I think at some point there was a whitelist of sorts, but HP removed it in a later BIOS. I had no issues upgrading my GPU and WiFi card.
Precision M4800 - i7 4810MQ, 32GB RAM, Nvidia Quadro M2200
Thinkpad T430 - i7 3630QM, 16GB RAM, Intel HD 4000, 1080p display mod
Main PC - AMD Ryzen 9 5950X, 64GB RAM, RTX 2080 Ti
i have the final .71ver on my machine, looking at the bios release notes on HP.com, it doesnt call out an whitelist being present, that said some had issues (there was alot of chatter on older forums on it). There was a Coreboot bios floating around 8770W only (however 8570 and 8770W share same .71 version, no O/C option in the .71 bios release for CPU or RAM.....which is a shame.
I tried (and failed) a GTX 965M upgrade, might have been a duff card. However now working on my 980M upgrade.
No issue going from 62205 to a 7260HMW, just plug an play in win10. Wifi speeds improved, still working on getting BT stack operational as only sees Broadcom (onboard ) not showing Intel chipset.
HP Elitebook 8570w - i7-3940XM / 32GB HyperX 1866 (fake) / 1TB Samsung Evo / 512gb Kingston Msata / K1000m (to be 980M)
9 hours ago, Daedalus said:
Welcome to the Forum and Thread, you will find a number of us have arrived at same desire to modify these machines.
Are you set in getting the M5100? i ask as there are a fair few MXM "A" cards you could use above the M5100, otherwise you can go further down the rabbit hole and look at MXM "B" upgrades.
Take a look at TechPowerUp, there maybe a Vbios image already there for the m5100 that works.
Unfortunately its difficult to load a VBios "in machine" as our CPU socket traces dont exist even though the CPU might have IntelHD on the core.
You refer to the whitelist, if i recall this is located on the Mobo and not the GPU card, so your looking at whiletlist editing (a completely seperate to a working VBios image). You may have a perfect Vbios solution but if the mobo says no, you'll only get a black screen.
The whitelist appears to have not just GPU restrictions, also Network cards too. sorted a 6250 wifi to a 7260 upgrade and had similar fun, Internet says "it shouldnt work" Pah..... This 8570W now runs a 7260HMW card (so stuff can be done within the apparent restrictions) wether it be HP scare tactics or an actual whitelist they deny exists......
That said its not all doom, if you read through the thread a number of GPU's have been proven to work which arent on HP's "list"
Hi Daedalus,
Thanks for the warning about the lack of CPU socket video traces preventing an in-machine flash. Fortunately, I am using an external CH341B hardware programmer and an SOP8 clip, so I was able to safely pull a clean dump of the original Dell VBIOS while the card is out of the machine. I won't need the laptop to boot to flash it.
Regarding the whitelist: I am still a beginner at this and definitely don't have the skills to modify raw hex code myself. I was hoping a VBIOS mod existed where the card's sub-vendor info could be changed to match an official HP card, tricking the motherboard into letting it boot.
Knowing that I'm flashing externally with the CH341B, is there a pre-modified VBIOS image floating around for this specific Dell M5100 to HP 8570w combination that you know of?
I did take a look at TechPowerUp as you suggested, but to be honest, I'm just not knowledgeable enough to know which VBIOS image might actually work for this specific cross-brand mod. Since I want to avoid potentially damaging the card through blind trial and error, I'd prefer to find a file that someone with more experience has already verified as working.
Also, thank you for the tip on looking at other cards. I decided on the M5100 specifically because I regularly use Debian 12 and wanted an AMD card to take advantage of the native open-source kernel drivers (amdgpu), which are a lot more stable on Linux right now than Nvidia's options.
On 10/8/2026 at 8:34 PM, gingerswordsmith said:
Hi Daedalus,
Had a search on TechPowerUp.
Found the unit (i think)
VGA Bios Collection | TechPowerUp
I totally get your concern on the will X work with Y.  I had similar concerns when trying to work out the correct Vbios for my 980M. Turned out KBX on here had already tested stuff, long story short, an MSI / Dell Vbios on an Nvidia card works in an HP. It seems the Dell Vbios are more relaxed and allow more compatibility.
I also run a dual boot with my current K1000M and soon to be 980M (once i finish messing around with the cooling solution) dont disagree AMD drivers arent more stable, good choice.
The lack of GPU traces on the CPU core sucks as we then have no internal GPU (IntelHD) to fall back on if the flashing didnt work. Im not aware of anyone managing to fix this.
Did anyone actually attempt the GTX 1080M ( the one without the extra power connector) in the 8570W? i know 1070M wont output to anything but DP, but curious if 1080M did the same?
Hi all, please critique the idea.......
Going back to the cable saga, are we (or am I) looking at this wrong, As far as im aware once we pass the GTX 980M upgrade we are in Dreamcolor territory (thats a given). 1070M and others only output to DP as a result as either the internal screen cant display (Mux) or not configured at Vbios level.
I was looking at DP to HMDI conversion (mini project) as a separate thing
Could we run say an DP to 30pin eDP or HMDI to EDP and see if the port would output to the inbuilt screen or am i missing something. DP output is only there on 1070M as its a "configured". Clearly we cant Vbios edit a internal screen (even if it could display) we have the MuX issue to work around.
checking specs for the 1080M it shows 3 DP ports ( now we have 1 wired) so it should display output at least to DP#1 our port.
I did stumble across the following in the continuing journey for the eDP to LVDS
Taidacent 3.3V 5V 30 Pin EDP Universal Driver Board EDP to LVDS Converter Board LCD Screen LVDS to EDP Signal Adapter (Extended-Type) : Amazon.co.uk: Business, Industry & Science
or
EDP to LVDS Adapter: Convert Signals Easily or Wholesale LCD TV Display Spare Part 51P FHD to 30P HD LVDS Adapter For HV320WHB-N ( the last one seems to look very close to our rare board)
Does the board convert signals or act as a connection point and thats it?
On 3/18/2026 at 10:18 AM, JadeRover said:
Yes, dell m6600 and dell m6700 DC models have that DC conveter board that transforms the incoming eDP to 50 pin LVDS + 10 pin power cable used by the DC LCD.
The HP zbook 17 g1, g2 and 15 g1 that have the DC screen option also use such converter boards.
Keep in mind that for all the models stated the converter board looks something like this :
Carte LCD + Vis (board) - pour HP ZBook 17 G1 - VBK10 LS-9374P - Testé OK -  Accessoires informatique
So if you get the DC cables for your model you see that it connects to your board in a non standard eDP format = can't use that cable to connect to a standard eDP panel conenctor.
Also the zbook 17 g1 and g2 all have this converted board as they all have LVDS displays and the motherboard outputs eDP. Not sure why HP chose this approach, probably because eDP lcds were rare in 2013-2014.
so zbook 17 g1/g2 with 900p to 1080p screes have this board if you want a sure way to get your hands on one.
If i re-read this right, This is the inverse of what we have in the 8570W? Our MoBo is 50Pin LVDS output and we can put a 30Pin eDP screen. So therfore an IPS screen. so even if i tracked one down and had an LVDS "normal cable and spliced to a G1/G2 cable (for the connector) and then its relevant output 30pin to the screen. i dont think this would solve our issue.
Your mobo is a 50 pin (LVDS + eDP) COMBO connector it is quite rare, usually laptops only expose either LVDS or eDP per connector, the 8560w, 8570w, 8760w and 8770w have this dual mode connector.
This is the schematic of a 8770w (because 8570w schematic is unavailable), it has the same 50 pin connector (different pinout from the 8570w BUT still the same function) :
See pins 39 to 50 : they contain 4 lanes of DP (4x2 differential pairs) + 1 aux pair + DP HPD pin, to change a DP into a eDP you need two extra signals : backight on + backlight PWM that is also present on the connector
  • INV_PWM (backlight inverter PWM) -> it is used by the dGPU when driving an eDP display
  • LCM_3S_BKLTEN -> Backlight enable signal
These two signals are universal between LVDS and eDP displays.
Here are the first 40 pins of the 50 pin LVDS + eDP connector of the 8570w (just so you can see that this connector also contains LVDS signals as well as DP signals just in a different order) :
All this to say that if you want a 30 pin or 40 pin eDP display connected to your 8570w, you need a custom LCD cable that only uses the DP lines + backlight signals from the motherboard's 50 pin LCD "COMBO" connector. Also this custom cable should contain other HP signals for LID closed and LOGO light that go through this 50 pin LCD connector.
This custom cable will terminate in either a 30 or 40 pin male IPEX connector that is required to plug in to a 30 or 40 pin eDP display. Therefore doing this will allow you to upgrade to 4K60Hz+ IPS displays or even Mini LED displays just like it was done here on the 8770w :
TLDR : To accomplish this upgrade you need :
  • Custom LCD cable that connects directly to the display, no DC board needed or any other type of signal converter board
  • 40 pin eDP display
Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 3011Mhz |  1440p165hz (upgrad)
Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 2666Mhz | FHD IPS
Thanks @JadeRover for the response, thats what i suspected it presented both,
I had initially scoured the "interweb" for 8770W cables, but discussed with GuitarG and found 8770W were wired different, which is a pain as if 90% of the wires are same and just a few are different it might have been viable "small" mod to make it work. (plus 8770W cables are less rare, relatively speaking)
40Pin EDP seem available so the screen end is easier (relatively)
I did catchup with DevilAngel on the 8770W post in the message, he used TaoBao to get someone to build a cable. I'm yet  to work that site out with success. We seem to have alot of the pinout detail its just getting someone to make one.
That said, what is the "interposer board" actually doing if a cable (custom) removes the need for conversion. I recall GuitarG saying the interposer / inverter part got hot in the shell so he put putty or something to transfer heat so i think the board wasnt a "passive" item.
IMHO, the only place where chinese copy(?) of DreamColor cable for 8770w is available (9996 pcs left):
Direct link to AliExpress
Warning: his p/n 6017B0352401, so pls click on the correct proposal (xxxxxxxxx301 is the LVDS version).
I would venture to guess that owners of the 8570w can also buy it, but then they will have to carefully pull almost all the wiring terminals out of the connector of the mobo's side and rearrange them to the correct positions, according to the GuitarG pinout table. But the cost of an error due to inattention will be significant (pinouts of 8570w and 8770w are very differents), so they will have to take this risk upon themselves.
Based on GuitarG's research, I have compiled my own, so far in theory, version of a custom cable for 8770w mobo -> 30 pin eDP. Dear @JadeRover, can you help me check the correctness of my work?..
And one more question for you.
Somewhere earlier our GuitarG wrote that he was able to get the 30 pin screen to work, but not the 40 pin screen. In this case, what would be the best way to deal with the microcables of the two left unused pairs of the eDP interface?
Just insulate their exposed leads near the 30 pin connector?
Or would it be better to pull their wiring terminals from the connector on the mobo side and insulate them near both connectors?
Or even pull them out of the cable completely?..
The custom cable pinout for hp 8770w mobo -> 30 pin eDP screen:
hp EliteBook 8770w: i7-3840QM | M3000m 4Gb | 16Gb DDR3L 1866Mhz (2 pcs original Kingston HX318LS11IB/8)
IIRC, the 8570W cable is different to the 8770W from discussion with GuitarG, I recall the pinout he added to the thread,
That said, moving a few cables is preferable to moving all of them...... Best have my steady hands and good eyes that day 🙂
Do we assume that Ali cable is a end to end solution? (could be an equipment pull or an actual manufactured clone) I ask as the "official" has the interposer board which i couldnt see in the Ali advert. Ive also seen the 8770W cables on ebay but again all seem to be missing the board in the middle (assumption is the cable is doing all the pinout changes to make LVDS Mobo and edp/IPS screen "talk" and work.
(added in GuitarG's version of the above for 8570W comparison)
Just trying to get all the bits to the puzzle......
So 301 is the Normal, 401 is the "dreamcolor". added to the basket 🙂 amongst other ALi items for the machine 😄
Hello,
Good job, yes this pinout matching is correct.
However I would actually wire this to a 40 pin eDP connection with 4 lanes of eDP because that way you can wire the screen up to nicer 1440p and 4k displays with high refresh rate, if you so chose to.
If you want a 30 pin screen you can pick up a very cheap 40 pin to 30 pin eDP converter flex cable such as this one, that way you can make these 40 pin cables in bulk and end users can decide to get one with 30 pin converter or not depending on if they want to use a 30 pin or 40 pin display.
If you want to make a custom 30 pin eDP cable then the 2 unused lanes should not be connected to anything, just let them terminate on the 50 pin LCD port on the motherboard -> cut the extra unused cables directly on the port.
30 Pin to 40 Pin EDP LED LCD Screen Converter Cable : Amazon.fr: Computers
13 minutes ago, JadeRover said:
Hello,
so without chasing the new 4K capability, would that be beneficial to the ageing 8570W, (dont get me wrong its a nice tech to have). Would the simpler 30 pin and IPS capability be suitable?
Have ordered one of the '401 cables Vladka shared the link to so looking good.
I had seen those converters online but they didnt look "intelligent" hence me thinking we were missing the interposer?
Thats actually a good logic of having a 50pin to 40pin option and then if 30 pin screen is your thing then just run it that way. Obviously this is all theory and assumes either the 4K screen or the normal 1080 Dreamcolor IPS/eDP screen would function. if we can indeed make the 50MoBo to 40 (or30) pin jump by coupling connectors (with a few rejumpering wires changed) then that makes it way easier than scouring the internet for remaining OEM DC cables.
Hello, yes that 8570w cable is different to the 8770w cable, the pinout in your message is correct.
You know that eDP cables are coaxial ? They have an inner core wire + insulation + outer ground wire + insulation, all in one cable. They are EXTREMELY hard to work with if you solder by hand, possible but very very hard, very fine soldering + microscope + tweezers are needed.
In the factory they are soldered by laser machines, ordering a custom cable is also manufactured this way.
Ali cable isn't the end solution, the best solution in my eyes is to ordering a custom cable, or finding the 50 pin male connector + 40 or 30 pin male eDP connector and making the cable by hand (you can by a spool of micro coaxial cable for cheap)
  • I ask as the "official" has the interposer board which i couldnt see in the Ali advert. Ive also seen the 8770W cables on ebay but again all seem to be missing the board in the middle (assumption is the cable is doing all the pinout changes to make LVDS Mobo and edp/IPS screen "talk" and work.
The cable is probably a clone since manufacture date of 2019 is 8 years after the laptop release. It probably works fine.
Yes if you want a dreamcolor display to work you need an interposer board, but be careful :
  • signals coming from the motherboard to interposer are eDP
  • signals leaving the interposer and going to the display are LVDS
The Dream Color display is a very rare IPS display using high bandwidth LVDS signals, that is why they needed eDP (high bandwidth), converted it to high bandwidth LVDS and then send it to the screen.
The confusion comes from the fact that the laptop sees this display as "eDP" since it has to send eDP signals to drive the display, the reality is that it sends eDP -> gets converted to LDS -> LVDS display.
The cable doesn't "convert" or "talk", that is done thanks to the chip on the interposer board.
A full DreamColor display assembly has :
  • Motherboard to interposer "eDP" cable
  • Interposer board converting eDP -> LVDS
  • Interposer board to LCD "LVDS" cable
  • DreamColor IPS display that uses LVDS signals.
Hope this clears things up for the Dream Color technology ! this is the same for dell precision also using the DC screen.
I see 2 solutions:
  1. Custom interposer board + LCD cable
    Using the stock DC cable, one must design a simple interposer board that has an eDP female port connected to the OEM DC cable + retraces the signals to a 40 (or 30) pin standard eDP female connector + use an off the shelf 40 (or 30) pin eDP cable to connect to the LCD (many can be found on Aliexpress)
    CONS : sourcing a 40 pin female eDP connector (connecting to OEM DC cable) of the interposer board + sourcing a OEM DC cable
    PROS : much simpler to get a custom PCB made than a custom LCD cable
  2. Custom direct LCD cable
    Create a custom 50 pin to 40 (or 30) pin eDP cable as discussed before
    CONS : sourcing a 50 pin female LCD port connector used on the 8770w motherboard + getting a company in china to build such a cable
    PROS : only sourcing one old stock part, the connector
Having DC isnt a deal breaker, just something that doesnt limit the GPU options, LVDS "standard" is 980M max, GuitarG and the DC setup he had was RTX level options, so even if a 4K screen & associated cables unlocks that (or a IPS equivalent for 1080) would work. I plan to use my machine for AI workloads so not so much GPU for gaming, the issue is internal screen display output.
Yep saw the manufactured date so assume its a new "clone" So i would assume a DC screen to have the interposer board attached to the back of it as the primary cable '401 seems to be quite long to route through the hinge assembly to arrive at back of screen. so i would assume the "secondary" cable off the interposer to be a short one similar to your 30-40 flat one shown up above?
if we can get each cable Primary & secondary pinout known / mapped then its really only the interposer board which poses the blocker for upgrades.
To add to the options, could the Dell equivalent cable and assembly work if yours uses Dells DC version? Just a thought.
In that case, best to get DC screen + cables, that way the sky is the limit in terms of GPU upgrade and you still get a nive 1080p IPS display with great colors.
Quadro P5200 or RTX5000 from HP or even RTX4090 with backlight mod to get picture on the internal DC screen.
We would only need to map the Primary (motherboard -> interposer) cable pinout + find the model of the connector used by this primary cable.
That way, one would only have to make a diy interposer board, simple PCB trace routing to a 40 pin eDP connector + use an off the shelf cable to connect to the lcd.
I don't think so, Dell uses the same system + the same number of parts but the pinouts are surely different and the connectors aren't even the same. Here are pictures of the dell m6700 parts :
MOTHERBOARD TO INTERPOSER CABLE :
For Dell Precision M6600 M6700 LCD LED Display Video Screen Cable YXDPN  0YXDPN | eBay
INTERPOSER :
INTERPOSER TO LCD CABLE :
Dell Precision M6700 RGB LCD Ribbon Cable - 2nd Cable - 64HMY
@JadeRover I’ve decided to make a custom (yet universal) cable rather than hunting down a DreamColor (DC) kit. The reason is clear to me: these DC displays (LP173WF3-SLBx, x=1...4, for 8770w x=4, for 8760w x=3) haven’t been manufactured for about 14 years, and - worst of all - their aging backlights tend to shift toward a red tint over time. Furthermore, these panels are limited to a 60Hz refresh rate, and I’d prefer something higher, if possible. I don’t want to be tied to an old, rare display that could start turning reddish at any moment.
I have other arguments as well:
- Our respected guru GuitarG wrote on another forum: "...unfortunately DreamColor is power hog, takes at least 15W."
- I suspect that the additional signal conversion that occurs when changing interface from eDP to LVDS might slightly degrade image quality.
By the way, I did find on our local marketplace OLX an entire display assembly from a DC-equipped 8760w. The seller claims the screen isn’t showing any red tint yet. It uses a different stock video cable (his p/n ...801), but the seller insists it will work on an 8770w. I think I’ll pass, even though it’s a tempting offer. 🤭
By the way, I did find on our local marketplace OLX an entire display assembly from a DC-equipped 8760w. The seller claims the screen isn’t showing any red tint yet. But it uses a different stock video cable (his p/n ...801), but the seller insists it will work on an 8770w. I think I’ll pass, even though it’s a tempting offer. 🤭
I have a 17" dreamcolor display, no red tint from a Dell M6700 with interposer
You’re luck - that means the backlight isn’t failing yet. However, hp and Dell have a different DC conversion boards and their signal processors. Thank you.
N.B. Although, I wouldn’t mind picking up a DC version of fully functional Dell M6700|M6800 for a good client who needs a machine for both work and gaming. 🙂  I’ve long wanted to get my hands on one of these competitors of my 8770w. 🙂 It's interesting to me...
I sell them it for 60€ with interposer and cables since it's very rare. More rarer than the eDP ones
19 minutes ago, Vladka76 said:
perhaps you have for sale an eDP cable for 8770w, p/n 6017B0352401? 🙂 😉
No. Only the 17" LG Dreamcolor screen and the M6700 interposer + cable. The full set.
Ha, I just ordered the '401 cable from Ali.😁  I'm just missing the other parts to get it to the back of the screen 😄
A universal screen cable would make more sense. as you rightly say these screen are no spring chicken and its a lottery on getting a good one that might have been "aged" in transit and goes red the first time its fired up in the new build.
 @SuperMG that DC screen is in a Dell, not attached to a 8570W right? This is why i was thinking can we use Dell or the newer G1/G2 DC cables and screens and transplant them into the 8570W chassis (albeit with re-pinout of cable)
As rightly called out by @GuitarG the screens being a powerhog would be why he saw a hot spot on his build and solved it with the heatpaste/pad.
@JadeRover The cables / board etc you show, those are G1 right? not 8570W? Is it only DC that unlocks the ability to go to P5200/RTX level? Could the "universal cable" give just as good an option? DC is great as its 10-bit screen, however if the MoBo isnt "detecting" the difference of screen installed, why the CardX wont work,but CardY will. So there must be a handshake that happens with DC that doesnt for LVDS that results in it displaying on internal.
These are consequences, not the root cause.
Migrating from an LVDS video interface to eDP opens the door to a world of newer graphics cards (IMHO, up to Ada Lovelace, e.g. 4060-4080). 🙂
The last NVIDIA GPU architecture to support data transmission between GPU and the screen via LVDS was Maxwell 2.0 (e.g., GF980/M5000).
Starting with the Pascal architecture (e.g., GF 1030/P600), support for LVDS was removed - only the eDP interface remains.
Note: Unfortunately, everything mentioned above applies specifically to mobile PCs (laptops).
A friend of mine, an economist with no technical background - followed my advice and installed a new GeForce 1650 (Turing) into his old Dell Workstation T3400, which dates back to 2008 (featuring an X38 chipset with PCI-e ver. 2.0, a Core2Quad Q9650 CPU). To my relief, the card worked properly; with some remote guidance from me, he installed the latest driver, and now he's working and gaming every day...
In our case, however, we’ll have to take a more complicated and somewhat risky path.
It hardly seems fair, does it? 🙂
Yes, DC set eats battery like kids eat candy.
Red tint, sometimes high pitched noise (had both). Even if one can fight tint with colorimeter, its not worth IMO.
My 40pin cable didnt worked only because my 40pin 4k screen was damaged. It tried to show image few times (text, no tv signal noise static, etc), then went totally blank. Later I tried that lcd on my zbook g9 and, suprise suprise, not working at all.
Maybe one day I will find affordable 40pin screen so I can show you that would work same way as 30pin worked. Only difference is two additional lanes pairs.
With good programing skills and ai it may be possible to distill and extract exact reason why 8570w recognized eDP panel fully only with K1000m, as rtx quadro did not (worked but not recognized as internal panel, only as one of DP external monitors). I still think its vbios rom issue.
