PDF to make a fitable timing table at 2133 according with the oficial specifications of the DRAM modules to avoid stability issues micron4Gb_DDR3L.pdf 1 MSI GT60 2OC Intel i7 4930MX, GTX 1060, 15.6" FHD (90Hz OC), 32GB RAM, 1TB mSATA RAID 0 (2x512), 1TB HDD, Intel WiFi 7 BE200 Card
FrancoTecno Posted August 28 Posted August 28 the SPD data on these chinese modules is pretty uncertain, because the reported latency in miliseconds contained in the SPD is lower than the official specificacion by micron in that PDF... even the jedec profiles are very uncertain because they dont have a 1866MHz jedec profile when the DRAM chips are officially of 1866MHz 1 MSI GT60 2OC Intel i7 4930MX, GTX 1060, 15.6" FHD (90Hz OC), 32GB RAM, 1TB mSATA RAID 0 (2x512), 1TB HDD, Intel WiFi 7 BE200 Card
FrancoTecno Posted August 31 Posted August 31 my best now.. i want to increase the dram voltage a little bit to go up to 2400 but i dont find any type of RAM voltage control in my unlocked bios, anyway 2200MHz is very well for DDR3 MSI GT60 2OC Intel i7 4930MX, GTX 1060, 15.6" FHD (90Hz OC), 32GB RAM, 1TB mSATA RAID 0 (2x512), 1TB HDD, Intel WiFi 7 BE200 Card
MODDER1 Posted September 1 Posted September 1 Hi, the system i worked on so far, "working fine" i would say, its a pure copper plate ajusted to the components of the card, i did dig some cavities for "R22" components in it to allow a direct and good contact between the plate and the GPU die of the 980M. At idle i hit 32-33° for the GPU and 46-47° for hot spot with PTM7950, the plate and heatpipe being cool i would say, but then under load the temp continue to spike and hit the 92° limit and the card start to throttle. I think may be its the heatpipes, that i don't cool effectively underload due to a bad alignement with the fins, or not enough heatpipes? And what's happening is that the heat is not pushed outside quick and effectively enough maybe? What you guys think the improvement is there ? Also, can someone confirm that the hotspot on the GPU is also at the level of the Die? Thanks HP Elitebook 8570w / i7 intel 3740QM / GTX 980M 8GB / 16 GB RAM 1600Mhz stock / Double FAN Cooling
Daedalus Posted September 1 Posted September 1 Nice work, Not bad. Thats kinda how i was envisaging my dual fan setup to look like. My version was keeping the fan to GPU pipe but also having the inverse like you have for the GPU to second fan. assume all LMP solder joints there. why no primary fan to GPU plate heatpipe? GPU maybe overloading 2nd fans ability to exhaust heat one question, why not have the 2nd fan nearer the SSD bay? (assume due to heatpipes not working in flipped over layout. Also where is your second fan run from, i see the PWM feed from main fain header, but are you using +5v and gnd from DVD? (as 980M install requires a brutal haircut of the DVD port) i planned on taking feed from USB sub-board (that black plastic covered board bottom right) on the underside how is fan intake working? i have a round hole in my DVD bay floor and a grille in my access panel now 🙂 Regards video output is that via internal display on 980M? which Vbios. How did you bend your heatpipes? Apologies for the critique. love the progress youve made. HP Elitebook 8570w - i7-3940XM / 32GB HyperX 1866 (fake) / 1TB Samsung Evo / 512gb Kingston Msata / K1000m (to be 980M)
MODDER1 Posted September 1 Posted September 1 6 hours ago, Daedalus said: one question, why not have the 2nd fan nearer the SSD bay? (assume due to heatpipes not working in flipped over layout. There are also some cables running there, the upper zone is the best i think for fan intake. 7 hours ago, Daedalus said: Also where is your second fan run from, i see the PWM feed from main fain header, but are you using +5v and gnd from DVD? (as 980M install requires a brutal haircut of the DVD port) So PWM from fan 1, 5V et GND from DVD port pins, and yes it requires a brutal haircut ahah, but pretty simple using hot air station. 7 hours ago, Daedalus said: on the underside how is fan intake working? i have a round hole in my DVD bay floor and a grille in my access panel now 🙂 This is the way, i haven't done it yet from my side, but running the laptop without the keyboard for now. 7 hours ago, Daedalus said: Regards video output is that via internal display on 980M? which Vbios. Yes, it's an alienware vBIOS i think, not sure though, but running smoothly till now. 7 hours ago, Daedalus said: How did you bend your heatpipes? By hands, pretty simple, but you have to be gentle tho. 7 hours ago, Daedalus said: Apologies for the critique. love the progress youve made. Why, don't, that why i'm there for😉, Thanks! HP Elitebook 8570w / i7 intel 3740QM / GTX 980M 8GB / 16 GB RAM 1600Mhz stock / Double FAN Cooling
MODDER1 Posted September 1 Posted September 1 7 hours ago, Daedalus said: why no primary fan to GPU plate heatpipe? GPU maybe overloading 2nd fans ability to exhaust heat And yes, i was thinkin like adapting a system for each of the cards, i also saw a pub from GuitarG earlier, who wanted a solution just like that. Then i also had an observation that the exhaust air was hot, but not hot enough (like it's not really pulling away much heat), so i might investigate on this also. HP Elitebook 8570w / i7 intel 3740QM / GTX 980M 8GB / 16 GB RAM 1600Mhz stock / Double FAN Cooling
janepa Posted September 1 Posted September 1 Hi The very best thing you can do in this case is to close the loop by soldering on shorter heat pipes. As a next step, you could ask someone with a 3D printer to make a simple tube bender, or even buy one and use 5mm heat pipes to bend them as needed and flatten them to the required thickness at the contact (soldering) points. https://www.ebay.co.uk/itm/283251571555 There’s also the option to adjust the fan blades themselves their number and size. The basic idea however is very good. Great work. Alienware M18x R1 i7-2720xm-32GB-Adlink RTX5000 Alienware M18x R2 i7-3920xm-32GB-RTX4090 (still in testing) with the latest bios version. A14 specially modified updated and unlocked by me 😎 Asus ROG Zephyrus G14 AMD Ryzen 9 7940HS-32GB-RTX4060
janepa Posted September 1 Posted September 1 Hotspot temp. sensors on a GPU chip. Alienware M18x R1 i7-2720xm-32GB-Adlink RTX5000 Alienware M18x R2 i7-3920xm-32GB-RTX4090 (still in testing) with the latest bios version. A14 specially modified updated and unlocked by me 😎 Asus ROG Zephyrus G14 AMD Ryzen 9 7940HS-32GB-RTX4060
Daedalus Posted September 2 Posted September 2 11 hours ago, janepa said: Hi The very best thing you can do in this case is to close the loop by soldering on shorter heat pipes. As a next step, you could ask someone with a 3D printer to make a simple tube bender, or even buy one and use 5mm heat pipes to bend them as needed and flatten them to the required thickness at the contact (soldering) points. https://www.ebay.co.uk/itm/283251571555 There’s also the option to adjust the fan blades themselves their number and size. The basic idea however is very good. Great work. if memory recalls i dont think linking the pipes back to GPU copper plate would be efficient, i get the logic of hot running to cold point (fan) though. I always understood heatpipes work best with a temp gradient from one end to other. looping would increase copper mass, you might benefit from two pipes ending up at exhaust grille. just my 2c. Is that a 3d printed fan? i ask as i had sooooo many Ali fans working out which would fit in DVD bay then the headache of supplying different brand fans with HP happy power. HP Elitebook 8570w - i7-3940XM / 32GB HyperX 1866 (fake) / 1TB Samsung Evo / 512gb Kingston Msata / K1000m (to be 980M)
janepa Posted September 2 Posted September 2 Yes, years ago I built a similar model with a loop and it worked well, but in the end I decided to go a different way because of easier installation and removal needed. Your idea is also possible of course. There are several options available. No, this is the original fan that was damaged it was missing a few blades it was basically a scrap. Here you have the option to remove the all original blades keep the fan core and attach a newly designed ring with blades shaped as needed. I also had a problem controlling the fans, but I eventually solved it by using my own small control electronics. Alienware M18x R1 i7-2720xm-32GB-Adlink RTX5000 Alienware M18x R2 i7-3920xm-32GB-RTX4090 (still in testing) with the latest bios version. A14 specially modified updated and unlocked by me 😎 Asus ROG Zephyrus G14 AMD Ryzen 9 7940HS-32GB-RTX4060
MODDER1 Posted September 2 Posted September 2 15 hours ago, janepa said: Hotspot temp. sensors on a GPU chip. Thanks a lot for the knowledge sharing! 15 hours ago, janepa said: As a next step, you could ask someone with a 3D printer to make a simple tube bender, or even buy one and use 5mm heat pipes to bend them as needed and flatten them to the required thickness at the contact (soldering) points. A pipe bender would allow me to be more precise in fact 15 hours ago, janepa said: The basic idea however is very good. Great work. Thanks mate! It's encouraging for me that the base is good and it can only get better. What i will try know is to align the fins and the fan near perfection, it will definitly help pushing the heat better. HP Elitebook 8570w / i7 intel 3740QM / GTX 980M 8GB / 16 GB RAM 1600Mhz stock / Double FAN Cooling
GuitarG Posted September 2 Author Posted September 2 On 9/1/2026 at 1:01 PM, MODDER1 said: Hi, the system i worked on so far, "working fine" i would say, its a pure copper plate ajusted to the components of the card, i did dig some cavities for "R22" components in it to allow a direct and good contact between the plate and the GPU die of the 980M. At idle i hit 32-33° for the GPU and 46-47° for hot spot with PTM7950, the plate and heatpipe being cool i would say, but then under load the temp continue to spike and hit the 92° limit and the card start to throttle. I think may be its the heatpipes, that i don't cool effectively underload due to a bad alignement with the fins, or not enough heatpipes? And what's happening is that the heat is not pushed outside quick and effectively enough maybe? What you guys think the improvement is there ? Also, can someone confirm that the hotspot on the GPU is also at the level of the Die? Thanks Nice work! Let me say my 2 cents, if CPU gets hot, GPU fan kicks higher gear too ? I see dents on heatpipe, it may be too damaged to work properly now. Try using "sandwich" technique to solder metals - distribute clamp force evenly using thin metal from up and down of heatpipe. Also if using premade heatpipes, check which side is cold side, because this is important. Heatpipes have hot side, CPU/GPU side simply saying and cold side, where fins are located. Most efficient are those with less bends and smaller angle. If fins are located in middle, it may also perform worse compared to fins welded on "end". Hotplate connection to gpu die is also big one, as level as possible and smooth surface helps. Lastly, always use up to date soldering paste (I made this mistake myself, I used one time paste that was past usefulness date - it connected metal but no trasfer of heat at all..) and connect metals solidly (I don't know how to describe but think of wood glueing - there is saying the less glue you use then better it holds) - good and big contact surfaces are MVP here. So anyway, nice job ! Good luck!
MODDER1 Posted September 2 Posted September 2 4 hours ago, GuitarG said: Nice work! Let me say my 2 cents, if CPU gets hot, GPU fan kicks higher gear too ? I see dents on heatpipe, it may be too damaged to work properly now. Try using "sandwich" technique to solder metals - distribute clamp force evenly using thin metal from up and down of heatpipe. Also if using premade heatpipes, check which side is cold side, because this is important. Heatpipes have hot side, CPU/GPU side simply saying and cold side, where fins are located. Most efficient are those with less bends and smaller angle. If fins are located in middle, it may also perform worse compared to fins welded on "end". Hotplate connection to gpu die is also big one, as level as possible and smooth surface helps. Lastly, always use up to date soldering paste (I made this mistake myself, I used one time paste that was past usefulness date - it connected metal but no trasfer of heat at all..) and connect metals solidly (I don't know how to describe but think of wood glueing - there is saying the less glue you use then better it holds) - good and big contact surfaces are MVP here. So anyway, nice job ! Good luck! Its an honor general 🫡! appreciate the feedback! HP Elitebook 8570w / i7 intel 3740QM / GTX 980M 8GB / 16 GB RAM 1600Mhz stock / Double FAN Cooling
MODDER1 Posted September 2 Posted September 2 5 hours ago, GuitarG said: if CPU gets hot, GPU fan kicks higher gear too ? if it was a question for me, i would say that the fan is always at max i think, and not depending on the the CPU temp. HP Elitebook 8570w / i7 intel 3740QM / GTX 980M 8GB / 16 GB RAM 1600Mhz stock / Double FAN Cooling
Daedalus Posted September 3 Posted September 3 15 hours ago, MODDER1 said: if it was a question for me, i would say that the fan is always at max i think, and not depending on the the CPU temp. as we are sourcing only PWM from CPU header (splitting only fan feed on mobo), we see both fans at equal speed, as the tacho pin isnt presented at 2nd fan (3-pin) (mainly due to the fact it confuses the mobo header) so its only CPU (4-pin) fan that would speed up and slow down. I know in GPU-Z it doesnt detect fan speed of either current and the "additional". HP Elitebook 8570w - i7-3940XM / 32GB HyperX 1866 (fake) / 1TB Samsung Evo / 512gb Kingston Msata / K1000m (to be 980M)
Daedalus Posted September 5 Posted September 5 On 8/17/2026 at 6:15 PM, GuitarG said: Hi all, just found the below for our cable build saga. Someone on the thinkpad forums hit similar issue for lvds 1. eDP -> LVDS adapter:https://e.tb.cn/h.8kNp2CawbSlReTo?tk=FLq9TdpACbP 2. eDP 40pin ->30pin: https://e.tb.cn/h.8lZV7mu4BxoANYC?tk=AYKSTdKbVim and https://a.aliexpress.com/_EG5DDMQ upd. 3. wacom-emr-digitizer to usb adapter project: https://github.com/bulat-chu/WACOM-ThinkPad-X60T-Digitizer In my head (yeah i know its crazy) it maybe easier to repin the intermediate boards above than mess with a tiny co-axial cables which will melt and short. again it’s TaoBao but might be useful Can someone on here confirm that an 8770W DC cable would work for our 8570W challenge? i may have a source for one. (however the pic shows just the cable so im thinking im missing the interposer board. unless its hidden under the tape / material covers HP Elitebook 8570w - i7-3940XM / 32GB HyperX 1866 (fake) / 1TB Samsung Evo / 512gb Kingston Msata / K1000m (to be 980M)
Vladka76 Posted September 10 Posted September 10 On 11/13/2025 at 11:42 AM, GuitarG said: so I bite bullet and changed audio IC. From 92HD80 to 92HD94, now both speakers sounds better (comparing to 8560w with Windows 7 and SRS) Hi! Could you clarify: how noticeably did the sound improve after this upgrade? What exactly improved, in your opinion? Are all the audio ports working and any issues with jack sensing? I'm looking at the datasheets: the main difference between 92HD9x and 92HD8x is the replacement of the Class AB power amplifier with a Class D amplifier. And the closest equivalent to 92HD81 is 92HD91 (there's no datasheets for 80 and 94). 🤔 Does this upgrade make sense if the original audio processor is working properly? hp EliteBook 8770w: i7-3840QM | M3000m 4Gb | 16Gb DDR3L 1866Mhz (2 pcs original Kingston HX318LS11IB/8)
GuitarG Posted September 10 Author Posted September 10 3 hours ago, Vladka76 said: Hi! Could you clarify: how noticeably did the sound improve after this upgrade? What exactly improved, in your opinion? Are all the audio ports working and any issues with jack sensing? I'm looking at the datasheets: the main difference between 92HD9x and 92HD8x is the replacement of the Class AB power amplifier with a Class D amplifier. And the closest equivalent to 92HD81 is 92HD91 (there's no datasheets for 80 and 94). 🤔 Does this upgrade make sense if the original audio processor is working properly? It did got louder and less distorted on original speakers. Also, I already had problem with missing channels (sometimes right speaker stoped worked suddenly) - that IC replacement solved it. It won't be ARM Macbook pro level, though, but still worth it IMHO. 1
Vladka76 Posted September 10 Posted September 10 44 minutes ago, GuitarG said: It did got louder and less distorted on original speakers. Gemini wrote to me that in 9x revisions of audio processors, IDT used "a much more aggressive and intelligent dynamic range compression algorithm. It 'pushes' quiet sounds and gently limits peaks. Subjectively, this is perceived as a sharp increase in density, 'thickness' of the sound and volume without any noticeable speaker wheezing." (c) Furthermore, "In 9x revisions, the algorithms for virtual stereo widening and bass boost compensation were refined, which are hardwired into the codec's processing logic." (c) So it turns out the AI was right about everything, right? Is the difference really noticeable to the ear? --- P.S. Just curious - why did you replace your 92HD80 with 92HD94 and not with other 9x? hp EliteBook 8770w: i7-3840QM | M3000m 4Gb | 16Gb DDR3L 1866Mhz (2 pcs original Kingston HX318LS11IB/8)
MODDER1 Posted September 14 Posted September 14 Bad news from my side, can someone maybe help on this? I did realign the heatpipe (fins) and the fan to allow a better cooling, the temps where great i would say at idle (28-29° on the die, the best till now) but then when trying to test the efficiency, i did launch a unigine heaven benchmark and after like 2-3 minutes, the card suddenly started glitching, artefact and frozen screen, and then hard disk automatic repair. It has never hapenned before altough i did a lot of testing till this time, i tried some research and found that it might be the vram chips (fried?) but when turning on the laptop after the repair it works like nothing hapenned (drivers install, and everything works fine) then it means that the chips are good i would say But then, i will lauch a game (like COD4) play it a bit, and then i stop and nothing happen, but the card start to artefact again even though the temps are decreasing (around 40°, it started), that is where i'm lost It might be the vbios (instability), i still didn't check properly the version because everything was working fine till now, but i would maybe need to flash another one. HP Elitebook 8570w / i7 intel 3740QM / GTX 980M 8GB / 16 GB RAM 1600Mhz stock / Double FAN Cooling
Vladka76 Posted September 14 Posted September 14 On 9/14/2026 at 11:02 PM, MODDER1 said: It might be the vbios (instability) IMHO, no. I’d say it looks like the GPU die separating from its substrate - a situation when data lines between video memory chips and a GPU break when the card heats up. Unfortunately, this is irreparable... 🥹 In case of an Nvidia card, it’s best to start diagnostics by testing the entire video memory using the appropriate version of MODS/MATS tools for that card's architecture. You’ll need a small bootable USB flash drive for this. If a specific memory chip is died, it will get very hot shortly after power is applied. In that case, you can use the "wet finger" method. 🙂 On 9/14/2026 at 11:02 PM, MODDER1 said: I did realign the heatpipe (fins) and the fan to allow a better cooling It would probably be best to realign the heatpipe(s) using a non-functional, "dummy" graphics card?.. hp EliteBook 8770w: i7-3840QM | M3000m 4Gb | 16Gb DDR3L 1866Mhz (2 pcs original Kingston HX318LS11IB/8)
MODDER1 Posted September 17 Posted September 17 On 9/14/2026 at 10:50 PM, Vladka76 said: Unfortunately, this is irreparable... 🥹 OH MYYY On 9/14/2026 at 10:50 PM, Vladka76 said: If it’s an Nvidia card, it’s best to start diagnostics by testing the entire video memory using the appropriate version of MODS/MATS tools for that card's architecture. You’ll need a small bootable USB flash drive for this. If it’s an AMD card, there aren't really any tools to test it with - no proprietary test exists for them. If a specific memory chip is at fault, it will get very hot shortly after power is applied. In that case, you can use the "wet finger" method Daang, thanks for the knowledge sharing mate, i will try to test as you suggest. I played for example GOW2 for a long moment and there was no issue (53° max), where my confusion. Thanks again for your answer! HP Elitebook 8570w / i7 intel 3740QM / GTX 980M 8GB / 16 GB RAM 1600Mhz stock / Double FAN Cooling
