Daedalus Posted April 21 Posted April 21 @GuitarG interesting to see the zbook units can work, although we hit the same cable problem. That said could we run the IPS version (dreamcolour equivalent) of whatever the zbooks have? Assuming Zbook cables are more plentiful of course. RE: Cooling can never have enough fins. Plan to run two fans (basically 2 8570W fan assemblies "with fins 🙂 " , just one flipped to point back towards GPU) similar to your idea earlier in post. May unsolder the big heatpipe arm and try a custom shape or other machine heatpipe that fits (worst case raid Aliexpress for straight pipes (i know sintered ones are best). once i have that it will be multiple to take either heat from CPU/GPU sources. intake will be via hole in DVD Bay chassis and a custom access panel vent then exhaust out a DVD drive cover with vent holes. Also looking at custom GPU spiders as 980M has VRAM underneath which doesnt connect to spider to remove heat, just the copper pads on the Mobo. Will share designs / parts used etc so anyone on here can duplicate as required. HP Elitebook 8570w - i7-3940XM / 32GB HyperX 1866 (fake) / 1TB Samsung Evo / 512gb Kingston Msata / K1000m (to be 980M)
Vladka76 Posted April 21 Posted April 21 20 hours ago, GuitarG said: Feeling better, so if I get little more free time will make schematic for edp cable It's very nice to read this! hp EliteBook 8770w: i7-3840QM | M3000m 4Gb | 16Gb DDR3L 1866Mhz (2 pcs original Kingston HX318LS11IB/8)
Daedalus Posted May 2 Posted May 2 @Vladka76 seen some apparently genuine 1866 hyperx sticks, never tracked down 2133 ones, not seen one in the wild (yet). Did you OC your 1866 ones to hit 2133? HP Elitebook 8570w - i7-3940XM / 32GB HyperX 1866 (fake) / 1TB Samsung Evo / 512gb Kingston Msata / K1000m (to be 980M)
Vladka76 Posted May 2 Posted May 2 7 hours ago, Daedalus said: Did you OC your 1866 ones to hit 2133? No, it's not possible OR not easy. IMHO. 🙃 1 hp EliteBook 8770w: i7-3840QM | M3000m 4Gb | 16Gb DDR3L 1866Mhz (2 pcs original Kingston HX318LS11IB/8)
Daedalus Posted May 5 Posted May 5 On 5/3/2026 at 12:02 AM, Vladka76 said: No, it's not possible OR not easy. IMHO. 🙃 No worries, i know Bios (.71) doesnt have OC options or an advanced setting page 😞 , not sure if CPU boost apps allow OC or MSI overclock for GPU) seen a few 1866 pop up since RAM got uber expensive. 2133 exist but not seen any for sale. would 2133 make a noticeable difference? i mean proper 1866 aint that bad. Did anyone manage to get Coreboot working (and did it unlock anything not already available in HP's version) , i know there was a 8770W build. HP Elitebook 8570w - i7-3940XM / 32GB HyperX 1866 (fake) / 1TB Samsung Evo / 512gb Kingston Msata / K1000m (to be 980M)
Dink Posted May 20 Posted May 20 @ Vladka76 Hi , I am wondering if you can help , not sure if this is exactly the right place on your forum but I see you are discussing the HP Elitebook 8570/8770 w and Video cards with Dreamcolor displays. I have a HP Elitebook 8770w , i7 3920XM , 32GB RAM , Dreamcolor screen , BIOS F71 , Win 10 x64 I am running Legacy boot not UEFI if that matters . Initially I had an AMD Firepro M4000 video card and have changed it to a Nvidia M3000M with appropriate heatsink , however I cannot get past POST , I get no HP logo or " esc " choice to show BIOS on the Dreamcolor screen , it seems to stall at end of POST and waits , as a quick tap on power button turns it off . There is no VGA or DISPLAY PORT output , I have tried disconnecting the video cable to screen to force a VGA output but that gives me a hard stop and shutdown at end of POST. Reverting to old AMD card everything is fine. This is all the info I know about the video card , it looks perfect physically even the stickers are white and show no signs of heat : Nvidia M3000M from ZBook 17 G3 Video BIOS version : 84.04.8D.00.04 ( 900-52754-0300-000 G ) or ( 699-52754-0501-400 N ) Quadro M3000M S/N 03238 16027699 N16E-Q1-A1 HP Assy No : 806269-001 SPS 827226-001 ( Date Code : 7J16A0 ) My question is simple , should I be getting at least the HP logo or BIOS screen with this card on this VBIOS , I appreciate that I will have driver issues for Windows , but at the moment I am at a loss how to fault find what I have . Hoping someone can shed me some light on this or at least give me some pointers. I see there are ways to flash the VBIOS from a USB key using nvflash ( https://www.techpowerup.com/articles/overclocking/vidcard/34/10 ) and a VBIOS file here ( https://www.techpowerup.com/vgabios/220986/220986 ) But I am not sure if this is my problem , or if it will work as I can't get display . .
Daedalus Posted May 21 Posted May 21 Welcome Dink, glad to have you here, as someone who had similar fun when i tried to upgrade to a 965M card, i too got no POST, just a blank screen, its sounding like your VBIOS isnt correct. If the older card you had in previously worked then the system Bios should be ok. I too have .71 advised by HP when i upgraded, that said others on here run earlier system bios versions. KBX on here runs a 980M but with a earlier SBIOS. if you can get output on any (VGA/DP/main screen you can use NVflash) if not then worth trying either a CH314A USB flash tool or find another machine which has IntelGPU so you can get an output. Unfortunately the 8770 and 8570W cant run intel's IGPU as no pins from CPU even though the CPU has it built. I'm running a k1000M but tried a 965M before going down the 980M SLI path. 2 HP Elitebook 8570w - i7-3940XM / 32GB HyperX 1866 (fake) / 1TB Samsung Evo / 512gb Kingston Msata / K1000m (to be 980M)
JadeRover Posted May 21 Posted May 21 On 5/20/2026 at 11:00 AM, Dink said: My question is simple , should I be getting at least the HP logo or BIOS screen with this card on this VBIOS , I appreciate that I will have driver issues for Windows , but at the moment I am at a loss how to fault find what I have . Hello, yes I think I know what the problem is. You 8770W with dreamcolor screen connects directly to the GPU in the MXM slot meaning that the GPU must be configured to have eDP output to the dreamcolor screen (dreamcolor LCD uses LVDS but all laptops from that era with DC screen use an internal eDP to LVDS converter -> GPU needs eDP output to be set on the correct lane for it to work) Your 8770w had eDP on lane "D" of the MXM slot *, the signal then goes to the LCD connector, then to the eDP to LVDS converter and finally to the LVDS DC screen. See schematic of your 8770w, eDP are on the last 10 pins of the LCD connector, signal are named DPDx_Dx = DP_D The issue is that the zbook 17 g3 you got the card from uses eDP on lane "C" ! So the card is configured to output eDP on the wrong channel compared to your 8770w = no display. (I know this from my first hand experience getting MXM cards to work on my 17 g3 and getting no display as well because of eDP lane mismatch) The fix is simple, you need to flash a vbios that has the correct display configuration to the card. This dell vbios has eDP on DP_D (as it is from a precision 7710 that has eDP on DP_D): https://www.techpowerup.com/vgabios/221521/221521 They are several ways to flash the correct vbios. I recommend getting a CH341a programmer with 1.8v adapter, it costs 10 dollars max. Good luck and ask away if you have more questions * This is good news as this is the standard for MXM gpus, you could even upgrade to an RTX card by x-vision or other brands that come only with a vbios configured with eDP on DP_D ! 1 Precision M6700 : i7-3740QM | P3000 6gb engineering vbios | 20gb DDR3 1600Mhz | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | M3000m 4gb | 16gb DDR4 2400Mhz | FHD ips Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 2666Mhz | (crappy) FHD ips -> 1440p165hz upgraded Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 | FHD IPS
SuperMG Posted May 21 Posted May 21 3 hours ago, JadeRover said: Hello, yes I think I know what the problem is. You 8770W with dreamcolor screen connects directly to the GPU in the MXM slot meaning that the GPU must be configured to have eDP output to the dreamcolor screen (dreamcolor LCD uses LVDS but all laptops from that era with DC screen use an internal eDP to LVDS converter -> GPU needs eDP output to be set on the correct lane for it to work) Your 8770w had eDP on lane "D" of the MXM slot *, the signal then goes to the LCD connector, then to the eDP to LVDS converter and finally to the LVDS DC screen. See schematic of your 8770w, eDP are on the last 10 pins of the LCD connector, signal are named DPDx_Dx = DP_D The issue is that the zbook 17 g3 you got the card from uses eDP on lane "C" ! So the card is configured to output eDP on the wrong channel compared to your 8770w = no display. (I know this from my first hand experience getting MXM cards to work on my 17 g3 and getting no display as well because of eDP lane mismatch) The fix is simple, you need to flash a vbios that has the correct display configuration to the card. This dell vbios has eDP on DP_D (as it is from a precision 7710 that has eDP on DP_D): https://www.techpowerup.com/vgabios/221521/221521 They are several ways to flash the correct vbios. I recommend getting a CH341a programmer with 1.8v adapter, it costs 10 dollars max. Good luck and ask away if you have more questions * This is good news as this is the standard for MXM gpus, you could even upgrade to an RTX card by x-vision or other brands that come only with a vbios configured with eDP on DP_D ! I'm curious. So his GPU has HDMI in DP_D then? If it has simple DP in DP_D, it should have worked. As "eDP" HDP are just DP signals. I think the RTX Turing will work (if all ports are DP/DP++) on the Zbook G3 17. Sadly not with the X-Vsion nor with ZRT cards 😕
Daedalus Posted May 22 Posted May 22 On 5/21/2026 at 2:58 PM, SuperMG said: I'm curious. So his GPU has HDMI in DP_D then? If it has simple DP in DP_D, it should have worked. As "eDP" HDP are just DP signals. I think the RTX Turing will work (if all ports are DP/DP++) on the Zbook G3 17. Sadly not with the X-Vsion nor with ZRT cards 😕 With the Zbook, arent they "different" Dreamcolor boards so could be a different issue? how the output is displayed? if I recall, Zbook G5 are P/N L28742-001 (been trawling the heck out of HP manuals lately to find P/N for the 8570W ( i find 653278-001 or 690626-001) for ours. HP Elitebook 8570w - i7-3940XM / 32GB HyperX 1866 (fake) / 1TB Samsung Evo / 512gb Kingston Msata / K1000m (to be 980M)
SuperMG Posted May 22 Posted May 22 3 hours ago, Daedalus said: With the Zbook, arent they "different" Dreamcolor boards so could be a different issue? how the output is displayed? if I recall, Zbook G5 are P/N L28742-001 (been trawling the heck out of HP manuals lately to find P/N for the 8570W ( i find 653278-001 or 690626-001) for ours. As long as the LCD input is an eDP signal then it can work. But it can depend in the dreamcolor boards. Someone needs to try it.
Dink Posted May 28 Posted May 28 Thank you all for the replies and ideas . I didn't reply earlier as I hadn't ticked notify me of any replies on thread via email , of the joys of getting older 😁 I agree that its probably an eDP/LVDS issue related to vBIOS but how can I find which vBIOS will work with M3000M on my HP 8770w with a Dreamcolor screen . I have tried another card from HP with vBIOS version 84.04.9B.00.07 , still exactly the same as before , returning to the AMD Firepro M4000 everything works fine. I get no crazy fan activity , it seems to act exactly as it should . This vBIOS is what I have seen suggested , even EUROCOM replied to my email and suggested this vBIOS number 84.04.9B.00.07 , I have emailed back and said " Dreamcolor compatible " hoping they can maybe help with a different version number . TechPowerUp who host some video bios files suggest compatibility with Hp 8770w ( But never mention Dreamcolor ) they have vBIOS for the M3000M but its a Dell 84.04.9B.00.07 not an HP one, they also have a Boosted up version of Dell vBIOS 84.04.9B.00.07 with better specs etc that mentions it works on HP 8770w but DO NOT mention DC screen 😐 They are it seems a lot of the time using that vBIOS with a Dell M3000M ( Are Dell cards physically different ? ) There are also Dell 7710 cards that have vBIOS 84.04.9B.00.14 on eBay that some have working on the 8770w , but I can't find anyone that specifically says : HP 8770w + Nvidia M3000M + Dreamcolor = vBIOS number xx.xx.xx.xx.xx 😤 I don't have a clip and IC program to change vBIOS or a Desktop , and would prefer not to go that route if possible , and having no display whatsoever means using NvFlash from a USB key would have to be done blind , which I definitely ain't confident to do. Anyone got some ideas on which vBIOS version I need or whether it is better to be a Dell card or HP , or is it get a Dell card with 84.04.9B.00.07 or 84.04.9B.00.14 and try them as neither HP ones I've tried work ? I was just hoping I could get a real HP card to work so drivers would be easier to do. HP says the M3000M will work in a 8770w as shown below , but they do not mention DC screen might have an issue , without a specific vBIOS , so is it the DC thats causing me issues or just the fact its a M3000M with wrong vBIOS for 8770w , irrespective of screen ? ................................................................................................................................................................. TITLE: NVIDIA Video Driver and Control Panel VERSION: 385.73 REV: T PASS: 1 DESCRIPTION: This package provides the NVIDIA video drivers and Control Panel for the supported notebook model that are running a supported operating system. PURPOSE: Critical SOFTPAQ FILE NAME: SP82366.exe SOFTPAQ MD5: d56de020bd6f245c603e005b4acb6920 SUPERSEDES: SP82365 EFFECTIVE DATE: October 20, 2017 CATEGORY: Driver-Graphics SSM SUPPORTED: Yes PRODUCT TYPE(S): Notebooks HARDWARE PRODUCT MODEL(S): HP ZBook 17 G2 Mobile Workstation HP ZBook 17 Mobile Workstation HP EliteBook 8770w Mobile Workstation HP ZBook 15 G2 Mobile Workstation HP EliteBook 8570w Mobile Workstation HP ZBook 15 Mobile Workstation OPERATING SYSTEM(S): Microsoft Windows 7 Enterprise Microsoft Windows 7 Professional Microsoft Windows 7 Ultimate Microsoft Windows 8 Microsoft Windows 8 Professional Microsoft Windows 8.1 LANGUAGE(S): Global DEVICES SUPPORTED: NVIDIA NVS 3100M NVIDIA NVS 5100 NVIDIA NVS 510M NVIDIA Quadro 1000M NVIDIA Quadro 2000M NVIDIA Quadro 3000M NVIDIA Quadro 4000M NVIDIA Quadro 5000M NVIDIA Quadro 5010M NVIDIA Quadro FX 1500M NVIDIA Quadro FX 1800M NVIDIA Quadro FX 2700M NVIDIA Quadro FX 2800M NVIDIA Quadro FX 3600M NVIDIA Quadro FX 3700M NVIDIA Quadro FX 3800M NVIDIA Quadro FX 380M NVIDIA Quadro FX 770M NVIDIA Quadro FX 880M NVIDIA Quadro K1000M NVIDIA Quadro K1100M NVIDIA Quadro K2000M NVIDIA Quadro K2100M NVIDIA Quadro K2200M NVIDIA Quadro K3000M NVIDIA Quadro K3100M NVIDIA Quadro K4000M NVIDIA Quadro K4100M NVIDIA Quadro K5000M NVIDIA Quadro K5100M NVIDIA Quadro K610M NVIDIA Quadro M1000M NVIDIA Quadro M2000M NVIDIA Quadro M3000M NVIDIA Quadro M4000M NVIDIA Quadro M5000M NVIDIA Quadro M600M ENHANCEMENTS: - Provides enhanced security for the graphics driver. PREREQUISITES: HOW TO USE: 1. Download the file by clicking the Download or Obtain Software button and saving the file to a folder on your hard drive (make a note of the folder where the downloaded file is saved). 2. Double-click the downloaded file and follow the on-screen instructions. Copyright Copyright (c) 2017 HP Development Company, L.P. .............................................................................................................................................................
Vladka76 Posted May 28 Posted May 28 3 hours ago, Dink said: which vBIOS version I need or whether it is better to be a Dell card or HP , or is it get a Dell card with 84.04.9B.00.07 or 84.04.9B.00.14 Last year, I bought a brand new, sealed M3000m designed for Dell Precision 7710/7720, which came with the stock BIOS 84.04.9B.00.14 (exactly the same as in the link to technopowerup site above), and it works on my 8770w without any issues. However, my screen isn't a DreamColor at all - it's ordinary N173FGE-LA3 (HD+, LVDS 40-pin). Are you sure you have a DC screen? What's the hardware ID for your screen (look in Device Manager, string MONITOR/xxxyyyy)? 1 hp EliteBook 8770w: i7-3840QM | M3000m 4Gb | 16Gb DDR3L 1866Mhz (2 pcs original Kingston HX318LS11IB/8)
Dink Posted May 28 Posted May 28 I think this was the right screen shot you meant , PC loads the " HP Mobile Display Assistant " for Dreamcolor displays , and that only loads if you have a DC , it has the sticker on the screen trim saying HP Dreamcolor and I can flip from 8 to 10 bit support in AMD driver.
Vladka76 Posted May 28 Posted May 28 8 hours ago, Dink said: I think this was the right screen shot you meant , PC loads the " HP Mobile Display Assistant " for Dreamcolor displays , and that only loads if you have a DC , it has the sticker on the screen trim saying HP Dreamcolor and I can flip from 8 to 10 bit support in AMD driver. Yes, this is it. Congratulations on the screen type. Take care of it, such LCD's are quite rare now. hp EliteBook 8770w: i7-3840QM | M3000m 4Gb | 16Gb DDR3L 1866Mhz (2 pcs original Kingston HX318LS11IB/8)
Dink Posted May 28 Posted May 28 Thanks , I do love the colours it gives , but the brightness can hurt the eyes , unfortunately it makes doing mods like this a pain. @JadeRover seems very clued up on how and why , reading back over the thread again , now I am at my PC. I think I may have to bite the bullet and get another card , this time a Dell one with vBIOS : 84.04.9B.00.14 , just wish I had the time to play / learn how to use a chip programmer and try the different vBIOS files that I have . @JadeRover I see a few sellers on Ali express list the M3000M with vBIOS version 84.04.9B.00.14 , they also give a choice of HP or Dell , I assume they brand the card in some way , am I better to get a Dell or HP branding , would either make loading drivers after this nightmare any easier is there a downside as I assume they can't change the PID/VID values or can they ?
JadeRover Posted May 29 Posted May 29 Hello, Yes luckily M3000m is getting really cheap, I got mine for 70 euros last year, now the price has dropped ! Probably the best price to performance card you can get for a working MXM card with little hassle (it also has LVDS support for even older MXM laptops). I would get the "for DELL" version. I had gotten mine from aliexpress for my precision m6700 that also has eDP on DP_D (just like your system) it was branded "for DELL" as well and it did have the correct display outputs set in the vbios. It was plug and play and my internal LCD worked properly, I didn't check the display port but I assume it works as well. - I think "for HP" is for the zbook 17 g3 that these cards originally came from where you have eDP on DP_C -> You would have the problem you had previously of diplay output mismatch. - I think "for DELL" is for dell precision 7710 that these cards where shipped in as well. That laptop has eDP on DP_D -> Would fix your problem. Good luck ! You can always sell your old card for probably the same price you got it for on ebay. 1 Precision M6700 : i7-3740QM | P3000 6gb engineering vbios | 20gb DDR3 1600Mhz | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | M3000m 4gb | 16gb DDR4 2400Mhz | FHD ips Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 2666Mhz | (crappy) FHD ips -> 1440p165hz upgraded Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 | FHD IPS
Dink Posted May 29 Posted May 29 @JadeRover Yes I agree I thought that , but was interested to know your thoughts , if I could find a seller with an HP card that was prepared to flash 84.04.9B.00.14 onto it , would this correct the DP output and would I then be able to use an unmodified driver , I would assume yes , but am I missing anything ? Some mention a whitelist on the video cards and you need a Dell card to get past it , have you come across any issues with this , I appreciate the Micro code in Main BIOS is relevant for it to recognise the card but I can't see HP putting in Dell ID's and not HP ID's ? Unfortunately the seller listing above , confirmed he had no idea what vBIOS they had and it was a generic picture , so the sticker is irrelevant 😥 So my quest goes on 🤣 I am predominantly looking for Dell M3000M now with 84.04.9B.00.14 , as you suggested , but still would be interested on your thoughts on above as you have tried MXM cards in ZBooks etc.
JadeRover Posted Saturday at 03:01 PM Posted Saturday at 03:01 PM Hello, 20 hours ago, Dink said: if I could find a seller with an HP card that was prepared to flash 84.04.9B.00.14 onto it , would this correct the DP output and would I then be able to use an unmodified driver , I would assume yes , but am I missing anything ? Yes, keep in mind all green pcb M3000m are the same regardless of HP or DELL branding, the only reason they call some DELL and others HP is for the different vbios. So yes if you convince the seller to flash that vBIOS for you it will work. Regarding driver install, you will need to mod an official driver yourself with nvflash (not complicated there are plenty of short tutorials on how to do so). 20 hours ago, Dink said: Some mention a whitelist on the video cards and you need a Dell card to get past it , have you come across any issues with this No whitelist has never been an issue for me, only MXM laptops that have a whitelist and that I know of are lenovo P70 and P71 as well as early clevo dual MXM gpus laptops. 20 hours ago, Dink said: So my quest goes on 🤣 I am predominantly looking for Dell M3000M now with 84.04.9B.00.14 , as you suggested , but still would be interested on your thoughts on above as you have tried MXM cards in ZBooks etc. Haha ok, honestly I would get a CH341a programmer, it really isn't that difficult to get it working, you can then flash 84.04.9B.00.14, especially if you still have your m3000m card with a zbook 17 g3 compatible vbios. 1 Precision M6700 : i7-3740QM | P3000 6gb engineering vbios | 20gb DDR3 1600Mhz | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | M3000m 4gb | 16gb DDR4 2400Mhz | FHD ips Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 2666Mhz | (crappy) FHD ips -> 1440p165hz upgraded Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 | FHD IPS
Dink Posted Saturday at 03:27 PM Posted Saturday at 03:27 PM @JadeRover OK , that makes sense now , thank you for the explanation , I will let you know how my quest goes 😁 Regarding drivers , yes I have seen a few tutorials , looks similar to what we had to do years ago for Broadcomm Bluetooth dongles , in XP , That bit I feel confident on , but flashing with a CH341a 🙄 if I can't find a card in a couple of weeks then I may succumb to your suggestion. It's not immediate as I have this HP 8760w with a DC screen I am using now , this will be my upgrade 😊
GuitarG Posted Saturday at 06:32 PM Author Posted Saturday at 06:32 PM Well, seems DC screen have new problem lately. I left screen closed for few days and that happened. So not only do they get very hot and are too bright (on lowest settigns), but they also have trouble with image retention 😕
JadeRover Posted Saturday at 08:38 PM Posted Saturday at 08:38 PM Ouch, that's unfortunate, maybe the age of the liquid cristals is making the image burn in ? I did notice that the DC screen on my m6700 would get very hot at the bottom of the screen bezel, where the eDP to LVDS converter sits, like 60°C hot ! Precision M6700 : i7-3740QM | P3000 6gb engineering vbios | 20gb DDR3 1600Mhz | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | M3000m 4gb | 16gb DDR4 2400Mhz | FHD ips Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 2666Mhz | (crappy) FHD ips -> 1440p165hz upgraded Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 | FHD IPS
Daedalus Posted Monday at 12:21 PM Posted Monday at 12:21 PM @Dink Damn you got a DC screen, you lucky soul. I wonder if the invertor under the screen area needs a heatsink of sorts as it seems to run hot. That said an AMD card shouldnt push it too much, heck even the M3000M should be fine. IIRC, the dell Bios are more amenable to our machines, as @JadeRover mentions seem to be more usable, the 980M i got from SuperMG on here has it i think as the card came from a 6700, so hoping i get lucky and get POST displayed. If you do get POST then at least you can flash a new VBios via NVflash, otherwise its oldskool via CH341A (which im not looking forwards to as its not 100% successful) HP Elitebook 8570w - i7-3940XM / 32GB HyperX 1866 (fake) / 1TB Samsung Evo / 512gb Kingston Msata / K1000m (to be 980M)
Dink Posted Monday at 06:30 PM Posted Monday at 06:30 PM @Daedalus well I thought that till I spent a few weeks trying to get a screen working with an Nvidia card 😂 blank screens are hard to fault find , but I do love DC screens the colours are amazing. It does look nice on the AMD Firepro , just not that good as its only got 1 GB vram , it came with a 1TB 5400rpm HDD so performance is slow , but it will be built on an SSD but can't till I get this video issue sorted , I want to use this copy of Win 10 as a test bed for drivers etc before building a final version on SSD . I am on a HP 8760w with a DC screen now , never felt inverter get really hot ? it's been on for 6 hours now lots of video etc but nothing crazy and its probably warm to the hand ( 40-45c ) however I am always on 230w power supply so no heat from battery .( Ambient 20-25c ) On my old 8740w with DC the converter board behind screen was missing a heat sink pad , putting one in made the back of screen cooler as it sinked away heat better rather than a hot spot that was hot to the hand 50-55c ? Why do I get this on @GuitarG posts , do I need to VPN to see it ? I am in UK.
Daedalus Posted Tuesday at 01:50 PM Posted Tuesday at 01:50 PM Hiya Dink, glad your on the path to get it sorted. Yeah SSD on the 8570W's really improves things, i have a samsung Evo 1TB SSD on it now going from an 500GB HDD, really moved faster. maxed it out with a i7-3940XM. Agree the older smaller cards do just plod along, currently trying to get the 980M from SuperMG working at present to give it more life. I get the image display errors too, thought it was only me. Also in UK too, so its not just you. HP Elitebook 8570w - i7-3940XM / 32GB HyperX 1866 (fake) / 1TB Samsung Evo / 512gb Kingston Msata / K1000m (to be 980M)
